My 3 door 1990 track car
This is the story so far with my track car.
After a few trackdays last year i decided to make a few changes.
More power, better handling and safer construction.
As it was with the 3door kit
As it is now with out it
So out with the 2.0 Dohc and in with a Cossie lump. The V6 type
old engine
V6 24 valver
Fitted it from the bottom
Also changed the 4x4 box into a 2wd
Then it was time to try the top mounts. trial fitting.
To get the top mounts to fit the 4x4 struts the top bearing needs to be removed and spaced out with washers to stop it hitting the under side of the top mount.
After making a template for the mounting holes. The strut top was drilled
Then on to fitting the seats
Its of to have the cage done next week.
Thanks to Paul (Northyorkshire RS Spares) My wallet is getting thinner
old engine
V6 24 valver
Looking good rob,whens it ready for the off then ,?
Mine is not running at the mo ,the fueling is through the roof and the plugs get soaked within 5 mins of driving
Good news is i may have found a dizzy that is correct for the TT coversion we did,and a cage on fleabay
will have to takeit somewhare to get set up though i think ,the hydrocarbons wher 4times what they should be
track.focus'd
12-08-2015 05:53 PM
Versus_Creations
24
05-08-2015 09:32 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
