Turboed ST170, 6 speed ERST now ZVH & GT30.......RIP.
Old 06-03-2007, 04:13 PM
sas
should be good!
sas's Avatar
Default Turboed ST170, 6 speed ERST now ZVH & GT30.......RIP.
I undertook a rebuild of my ERST at the begining of this year 2007.
I wanted to turn my ERST into a very quick car and as mentioned by several members you get board with 350+bhp!
The plan has been ever changing.
I decided to build an engine with 500ish bhp and then using a wizard of nos kit add upto another 100bhp.
Well here are some pics of the build so far. Everything is almost finished but I have not done any tidying up yet so it is in a "in work" state.
The block is my old Zetec block from the last build although it is only 8 months old, purchased from Ford. The crank has been lightned, balanced and Nitrided. I have WRC rods and my own spec of pistons to suite the cam. I am also using a resin head gasket.
I am fitting a side exit exhaust all 3inch pipe work and a Jamsport exhaust manifold. I will be using my external wastegate with a K26 turbo (not up to the full 500bhp but will be a starting point) and then changing to a Turbonetics T62.
The head is a ST170 casting which currently is away been flowed, having larger valves fitted.
Newman cams are currently reworking the cams, springs and followers.
I am fitting Gotech Pro-X which has anti lag, boost control and will control the VCT in the ST head. Since changed to Pectel T2.
I have fitted a Max Extreame nos controller to control the 100bhp hit of nos and it does my shift lights too. I am using direct port nos controlled by 2 nos solonids and a 11lbs bottle with heater.
The gearbox instal has been completed but taken out again. It consists of a new mount welded onto the inner wing and a torque reaction mount under the floor. The cable change mechanism was easy to fit.
The shaft are spec made by Dave Mac propshafts.
The box has been rebuilt to include a Quiafe LSD.
I have made my own inlet manifold which is a very heavly ported Rover lower part with my own plenum design. I have constructed the plenum but waiting for my new Tig welder to turn up so I can stick it all together.
All boost pipe work has been uprated to 3inch and fitted a 80mm thick intercooler
The gearbox install has ment that the servo has had to be ditched and a new pedal box has had to be installed (what a bitch that was!)
Old 06-03-2007, 04:23 PM
Brian
Brian's Avatar
Nice one mate
Carnt wait to see it finished
Brian
Old 06-03-2007, 05:14 PM
rapidcossie
rapidcossie's Avatar
good luck with this...
think you will struggle to get anywhere near the power tho.
You will need a bigger exhaust too
Old 06-03-2007, 05:40 PM
sas
should be good!
sas's Avatar
Cheers mate,
I have done my swotting up and a 3 inch short exhaust (side exit) will be up to the job. But my K26 wont be.
It's not looking good for Crail running out of time.
Simon.
Old 06-03-2007, 05:44 PM
KSA-Cossie
KSA-Cossie's Avatar
Whats the chances of coming up to see this beast one weekend si ?
Old 06-03-2007, 05:51 PM
sas
should be good!
sas's Avatar
Hi Kev, I work on it most nights and evey weekend so just name your time.
S.
Old 06-03-2007, 05:53 PM
KSA-Cossie
KSA-Cossie's Avatar
Cool m8,is it ok to use the number on your business card ?
Old 06-03-2007, 06:16 PM
rapidcossie
Cheers mate,
Simon.
a shorter exhaust can be of a less diameter so you might be ok
Old 06-03-2007, 06:18 PM
TimC
TimC's Avatar
thats going to be very naughty
Old 06-03-2007, 06:53 PM
749steve
749steve's Avatar
nice
Old 06-03-2007, 07:24 PM
zippyobrien
zippyobrien's Avatar
i think ive just spunked all over my laptop
can i prapose to your car???
Old 06-03-2007, 09:35 PM
fezzajsy
fezzajsy's Avatar
wiil be a monster
Old 07-03-2007, 09:26 PM
sas
should be good!
sas's Avatar
Thanks for all your kind words.
Todays progress is as follows-
Welded up the base of the plenum, which ment that I could bolt the trumpets in for good and tap and drill the base for fitment to the inlet runners.
I also modified the Willwood dics to fit under the 15 inch alloy. I am down grading my 16 inch OZ ultraleggeras for 15 as they offer a better choise of rubber.
The calipers and disc just fit under!!!
Simon.
Old 07-03-2007, 10:13 PM
Rab
Fucking superstar........
Rab's Avatar
Awesome!
Nice to see people thinking outside the box on the old RSTs.
With a bigger turbo it'll be a smoke machine! I hope you're good mates with whoever you buy your tyres from
Keep us updated
Old 07-03-2007, 10:30 PM
sas
should be good!
sas's Avatar
Nice to see you back Rab.
Had a nice time away?
Thanks for the coments.
But for my own refrance I want to see what the K26 will do.
S.
Old 08-03-2007, 12:09 AM
r-s-turbo
r-s-turbo's Avatar
fair play its builds like that this that make me wana get a loan n start mine from scratch!
Old 08-03-2007, 02:53 AM
MikeR
MikeR's Avatar
Simon that looks mental, i know this car very well, i brought my old rst from Mark Pett who owned this car and treat it like a museum piece,
Good look with your plans nothing like thinking out side the box
Mike
Old 08-03-2007, 03:58 AM
massivewangers
massivewangers's Avatar
Liked this a lot when it was featured, it's certainly gotta be one to watch, gonna be a monster
Old 08-03-2007, 08:18 AM
sas
should be good!
sas's Avatar
Mike
The car is still mint apart from the great big gearbox mount welded to the inner wing. Other than that it still is an unwelded example.
