PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Other Marques
Register Forgot Password?
Other Marques Use this section for any non Ford marques.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 16-02-2010, 09:42 PM   #1
EscoVan
EscoVan's Avatar
Trader Score: (0)
EscoVan is on a distinguished road
Default Lowering Escort Van Mk 6
Hi
Need some advice on lowering my mk6 escort van.
Can i just swap the front suspension struts for mk5 rs2000 struts and then maybe coilovers? Or would i have to buy lowering springs and have them fitted?
Also how would i go about lowering the rear leaf springs? Ive heard of people just flipping the leafs over so that they rin under the rear axel, but is it as simple as it sounds?
Any advice is much appreicieated.
EscoVan is offline   Reply With Quote
Old 16-02-2010, 09:46 PM   #2
duncansharp76
duncansharp76's Avatar
Trader Score: (0)
duncansharp76 is on a distinguished road
Speed shack can supply you a kit to relocate the rear axle and as far as i am aware the front struts are the same as the mk6 escort car so cant see any problem with swapping the fronts for either coilovers or rs struts and lowering springs. Rear axle will need some welding to be done. I dont the conversion to my own mk4 van and being on my own took me a day to do the front and the back.
duncansharp76 is offline   Reply With Quote
Old 16-02-2010, 10:02 PM   #3
EscoVan
EscoVan's Avatar
Trader Score: (0)
Quote:
Thanks a Lot ill look into doing that shortly
Old 17-02-2010, 03:22 PM   #4
EscoVan
EscoVan's Avatar
Trader Score: (0)
Also will mondeo zetec 16inch alloys be ok for te van, or will they scrub?
Old 21-02-2010, 06:16 PM   #5
duncansharp76
Trader Score: (0)
mondeo 16" will be fine n wont scrub as they arent wide enough to hit the inner arch and as long as you fit tyres that have a low enough profile wont scrub on the wings either
Old 21-02-2010, 06:31 PM   #6
EscoVan
EscoVan's Avatar
Trader Score: (0)
Thanks Mate
Old 22-02-2010, 07:03 PM   #7
monkeyboi
Trader Score: (0)
monkeyboi is on a distinguished road
if your using mk5 front struts your have to use the top mount off the mk6 shocks as the mk5 using a two bolt top mount and mk6 use's a three bolt pattern i think
monkeyboi is offline   Reply With Quote
Old 22-02-2010, 08:29 PM   #8
Dan j
New guy
Trader Score: (0)
Dan j is on a distinguished road
Send a message via MSN to Dan j
Iv got a mk6 van and iv just swapped the front suspension over from my car to the van lowered it nicely 40mm
__________________
Opinions are like arseholes, Everybody has one.
Dan j is offline   Reply With Quote
Old 24-02-2010, 10:54 PM   #9
EscoVan
EscoVan's Avatar
Trader Score: (0)
Quote:
Thanks a lot for all the info.
Another thing is there a way of fitting coilovers to the rear of the van? ( just wondering because i can get coilovers cheap) Cheers
Old 25-02-2010, 10:18 PM   #10
Definitive van
Trader Score: (0)
Definitive van is on a distinguished road
Quote:
Hi ive 17's on my mk6 but its not lowered and they seem fine
Definitive van is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
