My escort cosworth engine bay so far..
Old 23-07-2014, 08:47 PM
jaiscossie
jaiscossie's Avatar
Red face My escort cosworth engine bay so far..
Only had the car a few weeks but have spent a bit of time cleaning and replacing bits and pieces under the bonnet. Fitted a new heat shield , coolant tank and power steering tank (not happy with its colour really)
Going to get the rocker cover refurbed next, not sure if to keep it red or maybe go back to the oe blue.
Comments welcome good or bad and where I can improve
Old 23-07-2014, 08:54 PM
Mondi-DZK
Mondi-DZK's Avatar
Looks very clean. Good job i say
Old 26-07-2014, 09:26 AM
Harris.
Harris.'s Avatar
very nice ,I think id just change the blue hose then leave it
Old 27-07-2014, 08:33 AM
It does look good.You have a 2wd cam cover.
Old 27-07-2014, 08:55 AM
ginner
ginner's Avatar
It's a 500 engine
Old 27-07-2014, 01:35 PM
costina
Live long and prosper!!
costina's Avatar
My opinions only:
Hose from turbo to header tank needs to be routed either as a 4x4 or shortened
Fuel reg needs to be upright
change blue hose for black or std orange like the inlet.
But its your choice and what you want to achieve.
Regards
Paul
Old 28-07-2014, 09:12 AM
jaiscossie
jaiscossie's Avatar
Originally Posted by costina
My opinions only:
Regards
Paul
Hi thanks Paul, i have now shortened the hose from header tank and have a new set of hoses on order from roose Will put some more pictures up as she progresses
Old 28-07-2014, 09:39 AM
Originally Posted by ginner
It's a 500 engine
So it is lol.
Old 31-07-2014, 06:33 PM
jaiscossie
jaiscossie's Avatar
Managed to get a few more bits done today, did some more cleaning in the hard to reach areas of the engine bay. Painted the oil breather, map sensor bracket satin black, replaced the rubber fuel and breather hoses. Fitted new hose clips all round. Shortened and rerouted the header tank pipe and straightened up the fuel accumulator so now it sits right.
My new boost hoses from roose turned up to, really pleased with them.
Old 31-07-2014, 08:35 PM
costina
costina's Avatar
Old 31-07-2014, 08:40 PM
andy130
andy130's Avatar
looks nice an clean, great car you got there
Old 31-07-2014, 09:18 PM
costina
costina's Avatar
The coolant return from turbo to header needs to be routed thru engine lifting eye if you wanted it to be a little more factory looking. Also with that theme in mind coolant should be blue. Also warning sticker on abs reservoir
Looking good
Old 01-08-2014, 11:27 AM
jaiscossie
jaiscossie's Avatar
Looking good
Cheers pal i did wonder this as i looked at a couple of rs500 engine bay pictures. I have a decal on order for the brake res too I didnt know that about the coolant. I will get some ordered up and when i get chance get it flushed out. Im guessing all the red needs to be gone otherwise the blue is likely to go green
Old 01-08-2014, 03:17 PM
gjh
gjh's Avatar
Looks really good that!
Old 01-09-2014, 02:32 PM
jaiscossie
jaiscossie's Avatar
Old 01-09-2014, 05:53 PM
garrett
garrett's Avatar
looks amazing love the red came cover
Old 02-09-2014, 06:41 PM
ram
Has a large member
ram's Avatar
looks great.
What gearbox/diff setup you running with T4 power?
Old 02-09-2014, 07:25 PM
james kiely
james kiely's Avatar
i love it mate ,and somehow it looks at lot less cluttered than a standard escos bay
Old 02-09-2014, 07:58 PM
mk2cossy
mk2cossy's Avatar
Looks awesome, very tidy.
Old 02-09-2014, 08:12 PM
jaiscossie
jaiscossie's Avatar
Originally Posted by ram
looks great.
Cheers pal, it's running around 500hp at the moment, has a close ratio DPE box and standard diffs at the moment but looking to upgrade these next
Old 02-09-2014, 08:14 PM
jaiscossie
jaiscossie's Avatar
Cheers pal, it's getting more how I want it now, still not finished mind you
Old 02-09-2014, 08:16 PM
jaiscossie
jaiscossie's Avatar
Have tidied up a few more bits and rerouted some wires etc, more cleaning and replaced some more bolts and fixings etc.
Have put a before and after pic from when I got it till today
Before
After
Old 02-09-2014, 09:27 PM
Mondi-DZK
Mondi-DZK's Avatar
Perfection.
Old 05-09-2014, 06:13 PM
jaiscossie
jaiscossie's Avatar
Originally Posted by Mondi-DZK
Perfection.
Thanks pal, still lots to do mind
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
Wilsfoci
15
30-03-2016 10:26 PM
James Porter
26-08-2015 10:51 PM
track.focus'd
12-08-2015 05:53 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: My escort cosworth engine bay so far..
