Other Marques Use this section for any non Ford marques.
Long pedal travel after new front pads?
Old 24-02-2015, 11:08 PM
Cardie
Cardie's Avatar
Default Long pedal travel after new front pads?
Ive done a set of front pads on a 2010 Honda accord Estate, the fronts and backs were heavily warn but I only got given the fronts to do.
Did the pads in the usual way as I have always done but the owner is complaning of lots of travel? Ive tried it myself and the brakes are very good but they do feel a bit different than before, could it be because the rears are warn badly and the fronts are new or would that not make a difference?
The pedal before the pads were done was very very sensitive, now it just feels like a normal pedal to me.
No warning lights on the dash or out and the fluid level is on MAX.
Thanks.
Old 25-02-2015, 12:09 AM
botters
competant bodger
botters's Avatar
did you bed them in properly on road test
Old 27-02-2015, 03:02 AM
Neilfi
Neilfi's Avatar
If the pads were down to the metal (it's possible!) then new ones would seem soft, or if the discs are worn unevenly, then the pads will need time to ware down into the grooves.
Old 27-02-2015, 09:13 AM
YOREVOL
YOREVOL
YOREVOL's Avatar
check for any "pips" on the pad backing.
i did a rexton 4x4 front pads and the owner complained of long pedal travel. tried bleeding etc. eventually found that the calliper was flexing on a "pip" on the pad backing. must have been for a different car, but the shape was exactly the same.
Old 27-02-2015, 12:22 PM
RichieST
RichieST's Avatar
If the discs are warped it can knock the pads back in the carrier resulting in a longer pedal travel. Just sounds like they need time to bed in though.
james kiely
28-08-2015 08:58 PM
Toe Knee
23-08-2015 08:31 AM
C2 MAK
20-08-2015 09:46 PM
track.focus'd
12-08-2015 05:53 PM
Billy_RS
03-08-2015 08:43 PM
Quick Reply: Long pedal travel after new front pads?
