Other Marques Use this section for any non Ford marques.
heater problem -anyone got any ideas please?
Old 30-01-2006, 09:33 PM
MATCOS
MATCOS's Avatar
Default heater problem -anyone got any ideas please?
My other halfs 1999 Puma has a problem, well technically it's 2 problems but they may be related
When you squirt the windscreen washers it sounds like they are empty and only a little bit of water comes out (it is full and it is not frozen!)
The second part is the heaters/aircon, when you drive under 40mph ish the heater and aircon work fine but when driving for a while or if you speed above 40mph the temperature is constantly hot and not cold
Has anyone had a similair problem or have any suggestions please.
Many thanks
Old 30-01-2006, 10:29 PM
scott-cos
scott-cos's Avatar
sounds like the filter on the pump is blocked. you need to remove the washer pump and the filter. clean it out and re-fit and try it.
not to sure about your other problem though.
scott
Old 30-01-2006, 11:23 PM
steve211
steve211's Avatar
could be your heater valve causing probs with temps......know problem on pumas and fiestas and had mine replaced for similar problems when i had mine
Old 31-01-2006, 05:29 PM
MATCOS
MATCOS's Avatar
Cheers lads
Old 25-02-2006, 02:51 PM
big-dirty-dog
big-dirty-dog's Avatar
my escos had the same problem with the washer jets pulled the hose off the pump,tested,shot out water thick and fast washer jets were unblocked,had a blockage in the supply pipe to the jets blew out blockage with airline,probley the same
Old 25-02-2006, 03:11 PM
MATCOS
MATCOS's Avatar
Rsmat
63
25-09-2015 12:11 PM
RSBryden
06-09-2015 08:39 PM
ST-170
04-09-2015 11:02 AM
Ben26
03-09-2015 07:55 PM
Quick Reply: heater problem -anyone got any ideas please?
