Other Marques Use this section for any non Ford marques.
Subaru 2.35 Type R
Old 11-07-2012, 06:55 AM
banny786
banny786's Avatar
Default Subaru 2.35 Type R
Scoobyclinic billet GT35R
Cosworth manifold designed for drive by wire throttle
True bolt on conversion for a wire throttle with plenty of bonnet clearence
Rad fans fitted
Cossie manifold setup finished
Final adaptor version to accomodate the ICV
Throttle cable mount
Inlet manifold with its final finish=
Dry fit of the manifold, alternator bracket needs sorting to clear the throttle cable
Flocked dash
DC2 Intergra type r seats, steering wheel will be trimmed in black suede with red stitching
Some whiteline goodies
1.5 lite swirl pot with JIC fittings will be boot mounted with pump and filter
Got a couple of bits on the weekend, an air filter with trumpet and a billet timing belt guide
The fuel system has had a re think so it will be as follows, out of the tank to the swirl pot -10 to fuel pump, -10 out of fuel pump to fuel filter, -10 from fuel filter to -10 line through the car, billet y piece to split -10 line to 2 -6 lines to the fuel rails and -10 return line to the swirl pot.
This should allow sufficient flow for well over 700bhp and keep things simple but meant I needed another fuel filter with -10 inlet and outlet. All lines and fittings will be supplied by Alex from Torques via ebay
http://www.ebay.co.uk/itm/6-Race-Rally-Teflon-Stainless-Braided-Fuel-Hose-3m-/150634011932?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item23127c9d1c
http://www.ebay.co.uk/itm/6-AN6-STRAIGHT-Steath-Black-Teflon-Hose-Fitting-/160593501453?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item25641e5d0d
http://www.ebay.co.uk/itm/6-AN6-90-Degree-Teflon-Stealth-Black-Hose-Fitting-/150567959320?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item230e8cbb18
Small update, prototype rails for the 14mm ID2000 have been made, a cold air feed that fits in the inner wing and a the alternator bracket for the reverse inlet
Final finish on the fuel rails
One off fuel rail for driver's side to allow clearnce for the inlet pipe
In place
Test fit of inlet pipe to check clearance, actual hose will be black
Engine bay getting there
A little something for the under bonnet temps as it will have a vent not a scoop
Some flocked interior bits courtesy of Oh Flock, dash still to fit
mall update but we are now on the home straight :luxhello:
Was not happy with the standard wiring loom, so bought a Gazza loom from Gus sti8 :thumb:
Almost ready to be fired up and a couple of outside shots with Matt R's beast
Had my steering wheel retrimmed as it was looking a bit sorry for itself, retrimmed by http://royalsteeringwheels.com/
Before
After
Originally Posted by trails
where's the vid then...I trust all went well?
Some pins for the wiring did not turn up, so did not fire today but on the bright side will be good to go monday or tuesday and straight on the dyno for a base map. Im a pic whore so got a couple of snaps
RCM return to sump catch can (cheers Hardy-P1)
Old wideband lambda wiring
New wiring
Arty shot :lol1:
So close to firing, just an ecu issue holding us back now
All wiring done
4bar map sensor and turbosmart 3 port boost solenoid
Swirl pot setup, still needs finishing off
Flocked dash in
Snap off steering
Gazza messing about with the wiring loom lol
Few misc pics
22B vents fitted
Dyno run video and Gaz with his race face
Roof vent fitted
spool up vid
Old 11-07-2012, 06:58 AM
banny786
banny786's Avatar
Had an issue with the rear wheels catching on the arch due to tyre size and wheel offset so had the arches pulled by http://www.bandedsteels.com/
Pics
Had a friend gave the car some, very pleased with the result
Also bit the bullet and bought a hyperflow monster intercooler
Wizards of nos nitrous kit
That is how the car currently stands will be mapped for nos and methanol later this week
Old 11-07-2012, 07:54 AM
danneth
TORQUE!
danneth's Avatar
like it !
Old 11-07-2012, 11:48 AM
SteRB5138
SteRB5138's Avatar
Awesome project. Love Type R's!
Old 18-07-2012, 01:06 PM
s2erst
s2erst's Avatar
very nice mate
Old 18-07-2012, 01:39 PM
banny786
banny786's Avatar
Cheers guys
Old 20-07-2012, 11:25 AM
slammedorion
slammedorion's Avatar
Wow looking good.
