converting mondeo mk2 to 4x4
hi guys, got myself a mk2 mondeo 1.8 which im slowly turning to st24 spec (minus enigine lol- insurance would kill me) and i wondered if it was possible to convet it to 4x4, if so what bits would i need and from what car could i use them from
im just lookin into doin somethin different as i havent found anythin about a mk2 4x4 (unless google is not helpin properly) as at the moment its just a standard st24 replica in need of a paint job and something dirrerent, im thinking of having the bonnet extended like this one
doing something different to a MK2 is difficult mate, most things have been done before.
as for a 4x4 MK2, ford never made one
yeh thats what i thought, i heard that a certain jag has a similar plan to the mk2 so can use some of the 4x4 stuff from that but cant seem to find the site i found the info, but if its possible to use the parts from a mk1 that would be better as i know someone who is willing to sell me all the parts i need for Ł300 including the 2.0 engine, gearbox, all legs shafts and propshaft, even the rear subframe and tank
anything can be made to fit mate if your handy with fabrication. your best bet would be the MK1 mondeo 4x4 system, as it will be closest to the MK2. as for a 4x4 jag being similar, that is similar to the MK3 mondeo, as they share the same chassis.
its true about the jag being the same but its the x type and the mk3 mondeo, not sure mk3 made a 4x4 but i would think the mk2 and mk3 would take some work, mk1 4x4 is the best way, unless you want to convert to sierra floor pan, this would be alot of work!! why dont you fit a turbo instead??? 4x4 is no good in the mondeo form, you get gearbox/transfer box problems
Ford Focus Specialist
Mondeo's are good for stereos and styling and not a lot else.
God there's some rubbish going on here isn't there
I'm sure you could make the running gear from a MK1 Mondeo 4x4 fit the MK2, but I'm not sure if pick up points and things are a bit different, so you might be as well to buy a complete 4x4 and convert yours with that side-by-side so to speak. Though it would be a lot of work, so it is of questionable worth for the results.
As for the other thoughts. How is the 4x4 system wank? It's perfectly fine if it's looked after and you don't try and chuck a load of horsepower that it was never designed for through it. I love the way that the RS 4x4 system is shit as over 200bhp is pushing it a bit, but no one seems to say how shit the RST boxes are, despite the fact they regularly shit themselves at the same power output
Also, the Mondeo is good for a lot of things. It has a pretty decent chassis, especially for a car of it's size. Cars like the ST24/ST200 set class-leading handling standards, which the Mondeo has carried through to this day. People seem to forget it was the Mondeo which really made steps to change the way Fords drive, and without it, I very much doubt the Focus etc would be the cars they are.
If it was me, I'd fit the RSAP kit, bit of a drop with some nice 18" multispokes. Fit some V6 rear brakes, some Focus RS Brembos, ST200 interior, and supercharge a 2.0 lump. It isn't massively different, but who gives a monkey's uncle, it would be a wicked car
I'm sure the MK1 and MK2 shar ethe same floorpan? If thats the case I'm sure it would just be a case of swapping over the rear beam, fitting the propshaft and the gearbox?
A bit late to the party
OK I know it's been a looooong time, but has anyone successfully converted a Mk2 Mondeo to 4x4 ?
I have a Mondeo Estate ST24 that I like BUT in ice or in a muddy field the front wheels spin and it goes nowhere. I want to keep the car, so ideally I want to change it to have AWD. What do I need and what advice can you give me. ? PLEASE don't say "sell the car, and buy,,,,," that is not going to happen. I really like the car and it is only in these situations the front wheel drive lets the car down
I need a new rear axle, a new gearbox ? A diff for front to back ?
As it is an estate and they never made a Mk2 4x4 a custom propshaft?
Is the exhaust OK ?
What else would I need to change ? What welding do I need ?
Thanks
Dren
Is the exhaust OK ?
Thanks
Dren
