Vauxhall vivaro / renault engine fault (still probs)
#41
Shame, but this is what happens when you build a van with car parts, I certainly won't be buying another.
Anyone got a low milage 'smiley' Transit for sale ? 120,000 etc, infact I'll do you a straight swap for a 60,000 Vivaro - there ya go.
#42
Quick update for anyone having similar problems - New turbo fitted and van back to full power.
New turbo went on a lot easier than it came off, I suppose that was down to knowing where everything was and how to get at it etc.
If anyone else is looking for a turbo for a Vivaro 19cdti, go to Vauxhall, they do a service exchange turbo for £319 + vat = £380, not bad considering the cheapest I could find was around £350 with p+p on top.
So if you have a Vivaro that won't rev passed 2500rpm - check your turbo before you start changing bits - if I'd done this first I would have saved myself £200 because I changed the EGR valve, boost solenoid and boost pressure sensor - doh !
Oh and for £35 the garage computer diagnostics said it was the EGR valve - after I'd put a new one on ! So I wouldn't rely too much on computer diagnostics.
#44
Hi to solve the problem of the vivaro going into limp mode and feeling like its losing power or misfiring turbo kicking in late with some times the glow plug coming on !
This is a very common problem and is caused by air getting into the air filter box which is connected to the turbo pipe
Make sure the air filter box is fixed down properly some brackets which hold it down can brake making the box rattle and allowing air to get in
This will solve the problem 100 percent
#47
The air filter boxes on vivaro's rattle and just 1 bracket which holds it in place
Brakes which causes more air to get in
Which then causes the van to run sluggish
Usually after a while the glow plug light will flash
Basically telling you there's a fault to much air getting into the turbo
Which will then cause the loss of power
And Limp mode
And Limp mode
#49
And Limp mode
And Limp mode
#51
HOOORRRAAAYYY
Its sorted haveing thrown nearly 2 grand at this fault i dont know weather to laugh or cry at hte 50 quid it actually cost to fix this problem.. it was the air filter box wich is held in by 3 screws and 2 clips at the back any way 1 of the clips had broke and wasnt holding the filter in place properly. it held the filter in place till i hit seventy then failed and let the air rush straight onto the mass airflow and put the light on. So replaced whole airbox and the van runs perfect
#54
really mate thats funny i worked for vauxhall for 16 years and this is new to me i fail to see how the air box letting in air(which is what it does)its going to effect a engine in anyway?speciallly in the way your are talking about it will make no odds to it so please explain to me
#56
I was driving along and I noticed the glow plug flashed on and off for a fe seconds and thought nothing of it until the van started to drive sluggish and feel like there was no power
Then the light went out and everything was back to normal
So the next morning I started it up and notice the the engine didn't sound right like it was ticking over slower than normal and the revs were hovering on idle at around 10
Anyway drove around for a few days and noticed the glow plug light had come on and stayed on then the ban started to go into limp mode
So I pulled over and lifted the bonnet and pressed down on the air filter box and the glow plug light went off I noticed the box was not very secure so drove home
And had a look and found that the bracket and one of the clips had broken causing it to rattle so I bought a new air filter box put it on and everything was back to normal no glow plug light and the van ran like a rocket
vtec grin (19-03-2016)
#59
My theory
So make sure your air box is bolted down firmly before spending a fortune on diags or parts.
Although the above could be a complete load of tosh
good luck guys.
vtec .... an enthusiastic amateur.
#60
competant bodger
the extra air getting in through a crack or such in the box would not affect it as the air flow meter can detect and adjust for it, they are however a delicate sensor and i do think as suggested above if it is vibrating around badly it could well affect the reading considerably
#61
#62
My vivaro
Hi can anyone help my vivaro losses power and go's into limp mode Then the stop engine light comes on .
The Garage put it on the computer and its showing up EGR VALVE .
But ive replaced this and its still doing it , And the computer is still saying EGR Valve .
can anyone help.
can anyone help.
CabrioTurbo
01-08-2015 11:04 AM