I must resist another type r for now, 2.35 builds hurt the wallet! ŁŁŁŁŁ.ŁŁ
Old 20-07-2012, 12:06 PM
banny786
banny786's Avatar
Originally Posted by slammedorion
Wow looking good.
Do you post on snet as scoobyslammed?
Pipework changed for 3" on the inlet side
Hyperflow monseter intercooler fitted
Old 20-07-2012, 01:54 PM
BLU
BLU is the new black :)
BLU's Avatar
Looks good
Did you get those headlights off Darms?
Old 20-07-2012, 05:06 PM
Steve the Plumber
The original Rouge Trader
Steve the Plumber's Avatar
Looks good!
Old 21-07-2012, 11:33 AM
slammedorion
That's me
Old 23-07-2012, 11:32 AM
banny786
banny786's Avatar
Originally Posted by BLU
Looks good
Recognise you to Mr Blu Nope bought the projectors from ebay and did the conversion myself
Originally Posted by Steve the Plumber
Looks good!
That's me
Your car was one I aspired to back when you were doing the project
Old 23-07-2012, 11:41 AM
adam151082
adam151082's Avatar
Very nice, how much did the arch's cost?
Old 24-07-2012, 01:05 PM
banny786
banny786's Avatar
Charged me Ł70
Old 27-07-2012, 09:20 PM
banny786
banny786's Avatar
2.1 bar vpower + 20% meth (no nos)
Old 28-07-2012, 12:00 PM
gjh
gjh's Avatar
Christ alive! Serious bit of kit you've got there!
Old 31-07-2012, 08:12 AM
banny786
banny786's Avatar
Gave the car a shakedown at TOTB ran 1.9bar peak holding 1.7bar on RE070s and managed a 10.80 1/4, the car has so much more to give but defo needs proper tyres.
Old 31-07-2012, 08:33 AM
darrenb16two
darrenb16two's Avatar
Fuck me! I thought my mates impreza was a beast @ 370bhp . Hats off to you mate thats an awesome motor
Old 01-08-2012, 08:41 AM
Alan_D
Alan_D's Avatar
Jeez. Never knew you were over 700, Banny. Didn't know you were on here, either.
Very impressive.
Old 01-08-2012, 09:17 AM
slammedorion
Cheers. . . Type R's are the one to have. . . Expensive to make them fast though
Old 21-08-2012, 06:58 PM
banny786
banny786's Avatar
second set of wheels for drag/track thanks to Mikee Singh. Rays CE28N's with R888's
New climate control, makes the inside look a little more modern
Old 21-08-2012, 07:10 PM
fogulbennett
fogulbennett's Avatar
that thing is a proper bit of kit mate cracking power figure also! love the rays wheels look so much better than the black wheels imo cracking motor
Old 08-10-2012, 07:10 AM
banny786
banny786's Avatar
Small update
Veilside titainium exhaust
Old 09-10-2012, 07:26 AM
s2erst
s2erst's Avatar
Love it mate. I had a tommy kaira running 400bhp so god knows what this would be like
Old 30-10-2012, 08:32 AM
banny786
banny786's Avatar
Had the car mapped again on v power @ 1.9bar at area52's dyno, turns out the VVT is not working causing the slow spool and car being down on torque
Old 27-11-2012, 08:38 AM
banny786
banny786's Avatar
Had the car mapped with vvt a couple of weeks back and it has made a huge difference to the way the car drives and responds. It was mapped for 20% meth at 2.1bar hence the slightly higher peak figure
Boost graphs
v power no vvt
Meth vvt
Old 02-12-2012, 05:19 PM
slammedorion
Stop posting on here
You'll make me buy another
Looks and sounds awesome
Old 03-12-2012, 11:17 PM
rs_traynor
stage4 2wd cosworth
rs_traynor's Avatar
cracker mate
i loved my type r!
Old 31-01-2013, 09:01 PM
banny786
banny786's Avatar
Booked myself in with Si down at SRR for some mapping on nos and race fuel, however did go to plan for one reason another but mainly due to leaving stuff laying around too long. So the plan is to get a fresh nos fill, buy some more race fuel and map the same the week. However did get some comparison runs against Area 52s dyno
Just like to add huge thanks to Si for his perserverance, CJ for his dry, Charlie for his back passage and most importantly the pizza man
Main man, looking cool
Power/Torque
Boost
Also booked in with Chevron motorsport for full geo setup, turns out it all to cock and needs sorting but the platforms on AST's are seized so will be going down again soon. Simon's knowledge is awesome would recommend him to anyone if you want the best out of your car handling wise!
