| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Other Marques Use this section for any non Ford marques. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
1985 FIAT UNO TURBO / 1993 FIAT UNO TURBO / 1997 FIAT BRAVO 20V TURBO / 1997 FIAT PUNTO SPORTING |
#2 |
there is a sensor on top of the thermostat housing that controls the fuel for hot cold running
#3 |
![]() BANNED |
It could well be the CTS, coolant temperature sensor, this is what tells the ecu, electronic control unit what to do fuelling wise based on temperature throttle other sensor input etc.
This is to be found on the thermostat housing, you'll easily know if you have the right one as unplugging it with the engine running will cause the fan/s to come on. There is another in the same area which is also a temp sensor, but this is for the gauge and nothing to do with the engine's running. It could be a number of other things though, particularly with it being an auto, there is so much more load on the engine at idle from the auto box they are very sensitive to running lean, so I'd also get the co checked and look for the usual suspects like air leaks, especially on the dreaded "T" connector rear of head underside linked into the pcv system. tabetha |
#4 |
ok cheers people, il have a play about with it and go from there.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Auto to manual Escort Mk6.....how hard to do? | lammylama | General Car Related Discussion. | 0 | 18-03-2009 07:59 PM |
| FITTING MK6 ESCORT RS2000 RECAROS TO A MK5 ESCORT 1.8 ZETEC | steelcabby | General Car Related Discussion. | 11 | 03-01-2008 11:49 PM |
| shawspeed'd 1600 into mk6 fiesta | Gorbash123 | Technical help Q & A | 5 | 25-04-2006 07:39 PM |
| escort 1600 zetec | Tank Mike | General Car Related Discussion. | 2 | 19-04-2006 08:55 PM |
| Starting probs on a mk6 1600 zetec ezzie???? Any ideas? | Ezzie | Technical help Q & A | 2 | 29-05-2005 05:40 PM |