I am trying very hard not to distroy any of its origonality or at least be able to reinstate it.
I have all the recipts for the car since 1999 in a massive folder.
Simon.
Simon.
Old 08-03-2007, 08:30 AM
AustenW
AustenW's Avatar
Dont convert the head for the shorter plugs or you will run into a waterway
There are plenty of plugs available now for the Focus RS
Denso ITV30 are an NGK 9 equivalent
Just saved you a head
Old 08-03-2007, 08:40 AM
smitsturbo
smitsturbo's Avatar
alright simon mate
looking great, did you make the pedal box yourself aye?
keep us updated, another monster to watch this year
Old 08-03-2007, 11:57 AM
MAD matt-sab
MAD matt-sab's Avatar
shit this is serious !!!!
will be watching this thread very close
good luck mate !!!
Old 08-03-2007, 12:41 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
keep it up, should be a bit mad when done
Old 08-03-2007, 01:12 PM
sas
should be good!
sas's Avatar
Originally Posted by smitsturbo
alright simon mate
Hey Smits, you get the pedal box assy from Jamsport.
Plan to update every time I do somthing.
S.
Old 08-03-2007, 04:08 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Simon, what a stunning project, but I have to ask, WHY??!!
Mine is an absolute fucking animal at 350bhp and clearly way beyond the capability of the chassis. It is a killing machine, so 200-300bhp more??!!
Regardless of that, good luck, can't wait to see the results.
Old 08-03-2007, 05:04 PM
sas
should be good!
sas's Avatar
Not exactly sure myself!
I think I want to see how far my knowledge and ability will take me, and I enjoy making things.
S.
Old 08-03-2007, 06:33 PM
Zetec_mk4_XR3i
Zetec_mk4_XR3i's Avatar
Fantastic work mate, car looked lovely in PF and gonna keep an eye on this one!
Do you do tuning and rolling roads etc? Be lookin to get my S1 set up etc and not many places about here that are familiar with old RS's
CheeRS
Ross
Old 08-03-2007, 06:37 PM
luke89
Team HOTHOT!
luke89's Avatar
what else will be done to help get the power down ? should the hole shell not be seam welded at min? looks like a mental project mate keep the pics coming
Old 08-03-2007, 06:47 PM
rapidcossie
should put all your time and money into a cossie
can handle the power a bit better
Old 08-03-2007, 06:59 PM
AndyNo1
AndyNo1's Avatar
What a great bloody project! Will be keeping a close eye on this one Simon.
All the best
Old 09-03-2007, 10:45 AM
sas
should be good!
sas's Avatar
I have a preferance for the MK4 Escort over the Sierra.
My dad and I have a K reg cossie that we have owned from new, so I know what they are like (supurb), but on the modifing front you can buy all the kit to make the cossie into an animal and it has been done many times before - respect to all modified cossies.
I wanted to do something that was a challange!
Again thanks for all your encouragement.
Simon.
Old 09-03-2007, 02:40 PM
MAD matt-sab
will this be the 1st 180 mph rst ?????
i wouldnt bet against it !!!!!
that would put it in rainbums sapp league !!!
keep up the good work !!!
Old 10-03-2007, 12:37 PM
Rab
Rab's Avatar
S.
I wish I was back mate. But I'm liviing in Heswall in merseyside while I'm doing a major re-fit of the RFA Diligence.
I'm almost sure I'm coming back to the oval after this last 6 months in a German barge
Could be S2 number 10 for me At least I'm consistent.
Hows the business coming along? Intrested in a bit of work on whatever I end up with?
Old 10-03-2007, 12:46 PM
AdamB
AdamB's Avatar
looks a really good project
what 15's are you getting? glad you're getting rid of the OZ's as i'm not a fan
Old 10-03-2007, 09:10 PM
sas
should be good!
sas's Avatar
Rab, I am always interested in helping!
For my new 15inch alloys I was going to get the same Ultraleggeras because they are so light. Unless I can find some lighter forged ones without blowing the hole budget!
I remember when I fitted the 16inchers to my car, and I could really feel the differance in the response in the steering.
S.
Old 11-03-2007, 12:39 PM
AdamB
AdamB's Avatar
please, get superleggeras if anything
Old 11-03-2007, 02:40 PM
dsgtrain
dsgtrain's Avatar
This is going to be more than a animal, It's a BEAST!! Good luck with it mate
Old 11-03-2007, 04:31 PM
throttlebodiedzetecturbo
throttlebodiedzetecturbo's Avatar
[img]
http://i88.photobucket.com/albums/k185/simonsmail1/07032007122.jpg[/img]
Simon.
Simon with the boost you want to run those air horns do not stand a chance they will collapse. formed alloy is to weak to withstand the pressures. idealy you need some cast ones.
Old 11-03-2007, 04:40 PM
sas
should be good!
sas's Avatar
[img]
Simon.
Thanks for the tip! I have now sealed up the plenum. I will just have to keep an eye on them.
S.
Old 11-03-2007, 05:14 PM
Butch.
Butch.'s Avatar
Good to see you sticking at it simon
Quick Reply: Turboed ST170, 6 speed ERST now ZVH & GT30.......RIP.
