| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#41 | ||||
__________________
www.Locostbuilders.co.uk |
#42 |
Got a bit of work done over the last few days.
Made some new bearing mounts for the rover diff. I was going to use pillow block bearings but the mounts were too wide and would have fouled the diff so i made these at work. ![]() ![]() Mocked up ![]() All welded up and placed on the end of the diff to check that it wont foul ![]() ![]() Now fully fitted to the diff ![]() ![]() All together with drive shafts and uprights, just making sure everything turns without catching. ![]() Custom made uprights and brackets to take Saxo front calipers ![]() ![]() ![]() The new rear lower engine mount ![]() ![]() ![]() Front lower engine mount ![]() ![]() ![]() And the front upper mount, still to be welded on. ![]() Over the next week or so the engine mounts will be complete, the mounts for the diff will be welded in and the diff/shafts etc will all be painted and fitted.
__________________
#43 |
Did a little more on the diff
With its new frame ![]() ![]() ![]() ![]() the ends of the tube needed threads so i did this by welding 2 small square blocks together with an 8.5 mm hole and this was then taped with an M10 thread. ![]() ![]() ![]() ![]() ![]() The diff can now be bolted in place ![]() ![]() ![]() ![]() ![]() Over the next few days i will have the lower tensioners fitted.
__________________
#44 |
Right spot the difference lol
BEFORE ![]() AFTER ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() got bored of only 1 engine and decided to give myself a real challenge. there now mounted with only the rear lower mount to make/fit. I'm a bit skint at the minute so cant get much done right now but it will moving along slowly as the funds allow. I'm aiming now for a sub 500kg final weight which is still a realistic target.
__________________
#45 |
Capt Chaos
that should be fun are you running 1 engine 1 wheel or are you going to link the 2 engines together then go to the diff ???????????????????//
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,, ![]() ![]() TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION Clicky |
#46 |
a good mate of mine fitted two busa engine in his kit car, lives in normanton near me, he will be your man to talk to regards the issues you will come up against, if you can get it all working it will be great!
#47 | |
Quote:
Wide Ka: I pretty much have it all worked out in my head how it will all go but and help would deff be an extra bonus.
__________________
#48 |
Wow,just a small change of plan!!!!!!
My m8 who has built 3 MK Indys all bike powered is now building a MEV Sonic with a Fiat Uno turbo engine in the back with Fiat X19 gearbox.
__________________
. . . Saph gone,but not forgotten. My car interests have EVOlved............. You may PREFER your Cosworth,but not a sniff they are BETTER cars than Evos sorry................. My 309 Gti re-shell/resto thread: http://www.309ownersclub.com/Communi...hp?f=30&t=3552 |
#49 |
now that looks like a lot of fun.
good luck m8
__________________
link to my cossie powered renault 5 http://passionford.com/forum/restora...nault-5-a.html |
#50 |
Excellent mate, I have wanted to build a twin bike engine kit car for years, I planned on using two V-Twins though for a laugh.
![]() Good going!!!
__________________
Live Fast, Die Young and leave a good looking corpse. |
#51 |
__________________
#52 |
That's fucking cool, how do you make a diff chain driven as I assume it still needs oil or lube of some sort?
__________________
#53 |
Trader Score: (1)
Rep Power: 33 ![]() |
This will be some toy.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#54 | |
Quote:
Depends on the diff. i just sealed it up and filled it with CV grease. there are better ways but this will do for now. I plan to make a better diff with an oil supply when i can afford to.
__________________
#55 |
What diff did you use mate?
__________________
#56 |
Im using an LSD from a rover PG1 box. The car has the same rear track as a MGF and uses MGF drive shafts so was easy to use the Rover diff rather that make custom shafts to suit an other diff.
__________________
#57 |
Just thought id put up a few pics, no real progress today but i had to put the car on its wheels so i could move it out of the garage as i'm digging out my pit. First time its been on its wheels in about a year so was nice to see it back rolling. forgot how low/small it is.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Got a few parts coming next week so i can get the jack shaft built up and have the diff mounted.
__________________
#58 |
Any updates mate?
__________________
#59 |
Sorry no updates. the car is for sale right now but im not sure bout letting it go just yet.
__________________
#60 |
Did notice it on Pistonheads for sale.
How will you get a reverse gear on this set-up?????? As its compulsory now I believe for a road kit car is it not?????
__________________
#61 |
an extra gear will be fitted to either the diff or jack-shaft and a starter motor mounted to it. this will give enough power to move the car backwards.
The car has been for sale for a week now and had a few emails/calls but nothing serious yet so it could still be staying. just wish i had some cash to do more work. will proberly be shoved to the back of the garage untill i get some more funds.
__________________
www.Locostbuilders.co.uk Last edited by CraigJ; 14-03-2010 at 07:50 PM. |
| Display Modes | |
