PassionFord
Go Back   PassionFord > Main area > Pictures, video & Photoshop Forum
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 04-04-2007, 11:53 PM   #1
frog
0-60 in 17 seconds (eek)
frog's Avatar
Trader Score: (0)
frog is an unknown quantity at this point
Default Photography 101 - Lesson one - Cameras and Lenses
Photography comes from the Greek words for light and writing. Essentially, writing with light.
The first thing we will discuss are the main parts of a camera, whether it be compact or SLR, film or digital.
Lenses
At the front of the camera is a lens, its responsiblity is to focus the light which comes from the subject being photographed onto the film or digital capture device (CCD) in a digital camera.
Generally made of glass, lenses can also be made of plastic in cheap cameras. The more expensive lenses are made of specially coated glass which improves the optical qualities of the lens, resulting in better picture quality.
The lens is also usually responsible for the focussing aspects of taking a photograph, in other words, it makes the light beams converge onto the film so that the recorded image is crisp.
There are three basic types of lenses; normal, wide angle and telephoto.
The lens's focal length determine the size of the image that will be recorded, a wide angle lens captures a wide angle of light and therefore is able to "fit" more onto the film, a telephoto lens on the other hand captures a narrow angle of light and therefore "fits" less on film.
If you think of the film as if it were your eyes, a telephoto lens would be the equivalent of using binoculars, you can see detail on things that are far away, but, they are no good for peripheral vision, which is what wide angle lenses are very good at.
Typically, a wide angle lens will have a focal lens which is less that 50mm, a normal lens will be 50 to 80mm, and a telephoto lens will be anything above 80mm (210mm for example).
Fixed focal lenses are just that, a lens which only has one focal length, whereas zoom lenses are able to cover a range of focal length, typical examples are: 28-80mm, 70-210mm, etc...
Zoom lenses are very practical since they cover a range which would otherwise require a number of lenses, which equates to weight and space savings in a camera bag. They also remove the need to change lenses when photographing different subjects.
Imagine that you are on a safari with some friends, and fit your 300mm fixed focal lens on your camera to take pictures of the wildlife, suddenly, someone near you pulls a face which you want to capture for posterity, you'd need to dig into your camera bag, pull out your 50mm lens, fit it onto the camera and take the picture, or, run 1/4 mile in the bush to be far away enough. Chances are that your friend will then have lost the expression, and the photo opportunity is gone.
A zoom lens on the other hand may have allowed you to take the picture by quickly zooming out.
Photography as you will see through the remainder of these articles, is a constant set of compromises you have to juggle, where whatever change you make will affect something else which will always affect the end result in one way or another.
In this instance, the compromise you would have made as a photographer would be to capture distant wildlife only, just like choosing to drive your Ferrari in the morning is a conscious decision that you will not be able to go off road unless you change the car.
There are drawbacks to zoom lenses however, because of their multipurpose, they are often a compromise in terms of quality, and a zoom lens which is equally as good as the three fixed focal lenses it replaces will usually cost significantly more.
Finally, the speed, or light-gathering power, of a lens is indicated by the f number, called the aperture.
The lower the f number, the faster the lens, that is, the more light it lets through. A fast lens has an aperture of at least f/2.8, the very best lenses can have apertures as low as f1 or even less.
We will go into more detail about the subject of aperture in later articles, however, for now, consider that a lens, however good it is, absorbs a certain amount of the light that's passing through it, the more it absorbs, the slower it is, conversely, the more transparent it is, the faster it is.
The reason for this is that the glass they are made of isn't 100% transparent to light, and within one lens, there may be several glass elements, all of which contribute to light losses.
Note that while fast lenses tend to be more expensive than their slow counterparts, a fast lens isn't necessarily a sign of good quality.
Often lenses are characterised by two numbers, for example, 50mm f/5.6, meaning the lens has a focal length of 50mm, and a maximum aperture of f5.6.
You may also see lenses with markings such as f/5.6-22 or f/5.6(22) meaning that the maximum aperture is f5.6, and the minimum aperture is f22.
Lastly, some zoom lenses will show markings such as f/4.5-5.6 which mean that at the lowest focal length, the lens' maximum aperture is f4.5, but at it's furthest zoom setting, the lens absorbs more light, therefore lowering the maximum aperture to f5.6.
Key thing to remember for now, is that when setting the lens aperture to f5.6, you are allowing more light to reach the internals of the camera than if you chose f22. It is completely counter-intuitive, since the larger numbers relate to less light, so best get used to it now
Image capture
Behind the lens is film or CCD (Charge Coupled Device) in digital cameras, this is what is sensitive to light in a camera, and records the image. An analogy for this would be the retina in your eyes. It receives light and turns it into an image.
