PassionFord
Go Back   PassionFord > Main area > Pictures, video & Photoshop Forum
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 14-03-2006, 10:50 PM   #1
RS-Leigh
RS-Leigh's Avatar
Trader Score: (2)
RS-Leigh is an unknown quantity at this point
Send a message via MSN to RS-Leigh
Default Tutorial - How to make a Sig
As lots of people request for sigs to be made, and people want to learn how do do them.
I spoke to Adrian (section Mod) and offered to write a sig tutorial to show people how to make them, and more importantly make them to the proper size which is 550 x 150 at a maximum of 25k.
Before we start. I don’t claim to be an expert and there are methods which people will disagree with, but this a basic intro to making a sig. So no abuse please. If you have any info or tips then please add to the thread.
I will give you a step by step guide to making this sig using Photoshop 7.
Open up Photoshop and select the following windows.
WINDOW
TOOLS,
OPTIONS,
STYLES,
LAYERS,
STATUS BAR
These are all you will need to start off with.
Now we need to create a new blank canvas to make our sig.
FILE
NEW
Select the following sizes, 1000 by 300, with around 70 pixel/cm (yes this is to big but it will all become clear later.
Now open the images you want to use.
FILE
OPEN
You should have the screen like above, note the layer window at the bottom right. This layer has a padlock symbol beside it. This means we can’t adjust it so we have to make a copy. Right click on the layer and select ‘Duplicate Layer’. You can give it a name if you want to.
Open the rest of the images you want to use and duplicate them all.
So now I have 3 images I want to use to create the sig, and I have duplicated all of them.
Note – Each image has a separate layer pallet, by clicking on the selected image you will see that the layer window changes to show the layers of that individual image.
Now to start creating the sig.
Minimise your images so that you only have the new blank on the screen. Once you have worked out what you want for the background colour select the ‘Fill Tool’
Using the styles pallet you can find the correct pattern/ colour you want.
I have chosen an orange/yellow background.
Now I want to transfer my engine image onto the new sig.
Bring up your image, make sure you have the duplicate layer highlighted,
Now left click and hold the layer box in the ‘Layer Window’ and drag the box onto the new sig. The image will now be inside the sig, and note that you have created a new layer automatically in the new sig ‘Layer Window’.
Basically you are creating a wedding cake effect with it made up of lots of individual layers. We can select each layer and change as we see fit. So if you are not happy with your background colour choice, you can select that layer and change it without having any effect on the other layers. You can also delete a layer at any time by right clicking on the layer box in the ‘Layer Window’ and selecting delete.
You can also select
EDIT
UNDO
Or
EDIT
STEP BACKWORD
at any time if you make a mistake.
Now minimise the original image so all you have is the new sig.
Press Ctrl and T at the same time and you will get a box around the picture like this. Easier to maximise the new sig before you do this.
You can now adjust the image size and place it wherever you want on the new sig. Also by holding the CTRL button you can adjust the ‘skew’ of the image.
Below I have stretched the image to fill the box and then reduced the opacity in the ‘Layer Window’ to create this effect.
Now minimise the new sig and bring up your next picture to adjust.
I want to cut this image out before transferring it to the new sig.
Select the ‘Polygonal Lasso’ tool from the ‘Tool Window’, now carefully go round your image until you join the start and end points up. Dashed line should now flash. If you make a mistake at any time hit the Esc button and start again.
I also want to get rid of a piece of the road from under the car so you hold the Alt button as you trace round this shape.
You should end up with something like this.
Select the ‘Move’ Tool and drag this layer onto the new sig and adjust as before for size and position.
Carry out the same principles for the rest of your pictures.
Now we add some text.
Select the ‘Text Tool’ in the ‘Tool Window’, position the curser where you want to start the text. Adjust the size, colour and font as you would normally using the top toolbar. Select the ‘Move Tool’ in the ‘Tool Window’ so you can now move the text wherever you want.
You will have to select the ‘Text Tool’ and highlight the text if you want to change size and font etc.
Now for the text effects.
Select-LAYER, LAYER STYLE, then choose an option. I have chosen Bevel and Emboss. Now have a play and adjust as you see fit.
Well done, you have created a sig.
Nearly finished.
We now have to merge all the layers together to create one picture. At the moment we have lots of different pictures on top of each other.
