PassionFord
Go Back   PassionFord > Main area > Pictures, video & Photoshop Forum
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 12-07-2006, 08:27 AM   #1
CosRush
Trader Score: (0)
CosRush is an unknown quantity at this point
Default Tutorial - Car Colour Change (UPDATED)
Having done this many many times for users of PF I thought i'd make a quick tutorial to allow people to experiment themselves with colour changes.
This is by no means the complete way to do it, there are several ways depending on the original bodywork colour and the colour to be changed to. for example changing black to anything else is difficult to get right and as such uses different methods.
I have now added a second tutorial showing another way to achieve this colour change.
This tutorial will however work for most cars. It does not show every single step but most of them. If anybody wishes to know more about any part of it, feel free to PM or Email.
Method 1
Step 1.
Start with a picture.
step 2
Right click on that layer and select duplicate layer (or press control and J)
step 3
Then select polygonal lasso and do a rough outline of the car only, but dont get too close to it. This will save some later in a later step.
step 4
Once you have done this goto, Image/adjustments/hue & saturation.
Click on Colourize. you can then alter that layer's colour using the Hue and saturation sliders.
When you have decided on a colour select OK.
step 5
This is what you should be left with
step 6
Now using the eraser, and using the zoom function remove all the outer section of colour that have gone beyond the bodywork.
Also remember to do the windows, lights, petrol caps,wing mirrors and trim etc etc.
step 7
you should then end up with this.
step 8
Then by returning to the hue & saturation option and selecting colourize again, you can now change the car neatly.
You may notice that the blue of the handles, petrol cap window seal etc comes through, this is not a problem. You can either chose not to erase it when carrying out step 6, or otherwise you can creat another layer and reduce saturation to 0, this will make them look dark grey.
Method 2
Open the picture you wish to use.
Duplicate the layer to work on.
Goto Image/adjustments/replace colour
Move your mouse to the +icon (add to sample)
Click on it
Now you should get a wand, drag this over the bodywork of the car only on the coloured section in this case RED, avoid any of the other colours nearby such as black doorhandles, door creases etc.
Then when you've finished (dont worry about doing too much as you can add some more if you haven't done enough) goto the HUE slider and slide it either way and you will see all the red you highlighted change colour.
If some RED parts have not changed just go back over them with the wand and you should see them change again.
Here you can see how the colour change function alos changes the colours of all things RED in and around the image, in this case trees branched etc with red in them have also changed colour.
You can then just delete them either by highlighting them and selecting delete of using the eraser.
Once done you should have something like this
Note:
You may sometimes need to adjust the Fuzziness to get a clear colour change.
You are not limited to the HUE slider alone, you can also DESATURATE to create Greys and also use the Brightness slider to get anywhere from Black upto White.
I hope you find this helpful.
CosRush is offline   Reply With Quote
Old 27-02-2007, 11:32 AM   #2
kenny_ka
Trader Score: (0)
kenny_ka is an unknown quantity at this point
Default ...
is there an easier way of gettin rid of all the colour round the edges, windoes, lights, fuel caps, wheel etc....
i havnt got a steady enuff hand with the rubber
kenny_ka is offline   Reply With Quote
Old 27-02-2007, 11:44 AM   #3
CosRush
Trader Score: (0)
Yes you could use the Polygonal lasso tool. Just trace the area and then select delete.
For example:
A car window -
Trace around the glass only with the lasso tool, then select delete will remove the added colour layer provided you have that layer highlighted.
you can also lasso around the whole car bodywork (remember you can use the Shift Key + to add more selections before deleting), once selected seletc Inverse which switches the highlighted arear to everything outside of what you highlighted, then use the delete key also.
This works if you create a new layer in a different colour, then using the above the whole of the bqackground is then removed.
The main thing to note is that the way I have shown you above is one way of doing it, it really depends if you are doing it for a living or just to see how something else looks (wheel/bodywork etc).
To be done very well takes some time.
The easiest way is perhaps to use the colour change option.
Just highlight the bodywork for example with the +wand then goto the hue settings and move the slider, you may or may not need to add or subtract some of the colours depending on the result you see. this is a little bit more complex to get right as it depends on the whole picture i.e. the same colours in the background will change too.
Hope that helps.
***Edited***
I may do a tutorial when I get a chance of the Colour Change option.
Old 27-02-2007, 09:42 PM   #4
donny murdo
Trader Score: (0)
donny murdo is an unknown quantity at this point
An excellent tutorial good advice mate, allways helping I have asked you about things a few times and you reply with a helpful answer, you are a diamond thanks
__________________
How do you like them apples?
donny murdo is offline   Reply With Quote
Old 28-02-2007, 12:22 PM   #5
CosRush
Trader Score: (0)
Quote:
Thanks Donny Nice to see my work is appreciated
You'll see ive updated the above.
Old 01-03-2007, 11:11 AM   #6
kenny_ka
Trader Score: (0)
Default ..
nice one cheers mate
Old 01-03-2007, 03:53 PM   #7
Sukhy RS
LFC
Sukhy RS's Avatar
Trader Score: (0)
Sukhy RS is an unknown quantity at this point
Send a message via MSN to Sukhy RS
Nice one Cosrush
__________________
***** Liverpool FC *****
***** Y.N.W.A *****
Sukhy RS is offline   Reply With Quote
Old 26-03-2007, 03:00 PM   #8
Zetec_mk4_XR3i
Trader Score: (0)
Zetec_mk4_XR3i is an unknown quantity at this point
Brilliant guide that
__________________
my mk4 Escort Bonus, ST170 + throttle bodies in OAP gold
193 bhp & 13.7 1/4 mile at 102mph
http://passionford.com/forum/picture...16v-bonus.html
Zetec_mk4_XR3i is offline   Reply With Quote
Old 26-04-2007, 12:18 AM   #9
EIL132
Trader Score: (0)
EIL132 will become famous soon enough
__________________
James
EIL132 is offline   Reply With Quote
Old 02-05-2008, 03:28 PM   #10
Cadetsharp
Trader Score: (0)
Cadetsharp is on a distinguished road
What about cleaning up rust spots and primer? Is there non-tedious way to do that?
Cadetsharp is offline   Reply With Quote
Old 09-09-2009, 10:29 AM   #11
johnswhite
Trader Score: (0)
johnswhite is on a distinguished road
Hi...
Thanks alot for providing all information.. The Methods which you share with all just to good... I am looking for always this type of innovative work.... Thanks for sharing the post...
johnswhite is offline   Reply With Quote
Old 19-02-2010, 07:20 AM   #12
jimmie298
Trader Score: (0)
jimmie298 is on a distinguished road
Changing of car colors increases the looks of the car.
___________________
skate shoes
Vans Shoes
jimmie298 is offline   Reply With Quote
Old 22-04-2010, 12:15 AM   #13
CoupeUK
Trader Score: (0)
CoupeUK has a spectacular aura aboutCoupeUK has a spectacular aura about
Quote:
Originally Posted by shen261987 View Post
An STD is a serious illness that requires treatment. An STD like AIDS, cannot be cured and are deadly. If you are looking for an effective STD Testing or STD HIV testing you can call us at 888-338-9831. or visit our site http://getstdtestedhere.com/fm-2/
WTF??
__________________
<<<<Signature Removed>>>> PassionFord moderation at its best....
CoupeUK is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
