Sierra 2jz cosworth (Norway)
Her is my Cosworth 4X4 saloon motorsport replica with oz racing mote carlo wheels
The car is soon to be a 2wd with 500 hp
littel update . was out for a testdrive . just some littel things that need to be fixed before we dyno it
and i am going to lower more in the back .
http://s350.photobucket.com/albums/q...4042009002.flv
this engine has been rebuilt by mr raimond nordnes .
im not that good at english so hope you understand
speical made tubles exhaust manifold
innovative race turbo ar 84
720 cc simens injecktors
special made std innlet manifold
areomotive fuel pump a1000
hi flow oil pump
je pistons 7,7/1 comp
arp pro 2000 rod bolts
arp studs
balanced bottom
montune bottom pan
steel rods
dubbel piper prepped for max 12,5 lift
16 new sodiumsfilled valvs
wrc head gasket
cnc prepped head and hand prepped by mr nordnes for max nw
flows to about 620 hk
newmann racing cams 288 duration 10,8mm lift
piper adjustebel cam pullys
again pardon my english
hi flow oil pump
arp studs
balanced bottom
montune bottom pan
steel rods
wrc head gasket
Had the car on a dyno pack yesterday . i had 499,7 in the engine and 450 at wheels
566 nw at 1,75 boost the dyno guy said if you give it 2 bar boost we can have about 550
