| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| PassionFord Swap Shop. Post all your swaps in here. Starting a topic requires you to have purchased a gold membership. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
#2 |
hey mate good to see the van done looks nice how much did yer spend in the end also long shot u got any alloys for a fes to sell mate cheeRS
#3 |
Hello mate. didnt really spend to much tbh. Sold alot of stuff off the van and car which paid for alot of stuff. Main payout was the paint shop. The only other wheels I have I need refurb.
__________________
#4 |
You still after a CTS box mate ??
#5 |
Build a box yourself mate, ive done quite a few using the bigger type mainshaft bearing etc which is still available to buy, then just clean and fit a lsd pretty much a stage 1 cts box, i had two of these home built boxes in my fwd cossie powered rst which held up fine so depending on your power ?
__________________
#6 |
Oh really what spec bearing and where from?
__________________
#7 |
Its the same INA bearing cts use, you just have the casing machined and have it pressed in, the bearing comes with a sleeve so if your mainshaft is a little worn the sleeve just taps over then end to make it good again but check to make sure the shaft isnt completely useless or you will have issues, obviously always best to start with a good 2nd hand box that drives ok and go from there. A few pics of one that i built, ![]() ![]() ![]()
__________________
#8 |
satan's little helper
coswurv where u get the bearing from and how much?
__________________
![]() IF IT'S NOT A FORD IT'S NOT WORTH HAVING black series 2 f770 bjl daily runner / sold! black 3 door cosworth 4x4 d654 cla full restoration soon black series 2 h659 kar project bufty / collecting parts
#9 |
Sweet for info mate
As above.
__________________
#10 |
I'll double check but i think off hand it was about £50 for the bearing, any good bearing supplier can get this for you, machining was about the same and then just your gaskets and oil seals, oil. i done it for about £100 and on there website the box's start from £540 so defo worth a go.
__________________
| Display Modes | |
