Other Marques Use this section for any non Ford marques.
Fidansa Flywheel St220
Old 22-09-2016, 10:55 AM
robbo9006
robbo9006's Avatar
Default Fidansa Flywheel St220
Hello all
My engine give on my st220 due to a dodgy radiater hose.
As I changed it I am putting in a fidansa flywheel.
Ok the fidansa as well documented is for the st24 2.5.
This is the correct part.
THEN it says use a st24 slave cylinder.
This I id but whats the trick .
The locating holes are orientated different.
The clutch is ment to fit.
Question is please point me in the direction of someone that has done it.
What is the magic in the slave wheel,
Do I swap the slave bit of the st24 onto the mm7# gearbox.
I'm stuck and need my car finishing.
20/20 vision
23-09-2016 09:50 PM
mad max
29-08-2016 05:45 AM
Blades Rally Team
26-08-2016 07:26 AM
25-08-2016 07:43 PM
waynetdci33
25-08-2016 06:50 PM
Quick Reply: Fidansa Flywheel St220