Select
LAYER
FLATTEN IMAGE
Note that you now only have one layer in your ‘Layer Window’
Next we have to save the file. Usual steps
FILE
SAVE AS
Make sure you save the picture as a JPEG.
You now get this window
By moving the bar from Low to High you will adjust the size and quality of the file. Select around 35k-40k at 56.6kps in the size window.
Now if we look at the image in My Pictures you can see that the file is too big. 50k to be exact and still 1000 x 300 pixels in size.
Download the following Pixel Resizer Program –
http://bluefive.pair.com/pixresizer.htm
Open up the Pixresizer program and load your sig. Now select the reduction box to 50% and save the new smaller sig. Sig is now 500 x 150, remember original was 1000 x 300, you have now reduced the size of the file but still kept decent quality. This is the whole point of doing it this way. If you select 500 x 150 originally in Photoshop, when you save and reduce quality, the sig can look very poor. This way you keep more quality.
I had to reduce the file even more using the custom selection. Sig is now 480 x 144 pixels and is 25k in size.
Job done.
There are lots more things that can be done with Photoshop, this is just the tip of the ice-berg, just take your time and have a play.
Like I said at the start, this is a basic sig to show you all where to start and hopefully demonstrate that it is easy stuff. Remember and just adjust each layer at a time and build the sig up to what you want.
If you have any other useful tips then please add to the topic.
Enjoy
Leigh
__________________
Hampshire RS Owners Group Chairman
RS-Leigh is offline   Reply With Quote
Old 14-03-2006, 10:58 PM   #2
Adrian
Super Moderator
Trader Score: (0)
Adrian is an unknown quantity at this point
Send a message via MSN to Adrian
Many Many thanks for the time and effort Leigh has taken to put this tutorial together.
__________________
http://www.7thnote.co.uk/
360 : AdeBarbs69 PS3 : AdeBarbs69
Feel free to add.
Adrian is online now   Reply With Quote
Old 14-03-2006, 11:05 PM   #3
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Trader Score: (12)
Stu @ M Developments will become famous soon enoughStu @ M Developments will become famous soon enough
Fantastic effort pal
Stu @ M Developments is offline   Reply With Quote
Old 14-03-2006, 11:42 PM   #4
RS-Leigh
RS-Leigh's Avatar
Trader Score: (2)
Thanks
Lets just hope people use it!!
Leigh
Old 15-03-2006, 06:50 AM   #5
Bouncing Cougar
Trader Score: (0)
Bouncing Cougar is an unknown quantity at this point
WOW !!
Thank you so much Leigh
Ive had Photo Shop for over a year now but never really knew how to use it The best I could do was my Sig below
Ive just followed your 'How To' & made this...
It's only my first attempt but I'm really pleased with it
Top marks Leigh for an excellent 'How To' I found it really easy to follow
__________________
Bouncing Cougar is offline   Reply With Quote
Old 15-03-2006, 07:03 AM   #6
GazzaG
GazzaG's Avatar
Trader Score: (0)
GazzaG is an unknown quantity at this point
nice bit of work there fella
Bouncing Cougar
thats not bad for a starter keep having a fiddle and you will get better
__________________
2003 Focus is here
GazzaG is offline   Reply With Quote
Old 15-03-2006, 07:30 AM   #7
Bouncing Cougar
Trader Score: (0)
Quote:
Bouncing Cougar
Cheers Gaz
Ive had another 'fiddle' & made this for my mate.....
I'll be at it all day now
Maz
__________________
Old 15-03-2006, 07:49 AM   #8
RS-Leigh
RS-Leigh's Avatar
Trader Score: (2)
Quote:
Originally Posted by Bouncing Cougar
WOW !!
Thanks mate, glad you found it useful. Its all easy stuff
Leigh
Old 15-03-2006, 03:11 PM   #9
Phil (",)
Trader Score: (0)
Phil (",) is an unknown quantity at this point
Send a message via MSN to Phil (",)
Just tryed one myself not the best but ay. its only me first time thanks for the tutorial
__________________
Phil (",) is offline   Reply With Quote
Old 15-03-2006, 05:20 PM   #10
Eagle
Super Moderator
Trader Score: (2)
Eagle is an unknown quantity at this point
Send a message via MSN to Eagle
blooody excelent mate
many thanks for this .. have inccluded it in the pm's i send out
__________________
UB40 NEWS
http://www.ub40.co.uk/news.php
Eagle is online now   Reply With Quote
Old 16-03-2006, 09:14 PM   #11
Doug
Trader Score: (0)
Doug is an unknown quantity at this point
Fantastic
OOOOOOOOH and me car is famous lol
__________________
Doug is offline   Reply With Quote
Old 16-03-2006, 10:06 PM   #12
James-W
Trader Score: (0)
James-W is an unknown quantity at this point
Thanks cool guide Leigh and thanks for doing my sig.
