Escort MK6 1.8 Si Question
Kiss My RS!!
i've now got a Mk6 1.8 si again, this is my third in total, last one only lasted 6 days! but i had the 1st one about 2 years, my question is about the rear brakes and wheel bearings, on the first one i had real problems with the rear wheel bearings going all the time and its started again on this one i've got now, i want to know if there are any other ways, besides an RS2000 rear disc conversion that i can put rear discs on my escort, this may sound a bit weird but i believe if i have discs on the back it shouldn't go through wheel bearings quite as much? any help or any ideas on how i can solve this problem would be greatly appreiciated,
cheers
cheers
Kiss My RS!!
is there and specific tightness that they should be tightened to? i'd never really thought of that but tbh i never really used to overtighten them in my opinion, then again i cudda been if you know what i mean, lol
Kiss My RS!!
on this one i've only got 16's, on my first one i was swapping and changing between 15's and 17's, i'll find out what they want tightning to and try changing them both and see how i get on, cheers for the info/help
its a simple problem wit the wheel breaings , the rear spindles wear out to the point where even if you putnew bearings there will still be play in them and they wear really fast , all you need to do is buy new rear spindles and all will be fine again,.
They are around £65 each from Ford.
