| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Other Marques Use this section for any non Ford marques. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
Are you sure its the clutch and not the linkage ?
Mine has same problem and was told its common fault |
#3 |
to be honest chap i am not entirely sure? i was traveling approx 150 miles per day to and from work and it started to deteriorate ie crunch into gears untill now being stuck at my work
the clutch wasnt slipping or any thing but selects evey gear nice when engine is off? |
#4 |
any 1?
or is it just a case of no adjustment! replace the clutch etc? just wanted it home to change the clutch instead of having to do it at the works car park ![]() cheers
__________________
hud it chappin! mk2/3/5 GTE,GSI,VXR |
#5 |
look under the clutch pedal in the car there is a alan key bolt turn that a few times will ajust the clutch rathet give it a go but tak adjustment off when u fit new clutch m8
__________________
Your Current Signature Picture |
#6 | |
Quote:
i did notice that on the pedal, i have just bit the bullet and put it into the garage as i am stuck for time and need the van on the road asap for work cheers for your help tho m8
__________________
| Display Modes | |