James-W is offline   Reply With Quote
Old 24-04-2006, 05:44 PM   #13
BM
Trader Score: (0)
BM is an unknown quantity at this point
Excellent Tutorial mate
Alot of time/effort
BM is offline   Reply With Quote
Old 25-04-2006, 02:44 PM   #14
s2_rsturbo
Trader Score: (0)
s2_rsturbo is an unknown quantity at this point
I've been looking for a thread like this for ages!! thanks mods
__________________
s2_rsturbo is offline   Reply With Quote
Old 30-04-2006, 09:21 PM   #15
24vmk3
24vmk3's Avatar
Trader Score: (0)
24vmk3 is an unknown quantity at this point
this is great!!!!!!!!!!
never could work photoshop I havnt tried it yet but I think i will have to reload it
thanks
your a star
24vmk3 is offline   Reply With Quote
Old 01-05-2006, 04:32 PM   #16
righthooker
Trader Score: (0)
righthooker is an unknown quantity at this point
good tutorial...just made this one for my dad
__________________
http://www.clevelandrsoc.com/
righthooker is offline   Reply With Quote
Old 19-05-2006, 01:03 AM   #17
rst_cabby
Trader Score: (0)
rst_cabby is an unknown quantity at this point
Send a message via MSN to rst_cabby
My first attempt - Good instructions - Top
rst_cabby is offline   Reply With Quote
Old 02-06-2006, 06:42 PM   #18
jaimesdna
jaimesdna's Avatar
Trader Score: (3)
jaimesdna is an unknown quantity at this point
good thread . been wanting to do one for ages but didnt know how . here's my first atempt
jaimesdna is offline   Reply With Quote
Old 14-06-2006, 04:10 PM   #19
COSSIE CAL
Trader Score: (0)
COSSIE CAL is an unknown quantity at this point
Send a message via ICQ to COSSIE CAL Send a message via MSN to COSSIE CAL
damn went through it all and found out i have 8 something!! need one!!
__________________
the futures right...
your backends sideways...
COSSIE CAL is offline   Reply With Quote
Old 18-06-2006, 01:11 AM   #20
ford-driver
Trader Score: (0)
ford-driver is an unknown quantity at this point
Hey, do ya recon it would be very similar steps with adobe photoshop 8 ? Thanks
ford-driver is offline   Reply With Quote
Old 18-06-2006, 10:28 AM   #21
RS-Leigh
RS-Leigh's Avatar
Trader Score: (2)
Quote:
Don't know mate, but it cannot be that much different, just follow the same principles and see how you go.
Leigh
__________________
Old 18-06-2006, 12:17 PM   #22
DaveAVT
Trader Score: (0)
DaveAVT is an unknown quantity at this point
Why dont you just use Photoshop to resize?
__________________
http://www.kwik-fit.com/
DaveAVT is offline   Reply With Quote
Old 18-06-2006, 08:35 PM   #23
RS-Leigh
RS-Leigh's Avatar
Trader Score: (2)
Quote:
Yes mate you can do it that way, this was the way that I was shown, as your picture quality remains better, but you can use the 'save to web' function in Photoshop (which i discovered after writing the tutorial)
As I stated at the start of the tutorial, people do sigs in different ways, some use Paint Shop Pro and some use Microsoft Paint. each to ther own and all that. I also mentioned that if anyone had any tips or tricks then to post them up on the tutorial then we can all learn new ways.
Leigh
__________________
Old 17-07-2006, 06:42 PM   #24
vfj
Trader Score: (0)
vfj is an unknown quantity at this point
Thanks mate
vfj is offline   Reply With Quote
Old 24-11-2006, 07:55 PM   #25
jason_nike
jason_nike's Avatar
Trader Score: (0)
jason_nike is an unknown quantity at this point
What a fantastic tutorial.
When I get photoshop I`m gonna use this and have a go
jason_nike is offline   Reply With Quote
Old 27-11-2006, 04:45 PM   #26
COSSIE CAL
Trader Score: (0)
how do you resize?is it 1000 by 300?
