Other Marques Use this section for any non Ford marques.
1982 Capri unleaded ?
Old 19-05-2011, 07:05 PM
zs&tas
zs&tas's Avatar
Default 1982 Capri unleaded ?
Hello guys and gals, my friend has just dug his dads capri out of the garage, car hasnt run in years but it does now and flew through the mot.
It has a 1600 pinto lump and its a 1982, i am wondering wether it is unleaded ready or wether it would need an additive ?
all help appreciated thanks !
Old 19-05-2011, 07:32 PM
Chaz888
Chaz888's Avatar
not sure on that one the valve and seat are the problem I beleve and what there made of I did use an in line filter on an old car of mine (cast iron head) which lets you run unleaded with no more mods needed thare about Ł60 still got it I think if you need one Ill let it go cheap thare good for a 100 thou and its done under 10
Old 19-05-2011, 07:36 PM
zs&tas
zs&tas's Avatar
I know at some point they made them unleaded ready, and that was early 80's just not sure when, i was born 81 so that dont help lol ! Another friend had an 2.8 mk2 granada that was fine on unleaded.
Old 19-05-2011, 07:40 PM
trev1964
trev1964's Avatar
As far as i can remember, they never made them capable of running on unleaded.
My last Capri was a 1984 2.0s and that wouldn't run unleaded.
Old 20-05-2011, 07:07 PM
Perfectly fine on unleaded, they were since march 80 in fact.
The problem was the valve seat material not the valve itself, only the exhaust seat needed doing in ones that weren't, being a cast iron head helped anyway.
There was a campaign in other countries about using unleaded which forced ford to ensure the engine could run permanently on unleaded, though the japs were there years ahead as usual.
Old 20-05-2011, 08:05 PM
trev1964
trev1964's Avatar
Doing a search coughs up different responses depending on which site you try....
This is one..
http://www.fordcaprilaser.co.uk/the_facts.htm
Old 20-05-2011, 08:11 PM
trev1964
trev1964's Avatar
This one says some can and some can't and gives info on how to tell.....
http://musicchat.reocities.com/Motor...onunleaded.htm
Old 20-05-2011, 08:16 PM
I took my info from a german magazine that was involved with the casters/finishers of the heads, and although a long time ago remember it was due to a materials supplier change by chance the new ones from a certain number onwards were unleaded safe, this was from either march or april 80, I remember distinctly as my dad just got his new BFG XR3 at the time, and was wondering what engine that had etc etc.
Old 20-05-2011, 08:18 PM
stucapri2.9iTT
stucapri2.9iTT's Avatar
hi
the only pinto that will run on unleaded is the 2.0 efi engine from the sierra and granada
all the capri engine need the valve seat changing or running on an additive.
hope this helps
stuart
Old 20-05-2011, 08:22 PM
trev1964
trev1964's Avatar
My 1984 'S' wouldnt run unleaded for sure.
I checked with Ford at the time as i worked at a dealer.
Does seem a minefield..
mk1turboestate
02-12-2015 08:31 PM
jonnyenglish
21-09-2015 07:31 AM
DAN@ADRIAN FLUX
37
20-09-2015 10:38 AM
STAFFY OWNER
13-09-2015 08:59 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: 1982 Capri unleaded ?
