Other Marques Use this section for any non Ford marques.
Mondeo 4x4 ABS sensor
Old 13-08-2015, 07:47 PM
rdvil
rdvil's Avatar
Default Mondeo 4x4 ABS sensor
Hi,
anyone struggled with the same problem? Rear sensor is busted in a 1995 4x4, and they've been NLA from Ford for at least a decade now. Any way to fit another sensor in the originals place, or anything else along the lines of making the system work?
I don't even know what matters in a sensor, apart from physical size, air gap and resistance...
Of course the TCS & ABS lights can be "fixed", but I'd really like to fix the system instead.
Old 13-08-2015, 08:24 PM
st220kyle
st220kyle's Avatar
How similar is the 4x4 jag stuff, have you looked into that? Otherwise a breakers might be your only choice if you cant buy new anymore
Old 14-08-2015, 04:08 PM
rdvil
rdvil's Avatar
Jag's pretty different as far as I can tell, resembles a mk3 wagons rear suspension instead of the multilink in mk1 hatch. Hub carrier is so different it would be a surprise for the sensor to be even close...have to check though. 4x4 mondy woulda been difficult to find in the breakers 10 years ago, impossible today
If a mod feels so inclined, this could be moved to the mondeo section...didn't see that on the mobile.
Old 15-08-2015, 07:05 AM
cozzzzy power
cozzzzy power's Avatar
whats the finis code pal
Old 15-08-2015, 11:48 AM
rdvil
rdvil's Avatar
that would be 7045375
Old 15-08-2015, 11:57 AM
cozzzzy power
theres one in germany
rdvil (15-08-2015)
Old 15-08-2015, 12:06 PM
rdvil
rdvil's Avatar
if it's in the ford system my mate shoulda found it...I'll go have a chat on monday with him again. Thanks for the info! Could you pm the dealer for me too?
Old 15-08-2015, 12:11 PM
cozzzzy power
you have pm pal
rdvil (15-08-2015)
DixieTheKid
11
06-06-2020 11:20 AM
mike elsome
14-09-2015 04:08 PM
tib2220
14-09-2015 12:33 PM
Si B
12-09-2015 06:49 AM
mike elsome
Ford Range
09-09-2015 05:05 PM
Quick Reply: Mondeo 4x4 ABS sensor
