Other Marques Use this section for any non Ford marques.
slow xr3i
Old 29-08-2005, 02:18 AM
jason len
jason len's Avatar
Default slow xr3i
think its time a rebild soon as my car seems very very slow, struggles to get up hills most times, its a 1.8 16v 130 model so should have some poke
trouble is im curious to either rebuild or go for somethink alot quicker engine wize,
what you guys think?
Old 29-08-2005, 09:19 AM
Paddy
Legend
Paddy's Avatar
For the price of a second hand engine, you might as well stick the 2.0 litre lump in it
Old 29-08-2005, 02:38 PM
jason len
jason len's Avatar
well i know a guy who has a Ford 1.9 Zetec Engine Block and Pistons,
the block is 1.9 with forge piston, the conrod are design with floating gudgen pins, what ever that means , and there is no piston ring and you will need a new of mains and big end bearing, does this sound ok? also are the prices on new piston rings expensive?????
thanks
Old 30-08-2005, 03:40 PM
jason len
jason len's Avatar
ok guys need some advice here,
after phoning around asking mates mates etc,
i have 2 choices, which would u say is the best to go for guys for turboing my zetec,
option 1:
the pistons need new rings and it also needs a new mains and big end bearing.
option 2:
2 litre zetec bottom end, complete with 1.8 sump,
set of used mahle forged pistons from a vauxhall xe, apparently told they will make it low comp, however i was told needs will need reboring to suit to give around 2050cc.
what do u think guys is best option?
thanks
Old 02-09-2005, 02:55 PM
mart.rs
mart.rs's Avatar
didnt know they made a 1.9 zetec(or do you mean 1856cc,1.8) personally id go for the 2.0 ditch the injection and stick it on throttle bodys,add some uprated cams,a nice 4-2-1 manifold and system and a decent management and chip and bobs ya uncle you should be knocking on the door of 180bhp plus! and the 2.0 has more grunt!!!
Old 10-09-2005, 12:15 AM
Paul_RS
Paul_RS's Avatar
option 2:
thanks
You don't want to go low comp with an NA engine!!
Old 11-09-2005, 08:23 AM
Paddy
Legend
Paddy's Avatar
As RS nutter said, the low compression engine will be best suited to turbocharging so unless you're going that route, don't bother with it
07-10-2015 12:56 PM
stephenb4506
33
02-10-2015 06:25 PM
A.t.p
29-09-2015 05:04 PM
morg65
Escort MK 5 / MK 6
23-09-2015 08:57 PM
Quick Reply: slow xr3i
