My 400+bhp Focus
Old 07-03-2006, 02:29 PM
Big Ad
Big Ad's Avatar
Default My 400+bhp Focus
Hi All
This is my project. Hope you all like it
Engine:
2.0 Litre Zetec Engine
Garret Hybrid GT3071-R Roller Bearing Turbocharger
Arrow Forged Steel H Section Rod’s
JE Forged Pistons
Standard Zetec Crank
Compression Ratio 8.2:1
2.0 Zetec Fully Ported & Polished Head & Shimming
Custom Piper Camshafts
Piper Vernier pulleys
Siemens 650cc injectors
Omex 710 Management System
Blitz Spec R Boost Controller
Aquamist Water injection
Focus RS In Tank Fuel Pump
Focus RS Water Pump
Focus RS Oil Pump
Primary Designs One Off Inconel Manifold Ceramic Coated.
Primary Designs One Off Inconel Downpipe Cermaic Coated
Primary Designs 3" Boar S/S Exhaust System
Ali Sport Alloy Intercooler
GGR Alloy Radiator
Quickshift induction kit
Bailey Dump valve kit
Cosworth Oil Breather Kit
3 Bar Map Sensor
12” Kenlowe Fans (Twin Blowers)
Transmission:
MTx75 5 Speed Box & Quaife ATB Limited Slip Differential, Shot Peened Polished Gear set, Custom AP Racing organic Clutch
Brakes:
AP 4 Pot Callipers & 330mm Grooved Discs On The Front & ST-170 Rear Set-up
Suspension:
Full PI Adjustable Coil Over Kit With Gas Shockers
Power Flex Bushes All Round
Exterior:
18” Team Dynamics Alloy’s With Yokohama A048-R 225/45/18
ITS STILL FWD
5.4 second 0-60mph
14.008 Second ¼ mile @ 108mph
152mph Top Speed
Done at Bruntingthorpe with Performance Ford on a damp day.
Next Mods:
ST170 Cylinder Head (Ported & Gas Flowed By Ian Howell @ Area 6)
ST170 Steel Inlet Manifold Made By Ian Howell
Race Logic Traction Control Kit Setup & Fitted By Chris Todd @ Power Engineering
Pics:
Some Old Vids When The Car Was 300bhp:
http://members.aol.com/ffocbigad/focusvideo/
The Second run on the manifold video is cool
Ad
Old 07-03-2006, 11:26 PM
Benni
Ban[B][/B]ned
Benni's Avatar
I've read about your car before mate and its smart as fuck I also heard you was going 4wd drive aswel
Old 08-03-2006, 08:11 AM
m4frd
m4frd's Avatar
is that a fire extinguisher your using on the front there?
Read the grudge match in the mag, looking nice
Old 08-03-2006, 09:07 AM
simhopper
simhopper's Avatar
will be co2 to cool the intercooler
looking good ad and the figures speak for themselves
Old 08-03-2006, 09:12 AM
Big Ad
Big Ad's Avatar
Thanks Guys
Yeah its a Co2 Fire Extinguisher, will freeze the intercooler and reduce ACT's
Old 08-03-2006, 10:21 AM
Muzz
Muzz's Avatar
A little bit quick then
Old 08-03-2006, 11:08 AM
Garage19
Garage19's Avatar
Thats very interesting.
A very similar spec to an engine i am helping to build at the moment.
Different rods pistons, 8:1 CR and same turbo.
Are you using a black top engine? We are using E bottom end with black top head. Standard crank as you are.
We are using the same turbo. What size exhaust housing are you running?
When does it start making boost? What psi are you running?
We are aiming for a very similar 400-420bhp. Good to hear someone else has already achieved this goal.
Old 08-03-2006, 03:50 PM
Big Ad
Big Ad's Avatar
Its a Black Top Engine.
Until I get a bigger intercooler it runs 1.4Bar and redlined Power Engineerings Dyno, which IIRC the 2WD Dyno is good for 300 @ The Wheels.
Uses the .86 Exhaust Housing
Once the the cooler is on its going to run around 1.6/1.7 bar and hopefully run around 450-460bhp
The cylinder Head will certainly help achieve this and maybe the addition of some gas
Old 10-03-2006, 06:56 AM
Benni
Ban[B][/B]ned
Benni's Avatar
460bhp So will this be the fastest fwd focus in the U.K then ?
Just to add, I will make you a proper sig out of the pics.
Old 10-03-2006, 07:19 AM
Benni
Ban[B][/B]ned
Benni's Avatar
Old 10-03-2006, 04:59 PM
Big Ad
Big Ad's Avatar
Wow, that sig. is great, Thanks mate
Old 10-03-2006, 08:41 PM
Benni
Ban[B][/B]ned
Benni's Avatar
No problem
Old 11-03-2006, 11:03 PM
Sleeper
Old 10-05-2006, 07:39 PM
TimC
TimC's Avatar
stunning - any pics of the engine?
Old 10-05-2006, 07:46 PM
Big Ad
Big Ad's Avatar
I pick it up from Primary Designs on Friday, I'll get some pics at FITP on Sunday of the engine bay.
No, When Ian Howell's Focus is finished it will beat mine by a fair few seconds on a 1/4 mile.
Old 10-05-2006, 08:25 PM
rs nutta
rs nutta's Avatar
thats a sweet motor you got there chap whats the top end on it that youv had
Old 10-05-2006, 10:18 PM
GUZZLER
GUZZLER's Avatar
i'm loving some of these Focus's
Ad's car is out of this world, Si's look & drives like a pretty stock ST170,,, untill you floor it, then theres Steve F's, lokks like a shopper & packs 300bhp hats off to you boys
btw, our 2wd dyno at P.E. reads 370-380 bhp at the flywheel, Big Ads car redlined the dyno & the power was stil climbing
Cousin Fuckers
Old 19-05-2006, 01:29 AM
Benni
Ban[B][/B]ned
Benni's Avatar
Old 19-05-2006, 10:54 AM
Big Ad
Big Ad's Avatar
Originally Posted by GUZZLER
Cousin Fuckers
Cousin
wowk
30-03-2021 07:49 PM
tankybaby66
06-02-2016 02:24 PM
Sp3no
27-09-2015 07:23 PM
Tank Mike
26-09-2015 08:07 AM
Quick Reply: My 400+bhp Focus
