Peugeot 205 with 4wd cosworth engine and running gear.
Old 19-11-2016, 05:53 PM
  #1201
jonfoc
jonfoc's Avatar
Originally Posted by FLAT TRACK
most of the problems are because people dont put floor /mounts in right place to start with which knackers all the geometry up
Good job I've got a man in the know sorting mine
Old 04-12-2016, 12:32 PM
  #1202
Caddyshack
Caddyshack's Avatar
After hearing about a few car fires I thought I would fit a proper msa approved battery isolator, I went with one that stops the car running on the alternator and completely cuts the earth along with power to the ecu and fuel pump.
I went for the Solid state cartek, it is expensive (bought from demon tweeks) but seems to work really well, I have an internal cut button which doubles as the reset and then it has an external one too....I haven't decided where to put that yet as I don't need to comply with any rules.
Old 12-12-2016, 05:37 PM
  #1203
Caddyshack
Caddyshack's Avatar
I got my front bladed ARB mounts today from Mark at MK, they will be a great base for me to fabricate from...I expect people will will be able to work out where his welding ends and mine starts though.
Just the 6 degree beam to go now
Old 12-12-2016, 06:25 PM
  #1204
jonfoc
jonfoc's Avatar
Result! I'm off up there tomorrow mate I'll ask the question. Let's see a picture of the mounts please.
Old 13-12-2016, 07:20 AM
  #1205
Caddyshack
Caddyshack's Avatar
Ok, will get some update pics done
Old 16-12-2016, 09:55 AM
  #1206
Caddyshack
Caddyshack's Avatar
We are sinking the workshop ramps so they are flush with the garage floor so I had to get the pugs out. Thought I would take a quick pic
rooos (17-12-2016)
Old 16-12-2016, 10:02 AM
  #1207
jonfoc
jonfoc's Avatar
Nice collection there mate. Can you adjust the exhaust to get it level. It looks like it's sloping a bit.
Old 16-12-2016, 10:23 AM
  #1208
Caddyshack
Caddyshack's Avatar
Thanks, the 944 has had to stay in the garage and get dusty as the engine is out and waiting to go on the ramps for a new motor to go in.
You are right and it does my head in every time I look at it. It will be corrected soon, it only sits like that due to the new mount for the oppliger gearbox, now that I have removed the front standard ARB I no longer need the hump and restrictive flat in the pipe so I am going to have that section cut out and a straight put in, at the same time I will get them to raise the rear for better ground clearance and level the box. I think I will have more room with the new rear beam too as it will do away with the Supra fitting kit which I think will give a few cm more room.
Old 17-12-2016, 06:48 PM
  #1209
rooos
rooos's Avatar
the red one is something sexy, mate !
(even with the sloped exhaust...)
Caddyshack (17-12-2016)
Old 19-12-2016, 03:31 PM
  #1210
Caddyshack
Caddyshack's Avatar
Work shop ramps going in the ground so they sit flush
Old 19-12-2016, 05:14 PM
  #1211
COLEYST200
COLEYST200's Avatar
Looking very good there Toby
Old 19-12-2016, 06:16 PM
  #1212
jonfoc
jonfoc's Avatar
You've got all the toys, very nice mate
Old 23-12-2016, 11:26 AM
  #1213
Caddyshack
Caddyshack's Avatar
Ramps are back in the ground, need to put the floor tiles back and tidy up now.
I have been painting the walls to freshen it up, once it is all sorted I can look to fit my front bladed arb.
Old 24-12-2016, 08:05 PM
  #1214
rooos
rooos's Avatar
bloody job! i've always hated to paint the walls, especially in winter and especially under the festivities... i don't envy you. merry christmas mate
Old 25-12-2016, 08:10 AM
  #1215
Caddyshack
Caddyshack's Avatar
Merry Christmas to you too
Old 25-12-2016, 03:23 PM
  #1216
COLEYST200
COLEYST200's Avatar
Happy Christmas Toby l hope you and your family have a good time
Caddyshack (25-12-2016)
Old 25-12-2016, 05:31 PM
  #1217
mattym
mattym's Avatar
Just read this from start to finish, well, to the state it is in now. What a machine, superb work and I hope you get it running how you want after all the effort you have put into it.
Old 27-12-2016, 12:00 PM
  #1218
Caddyshack
Caddyshack's Avatar
I got my stack shift light working today so that is another job off the list.
I have offered up the bladed anti roll bar for the front and with a bit of fabrication I can get the MK mounts to work on the 205 chassis. Then once Mark Walker (mk) delivers the rear 6 degree beam I can see if I can get a rear bar in there too, I can then really soften the springs and fit the new Leda dampers that I am going to order then get it all set up by a chassis guru.
MK thinks he may drive the beam down over the next week in his van which will be good news.
I will get some pics up of the anti roll bar soon, I plan to fit it with riv nuts (steel) and the weld it in place.
Old 27-12-2016, 03:32 PM
  #1219
Caddyshack
Caddyshack's Avatar
Mk mounts on adjustable bladed arb
Need to play with the adjustment but at least I have an anti roll bar again now
Old 28-12-2016, 11:52 AM
  #1220
Caddyshack
Caddyshack's Avatar
Both of these have twin scroll turbos, the BMW has an m performance Ecu and intercooler, both make nearly 500 lb ft of torque
I need to lower the front a bit
Old 28-12-2016, 04:06 PM
  #1221
jonfoc
jonfoc's Avatar
Looks epic Toby. We can sort the stance when we do the dampers.