Once exposed to light, the film or CCD records the light which it received and stores it chemically (in film), or, digitally for a CCD.
If the film or CCD receives too little light while it is exposed, the resulting image will appear dark, the photography term for such an image is under-exposed. If on the contrary it receives too much light, the resulting image will appear washed out, too bright, the term used here is over-exposed.
Just as your eyes have difficulty making things out in the dark, or, can't stand the brightness of the sun, film or CCD needs just the right amount of light to record a good picture. How this is done will be covered later.
Film is available in a number of sensitivities, known as ISO which express how much or how little light is required to correctly expose the film. CCDs in digital cameras replicate this by electronic means, again, we'll cover this in more detail later.
Viewfinder
The viewfinder is where you see what picture you are about to take. In an SLR, a mirror inside the camera is installed between the lens and the film, so that when looking through the viewfinder, you are looking at exactly what will appear on the photograph.
Non-SLR cameras on the other hand have a viewfinder which isn't 100% aligned with the lens.
When you press the shutter (the button that takes the picture), the mirror lifts and therefore exposes the CCD or film, resulting in an image being recorded. If you look carefully through the viewfinder in your SLR when you take a picture, you should notice that it goes black while the picture is taken, this shows that the mirror has lifted and closed the path of light through the lens to the viewfinder.
Non-SLR cameras use an optical viewfinder that was more or less aligned with the lens, sometimes resulting in framing errors, particularly on close objects due to a less than perfect alignment. More recently, digital compact cameras show the preview image on an LCD screen which shows what goes through the lens though.
In the next article, we will discuss exposure in more detail (http://www.passionford.com/forum/vie....php?p=3784722).
__________________
Any advice given is for you to take with a large pinch of salt.
Mike Rainbird for parts - MADevelopments for tuning - Opie Oils for, er, lubricants
frog is offline   Reply With Quote
Old 05-04-2007, 08:49 AM   #2
foreigneRS
Testing the future
foreigneRS's Avatar
Trader Score: (0)
foreigneRS is on a distinguished road
great start greg
thanks for a simple explanation of some of the things that i wanted to know. i look forward to reading further
__________________
Nick
It takes me less than 9 minutes
RP Lab L8 ECU
1998 Puma 1.7 / 2002 Galaxy 2.3 LPG / 2007 Honda VFR800 VTEC / 1972 Honda C90
foreigneRS is online now   Reply With Quote
Old 05-04-2007, 09:04 AM   #3
frog
frog's Avatar
Trader Score: (0)
Thank Nick
__________________
Old 05-04-2007, 09:58 AM   #4
Muska
Trader Score: (0)
Muska is an unknown quantity at this point
Send a message via MSN to Muska
Excellent start, looking forward to the next one already!
Matt.
Muska is offline   Reply With Quote
Old 05-04-2007, 10:15 AM   #5
Jasesapphy
Trader Score: (1)
Jasesapphy is an unknown quantity at this point
excellnt information, please do more of these theres a lot of new guys with good equipment coming on board
__________________
CO Owner of the GOOOOON, 300bhp/320ft lb @ 860kg, and YES ITS A MAESTRO
http://smg.photobucket.com/albums/v140/jasesapphy/?action=view&current=IMG_0084-1.jpg
Jasesapphy is offline   Reply With Quote
Old 05-04-2007, 05:15 PM   #6
frog
frog's Avatar
Trader Score: (0)
Some examples of lenses and markings
28-70mm zoom lens
Max aperture f2.8 throughout.
70-300 zoom lens
Max aperture f4.5 at 70mm, 5.6 at 300mm
17-35mm zoom lens
Max aperture f2.8 at 17mm, f4 at 35mm, min aperture f32 (in brackets)
35-80mm zoom lens
Max aperture f4 at 35mm, f5.6 at 80mm, min aperture f22 (in brackets)
__________________
Old 05-04-2007, 07:11 PM   #7
The Beard
Trader Score: (0)
The Beard is an unknown quantity at this point
Send a message via MSN to The Beard
sticky
__________________
pete
LEAVE MY SIG ALONE please
My first baby due SEPTEMBER.
The Beard is offline   Reply With Quote
Old 06-04-2007, 01:49 PM   #8
rstoughy
rstoughy's Avatar
Trader Score: (5)
rstoughy is an unknown quantity at this point
__________________
Paul.