Old 04-03-2013, 07:50 AM
banny786
banny786's Avatar
Had a laugh at Curborough, car is now at Chevron motorsport for some proper suspension, tyres and geo setup.
Had oil surge issues so had a baffled sump made up
Old 29-04-2013, 01:05 PM
banny786
banny786's Avatar
Little update, getting sorted by Chevron Motorsport in Stafford
Had an issue with two of the arms not adjusting properly so had them swapped out
Also got a little interior bling
Old 09-07-2014, 10:10 AM
banny786
banny786's Avatar
Due to personal reasons the type r was sold in september and I took a break from the scene but picked this up after a 6 month break
URL=http://s258.photobucket.com/user/banny_sti/media/d8444482-0077-4a25-b321-67a179e43fbe_zps97680324.jpg.html][/URL]
Gathering bits slowly
Forged destroked 2.36 short engine using a pinned ej257 block
Tomei+2mm rods
Cp custom pistons
Acl race bearings
Ej25 casings ( pinned )
Drilled for 14mm
12mm modified oil pump
2.0 rear thrust crank
Rcm water pump
Billet belt guide
Twin scroll sump / pickup
avcs heads
supertech standard sized valves
supertech springs and retainers
272s cams of some flavour
cdf verniers
Whiteline 24mm adjustable front anti roll bar
super pro roll centre kit
whiteline heavy duty steering rack mounts
whiteline subframe lock kit
Whiteline Castor bushes
Whiteline adjustable arms
newage sti quickrack modded to fit classic
sti group n engine and gearbox mounts
cusco front strut brace
cusco rear v brace
whiteline h brace
Whiteline heavy duty gearbox bushes
Kartboy Rear Shifter Bushing
Kartboy Shifter Bushings
Whiteline Rear Diff - support outrigger bushing
Whiteline Diff.mounts in cradle Rear
whiteline arb collars front and rear
WHITELINE BUSH KIT-CONTROL ARM - INNER FRONT
WHITELINE REAR TRAILING ARM BUSHES -FRONT
WHITELINE REAR TRAILING ARM BUSHES -REAR
whiteline camber adjustment bolts front and rear
whiteline max c kca251s front top mounts
Beatrush rear diff brace
Beatrush Propeller Shaft Mount Collar
beatrush forged pitch mount
Also sourced a uk hawk dccd box and an act 6 puck xtreme clutch. Just turbo left now
Got this sorted along with 2 x 38mm tial mvs external wastegates, just deciding on the turbo now
As a bonus an SDM gearbox cradle
Added in a defi racer water temp (cheers Indigo GT) due to the standard gauge being crap and not being able to find an amber bf water temp gauge as its an old model
Ready for its transformation at Richard Henry Motorsport
Manifold collected, previous owner's car with a GT4094
Old 10-07-2014, 12:13 PM
banny786
banny786's Avatar
Last car was finished before being sold
Old 15-07-2014, 08:01 AM
slammedorion
Gutted you had to sell up...
White one looks a good base...
How much did you give for it? Would love another Type R...
Old 15-07-2014, 08:24 AM
banny786
banny786's Avatar
Picked it up for a bargain Ł3.5k with the a few decent bits inc the AP's and a simtek ecu already fitted
Old 15-07-2014, 02:54 PM
slammedorion
V5 or V6...? Looks a great shell, love them in white...
I'd have another at that price...
Old 16-07-2014, 07:05 AM
banny786
banny786's Avatar
It was a bargain so I snapped it up and parked it up for a little while I decided what I was going to do with it, its a version 5
Old 23-07-2014, 06:53 PM
slammedorion
Keep the updates coming...
You get on Scoobynet much now days?
Old 23-07-2014, 09:13 PM
banny786
banny786's Avatar
Will do, yep still on there but dont post so much anymore as the ownership demographic has taken a nose dive in recent years
Old 21-08-2014, 09:49 PM
banny786
banny786's Avatar
Couple more pics, should have more come the weekend
Would like to say a massive thanks to Andy @ RH, man has not had a day off in 18 months and stayed an extra day just so I could have my cat flap :lol1:
Switching to solid engine mounts
Quick Reply: Subaru 2.35 Type R