Caddyshack (28-12-2016)
Old 28-12-2016, 04:45 PM
  #1222
M K
M K's Avatar
looks nice Toby
Old 28-12-2016, 04:59 PM
  #1223
Caddyshack
Caddyshack's Avatar
Originally Posted by M K
looks nice Toby
Thanks Marc, lots of Wrc bits now.
Old 29-12-2016, 04:11 PM
  #1224
costina
Live long and prosper!!
costina's Avatar
Toby you are only using the rivnuts as a temp fix to hold when your welding them on?
Hope so.
Paul
Old 29-12-2016, 08:30 PM
  #1225
Caddyshack
Caddyshack's Avatar
Hope so.
Paul
Yes, just to locate it. I am now welding it to the chassis.
Old 29-12-2016, 08:36 PM
  #1226
Adam-M
Adam-M's Avatar
Looks a little beast Toby a bet it is mega round a track. Really like the beemer aswell.
Old 29-12-2016, 08:42 PM
  #1227
Caddyshack
Caddyshack's Avatar
Thanks mate, will get on track soon. The beemer makes the cossie feel ancient but that is part of the fun, i love the pugs more after driving the modern stuff.
Old 30-12-2016, 12:22 PM
  #1228
Caddyshack
Caddyshack's Avatar
Hope so.
Paul
Welded the mounts to the chassis this morning, just need to paint the mounts and weld points this afternoon. Tried to get hold of my mate who has a laser hunter system in his tyre shop but seems he is on holiday.
If I can get my 6 degree beam from MK then I can get that fitted and dialled in too.
Old 30-12-2016, 02:14 PM
  #1229
Ridgey
Ridgey's Avatar
Good luck
Should be a handy piece of kit when everything is fitted
Old 30-12-2016, 02:55 PM
  #1230
Caddyshack
Caddyshack's Avatar
Originally Posted by Ridgey
Good luck
Thanks, it is starting to feel very direct with the steering. I think I will be able to soften it quite a bit though although it is not much firmer than a standard 205 right now but I do want it really supple, that should help when it does lose traction as it is 20cm shorter wheelbase than an sapphire and I don't want it too snappy.
I went and filled up with petrol today and the box and diffs seem to be getting looser with each mile I put on it, before I could not push it in neutral but I can now, it used to roll freely on the original diffs and I am sure it is those that are tight.
The shift of the oppliger is very short and precise but I still cannot get over the rate of acceleration in 2nd and often take my foot off the throttle before the shift lights.
Old 30-12-2016, 06:19 PM
  #1231
Jay,
Sponsor
Jay,'s Avatar
Mate have you not got this yet
Old 30-12-2016, 08:10 PM
  #1232
Caddyshack
Caddyshack's Avatar
No but hopeful it will be here soon.
Old 06-01-2017, 03:45 PM
  #1233
Caddyshack
Caddyshack's Avatar
Took the car to my mate to laser align the front geo, we struggled to get below 2.7 meg camber due to the 205 front being thinner than a cossie. I will need to bring the front in to 2 to 2.5 deg. The tracking also needs a little more adjustment so need to take a bit more off the steering arms but it is all pointing in the same direction now and the compression struts make it so easy to set the castor. It drove so nicely on the way home, still spins the wheels if you boot it from a rolling speed at 5000rpm in 3rd gear on a cold and damp road.
Turn in is really fast with very detailed feel....I have loads more of scope in terms of damping, spring poundage and adjusting the arb but it is getting better all the time.
Finally got chance to run it through 2nd, 3rd and the 4th changing around 6000rpm....my god it gets through the gears quick
Old 06-01-2017, 03:48 PM
  #1234
Jay,
Sponsor
Jay,'s Avatar
Lol all sounds like it's moving forward toby . Oh you up for a beer on the 12th dude it's the local group night ?
Old 06-01-2017, 04:20 PM
  #1235
Caddyshack
Caddyshack's Avatar
I might be able to make that, I will check and let you know. Thanks for the invite.
Old 06-01-2017, 05:04 PM
  #1236
Caddyshack
Caddyshack's Avatar
Old 06-01-2017, 07:52 PM
  #1237
COLEYST200
COLEYST200's Avatar
All sounding good Toby
Old 07-01-2017, 04:13 PM
  #1238
Caddyshack
Caddyshack's Avatar
Today I got the speedo working again as the MK Wrc hubs hide the bolts I was using for the sensor to see, now I have it working and re calibrated and all is well again.
I also had a slight rub on a calliper so I sorted that and now the brakes are lovely and quiet.
Next jobs are to get a bit more camber off the front to get under 2 neg and to get the exhaust back level.
I have put a few miles on it this weekend and the car is freeing up, I can now push it again.
Old 07-01-2017, 09:48 PM
  #1239
jonfoc
jonfoc's Avatar
I really need a passenger ride in this. Looks like it'll be up to full speed for summer
Old 08-01-2017, 09:11 AM
  #1240
Caddyshack
Caddyshack's Avatar
You can have a go in it any time you like but I would wait for a bit more development as I am still ironing out things to make it more like a daily driver.
jonfoc (08-01-2017)
Quick Reply: Peugeot 205 with 4wd cosworth engine and running gear.