No its not toughy Its pronounced tooghy
rstoughy is offline   Reply With Quote
Old 12-04-2007, 11:55 PM   #9
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Trader Score: (12)
Stu @ M Developments will become famous soon enoughStu @ M Developments will become famous soon enough
Exceptional information Greg. Thanks for your time.
Stu @ M Developments is online now   Reply With Quote
Old 17-04-2007, 09:14 PM   #10
danja
danja's Avatar
Trader Score: (0)
danja is an unknown quantity at this point
Well done! Top draw
__________________
danja is offline   Reply With Quote
Old 08-05-2007, 08:06 PM   #11
Trader Score: (12)
Moved to general discussion for peoples enjoyment Frog, these essays should be absorbed by as many people as possible after all your effort.
Old 08-05-2007, 08:42 PM   #12
Trader Score: (0)
Anonymous is an unknown quantity at this point
Anonymous is offline   Reply With Quote
Old 08-05-2007, 09:41 PM   #13
Trader Score: (12)
Anyone who enjoys these, can find further lessons from Frog stickied in this room...
http://www.passionford.com/forum/viewforum.php?f=12
Old 25-05-2007, 12:55 PM   #14
Trader Score: (12)
BTTT
Old 12-07-2007, 12:20 PM   #15
ballin
ballin's Avatar
Trader Score: (1)
ballin is an unknown quantity at this point
Didnt see this the first time round, good shit!
__________________
--- cheeRS, Rich
ballin is offline   Reply With Quote
Old 14-10-2008, 10:50 AM   #16
Red16
Trader Score: (0)
Red16 will become famous soon enough
Send a message via MSN to Red16
Thanks for going to the effort of composing this thread
But why is it not a sticky like the other 'photography 101' threads?
__________________
Mac Motorsports Worx ZX10r turbo engined kit car... build thread in the restorations, rebuild & projects section
PS3 username - SausageArm ....... My DSLR photo's - http://www.flickr.com/photos/30990332@N02/
Red16 is offline   Reply With Quote
Old 27-10-2008, 08:23 PM   #17
Dicko&Sarah
Trader Score: (3)
Dicko&Sarah is an unknown quantity at this point
thanks for this, no doubt ill be referring to it quite frequently until i master the art of lenses etc
__________________
scc/ian howell built,cr turbo's gt30,autronic sm4 management,rc750cc's
ap 6 pots,mapped by ma developments estimated 450+hp
Dicko&Sarah is offline   Reply With Quote
Old 28-10-2008, 09:44 PM   #18
Red16
Trader Score: (0)
Thanks again to Stu, for making this thread a sticky and moving it to this section
__________________
Old 13-11-2008, 08:03 AM   #19
Hamid
Trader Score: (0)
Hamid is on a distinguished road
thank you very very much mr. frog
great lesson ,i was looking for a long time
this is my fairst time in this fourm,
after i read your lesson i regestered specially to thank you frog
looking forword to the nixt lesson..
best regards..
Hamid..
Hamid is offline   Reply With Quote
Old 01-08-2009, 09:40 PM   #20
arbaba
Trader Score: (0)
arbaba is on a distinguished road
Thanks,that was a very good post.
__________________
wedding rings
suzanne gudakunst
arbaba is offline   Reply With Quote
Old 16-12-2009, 01:03 PM   #21
montyhar2
Trader Score: (0)
montyhar2 is on a distinguished road
Nice Information. Thank you very much Frog. It is very helpful to me after i read your lesson i registered specially to thank you frog.
best regards.
__________________
r4i칩
montyhar2 is offline   Reply With Quote
Old 13-01-2010, 11:44 PM   #22
housefull
Trader Score: (0)
housefull is on a distinguished road
I accept with information:Imagine that you are on a safari with some friends, and fit your 300mm fixed focal lens on your camera to take pictures of the wildlife, suddenly, someone near you pulls a face which you want to capture for posterity, you'd need to dig into your camera bag, pull out your 50mm lens, fit it onto the camera and take the picture, or, run 1/4 mile in the bush to be far away enough. Chances are that your friend will then have lost the expression, and the photo opportunity is gone.
__________________
Daybreakers Movie Online Free
housefull is offline   Reply With Quote
Old 17-04-2010, 11:11 AM   #23
worthmiller
Trader Score: (0)
worthmiller is on a distinguished road
Quote:
Originally Posted by The Beard View Post
sticky
ya so amazing
__________________
Koozies can coolers
worthmiller is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