__________________
Old 27-11-2006, 04:53 PM   #27
RS-Leigh
RS-Leigh's Avatar
Trader Score: (2)
either use the pix resizer program in the first post, or select IMAGE, IMAGE RESIZE in Photoshop.
resize to 550x150 but less than 25k in size when you save it.
Leigh
__________________
Old 28-11-2006, 01:56 AM   #28
Posty-ST
Posty-ST's Avatar
Trader Score: (0)
Posty-ST is an unknown quantity at this point
Send a message via MSN to Posty-ST Send a message via Yahoo to Posty-ST
Quote:
Originally Posted by RS-Leigh
Thanks
Leigh
I would if I had photoshop lol
__________________
Posty-ST is offline   Reply With Quote
Old 09-01-2007, 01:06 AM   #29
Diamonds.
Trader Score: (2)
Diamonds. is on a distinguished road
thats a great lesson always had photoshop but never tried to make a sig and you made it so easy cheers mate
Diamonds. is offline   Reply With Quote
Old 12-04-2007, 08:59 AM   #30
rs1600cab
Trader Score: (0)
rs1600cab is an unknown quantity at this point
hi sorry im the first to ask this wil photo 9 do the same i cant get it to work ?
rs1600cab is offline   Reply With Quote
Old 14-04-2007, 07:14 AM   #31
gwagner00
Trader Score: (0)
gwagner00 is an unknown quantity at this point
Thanks for this helpful tutorial! I hope I can create one..
gwagner00 is offline   Reply With Quote
Old 18-07-2007, 12:46 PM   #32
Sanchez_
Super Moderator
Sanchez_'s Avatar
Trader Score: (3)
Sanchez_ is on a distinguished road
THERE ARE ENOUGH SAD TWATS ON THERE WITHOUT ME LOL
Send a message via MSN to Sanchez_
cheers leigh spot on tutorial
__________________
Sanchez_ is offline   Reply With Quote
Old 24-08-2007, 07:51 PM   #33
hawko
hawko's Avatar
Trader Score: (0)
hawko is an unknown quantity at this point
allways wondered how i got one now i know thanks ,very well put together
hawko is offline   Reply With Quote
Old 22-11-2007, 10:55 PM   #34
yellowsierra
yellowsierra's Avatar
Trader Score: (0)
yellowsierra is an unknown quantity at this point
all i need now is photoshop 7
Anyone got a link to it
Regards
Ian
__________________
yellowsierra is offline   Reply With Quote
Old 10-12-2007, 08:03 PM   #35
PastyKing
PastyKing's Avatar
Trader Score: (0)
PastyKing is an unknown quantity at this point
RS-Leigh
im following your instructions and im struggling with the image im dragging in being too big? as you can see its too big and i cant get the full picture within the box can anyone help please?
PastyKing is offline   Reply With Quote
Old 10-12-2007, 10:57 PM   #36
PastyKing
PastyKing's Avatar
Trader Score: (0)
cancel that above,
ive sussed it out ctrl + t does the trick
great thread im still pretty crap at sigs but ill keep practising
Old 17-02-2008, 11:20 PM   #37
rsdan123
rsdan123's Avatar
Trader Score: (3)
rsdan123 is an unknown quantity at this point
MANIC321
nice work cheeRS for your time! just need to find photoshop 7.... as above if any one knows free download link please can you post
__________________
Cheers, Danny
rsdan123 is offline   Reply With Quote
Old 19-02-2008, 05:29 PM   #38
rsdan123
rsdan123's Avatar
Trader Score: (3)
MANIC321
found photoshop 7 for free on winMX with the password key
__________________
Cheers, Danny
Old 04-03-2008, 04:50 PM   #39
ANDY1711
ANDY1711's Avatar
Trader Score: (0)
ANDY1711 is an unknown quantity at this point
i have 2 problems 1 is it wont let me put in 70 pixels/cm it keep changing to 30
2 is when you drag the duplicate image over to the sig it doesnt go in to it just sits on top help me please it driving me nuts
__________________
ANDY1711 is offline   Reply With Quote
Old 04-03-2008, 06:56 PM   #40
ANDY1711
ANDY1711's Avatar
Trader Score: (0)
its o.k. i got it this is great one i did for starters will mess about and make some more thanks for this
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
