NW England This is where members from the North West of England can arrange their meets and chat together.
Ford sierra dohc 2000e
Old 25-09-2012, 01:57 PM
Matt Reeves
Matt Reeves's Avatar
Default Ford sierra dohc 2000e
I have a problem with my twincam...when the weeather is `normal` conditions the car idles fine ie 850rpm. But when the weather is warm ie over about 18`c the car will idle at about 1500 rpm. When the weather is cold and wet the car really struggles to idle, it will vary between 500 and 2000 rpm and get worse until it eventually stalls. It will start again straight away no problem and rev straight to 2000 rpm, but then slowly fall down to between 500 rpm then upto 2000 rpm until it stalls again. Its definataly weather conditions that cause this, just dont know what its affecting?! Any ideas anybody?
Old 25-09-2012, 08:38 PM
mk22door
Fart of the Purniture
mk22door's Avatar
I would check/replace the coolant temperature sensor, idle speed control valve and ask on the FSOC.
Old 26-09-2012, 08:48 AM
Matt Reeves
I changed the idle air valve, the one on the air filter trunk at the front of the engine bay and that didnt make a difference. Im not sure if the throttle position sensor is playing up?
Where abouts is the coolant temp sensor located? How much would this affect the idle speed?
Old 23-10-2012, 12:33 PM
Moderator
STeve's Avatar
FYI, in case anyone else reads this ,not really the right area to ask for help or advice as there is specific areas here on passionford for this
3doorcozmess
31-08-2015 05:15 PM
tomiii
12
18-08-2015 08:40 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
pegaz
12-08-2015 07:30 AM
09-08-2015 07:03 PM
Quick Reply: Ford sierra dohc 2000e
