mondeo service lights
Originally Posted by medusa
Remove the glovebox, there will be a switch on the left handside, push the button in then switch on the ignition, turn off and the light should go off.
OR
in the bottom right hand side of the Aux Warning panel, should be a little hole, get a pin and stick it in ( this is the reset button for MK 2 mondeos )
brake light??????
thanks lads thats done the trick
anyone got any ideas on the brake warning light the car has js had new pads n disks but light js stays on
This is on mk2 mondeos? I got a v6 ghia X V reg, never noticed any service or brake warning lights!?!
Are these on the "doors open" panel that the earlier models have? Mine is a late model with the climate control but just has a coin tray.
Hi! Essex boy racer jo here just letting you know that if you have a coin holder on the dash you wont have the picture of the car and warning lights, but would have thought you would have as you have got a mk2 ghia X as I have it and have got the mk1 ghia.
I've noticed the later mk2s that have climate control rather than just air con don't have the warning lights in the coin tray. I'm yet to see one that does.
