| New! Use your Facebook to securely log into this site, click logo to login |
| Register | Photo Gallery | Knowledge Base | Gold & Trader Accounts | Rules | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | My Recent Topics | Garage | Vendor Directory |
| General Discussion. To discuss everything and anything, car related or not. Arguing, libellous and defamatory posts will be removed without warning. (Strictly no parts for sale or adult topics in this room.)
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Display Modes |
#1 | ||||
PassionFords Creator
![]() ![]() ![]() Trader Score: (11)
__________________
Best Regards, Stu ![]() Click to read my tuning articles. / Click To Visit Our eBay Shop Does Your Ford Need A Setup? / Cosworth Chips / Cosworth Tuning Packages. Wasted Spark Systems / Closed Loop / L8 & P8 Anti Lag / L8 & P8 Launch Control Magnetic Sump Plugs / Focus Rs Tuning / Evolution Chips For All Cars |
#2 |
My 044 pump arrived last weekend, just got to fit it now, glad i decided to take the "just in case" step now
![]() nice example stu, especially with such clear evidence. On the subject of fuelling, i took apart an engine last night that im building for Rob for his astra as he wants 500bhp now. When we measured the bores there was [/b]12 thou[/b] of wear at the top of them, and this was an engien that had only been built for 1500 miles. Reason i believe was that the guy Rob got it off had been running it for most of that time on a "running in SAFE map" all very well being safe from running lean, but not much good if its so rich it makes the rings eat the bore walls at the rate of 1 thou per 100 miles! People REALLY need to realise how critical fuelling is! |
#3 |
impreza wrx sti version 8
unchballs: i know the feeling
__________________
Motorsport Developments: "The engine management Live mapping Specialists" 01253 508400 |
#4 |
i take it mine was ok when you tuned it then stu.
__________________
#5 |
I am a little lost, as the second chart you put up also show lower that 12.2 above 22psi?? Not a dig, more of a question really??
Also could you put the1st 2 and second 2 images side by side so they are easier to compare |
#6 | |
Quote:
The point he is making is that you cant just look once and then assume it all stays ok. Yours WAS fine, make sure you dont leave it too long before taking it back for a quick checkover |
#7 |
you said your car was 34 peak 30 held - its like fishing stories in here LOL
Good warning setup though |
#8 |
very interesting Stu
what is the best wideband in car gauge to run? also.. im confused at the AFR figures.. i admit i never really paid much attention to what these mean... so i guess im paying for it now but.. on your second log, after the fuel pump was replaced.. is it the higher the afr numbr, the leaner it is? |
#9 | |
Quote:
#10 | |
Quote:
you paid more attention that you realised |
#11 | |
Quote:
#12 |
PassionFord's crazy fool!
Sean, you still thinking over a rebuild while all seems healthy?
__________________
============================================= Time for the PF Keyboard Warriors to grow up and stop running around in their playground cliques..... ============================================= PS3 name: DeathKind |
#13 |
Uprated fuel pump is the first mod to be done!
#14 | ||
Quote:
unless he fancies going over to do some festive tinkering. I DONT THINK SO. your right though need to get there asap for my post tuning check up.
__________________
#15 |
If thats in a lowish gear and its only hitting 34 psi for 1500rpm on the way up. thats pretty much just a peak by any standard surely?
So 34 peak 30 held sounds fair to me on that |
#16 | ||
Quote:
I want one
#17 |
a couple of q's then
what are the bounderies for a top end fueling run.. ie.. when should the alarm bells start ringing and waring lights start flashing in terms of afr also, at what boost.. do engines only melt at high boost AND revs, or can hey melt at lower ranges, ie 15 psi to 22 psi but at low revs) basically.. what should the alarm bells be set too |
#18 | |||
Quote:
![]() The most dangerous thing your car can do tuning wise is running a LITTLE lean on big boost. thats where it slowly melts the pistons away! |
#19 |
34 peak and in my opinion more like 25/24 held as this is the top end - but thats how i read it.
It was only the lightest of joking digs as I'm sure stu will appreciate |
#20 | |
Quote:
__________________
#21 |
Personally, I would.
__________________
#22 | ||
Quote:
#23 | |
Quote:
anything in the 11s is generally nice and safe for on boost fuelling though. and its often in the middle of the range that people melt things due to a mapping problem (its where you make most boost normally) but its at the top end that you will always kill it if its a fuel pump issue as its at the point of max bhp not max torque that the pump is working hardest. |
#24 | |
Moderator
Quote:
__________________
Mike Rainbird Sarcasm is just a free service I provide. http://www.rsnorfolk.co.uk/ Nordschleife, there's only two barriers to worry about - the ones on the left and the ones on the right .
#25 | ||
Quote:
Given your current financial situation and how much you love that car, i would do it mate
#26 |
So presumably following on from Chips first comment many things affect the "ideal" fuelling level??
I mean for eg mine could be lets say for example, 12.4/12.5 @27 /28psi Peak/held Presumably thats stil ok?? Or do different tuners like their own different figures?? |
#27 | ||||
Quote:
__________________
#28 |
hmmm.. my dyno plot is full of 12's! ??
#29 | |||||
Quote:
__________________
#30 | |
Quote:
running leaner means more heat, so its all down to what your components can take and what measure you are using to combat heat, like for example if you have water injection you can get away with running leaner than without it |
#31 |
0-60 in 17 seconds (eek)
Nice one Stu.
Worth checking the wiring too, as it gets old and isn't quite so able to carry the requisite power and voltage to the pump PS: Any offers on wideband kits over xmas ???
__________________
PF Berks+Hampshire meet, last Wed each month @ 19:30, Longbridge Mill,Sherfield on Loddon,Hook,Hampshire,RG27 0DL. Any advice given is for you to take with a large pinch of salt. Mike Rainbird for parts - MADevelopments for tuning - Opie Oils for, er, lubricants
#32 |
Good thread witha great example.
__________________
nice try |
#33 |
Chasing Radders
Pop a new fuel filter on while your there
#34 | ||||
Quote:
Quote:
AFR figures are a ratio of fuel to air, the larger number being air.. Example: 11.5:1 is RICHER than 12.5:1 Quote:
![]() Admittedly that run was in 4th and it DID hold a tad more boost than it normally does. probably more impending doom on teh horison... look out for teh next topic Quote:
I like teh dynojet for its instant datalogging at teh flick of a switch, as seen here, and its ability to WARN you of danger, so no need to EVER look at teh gauge itself.
__________________
#35 | |
Quote:
I cant see why you are richer at low rpm at 15psi than you are flat out at 28 psi Were the EGT's being monitired too though? |
#36 |
Stu - why is the fault away once the boost goes down/revs up as presumably peak power is up at 6500odds so peak fuel should be needed there?
Looks more like some sort of regulator fault than pump from the 1st charts but then your new pump sorted it minted Just seems odd - I would ask if the problem was repeatable through rev range like that but after seeing it once i doubted you wanted to know lol
#37 |
ok, stu's alarm went off at afr 12.1 up to 12.4
my dyno chart shows my entire air fuel range at 12.4 - 12.7 whats going on there then? or is it different rules for dyno runs? |
#38 | ||||||
Quote:
ask jamsport dan about the traffic lights launch wid the evo sat behind me to be fair though when stu set the car up he did say there was a issue with the clutch and this confirmed the voice of reason
__________________
#39 | |
Quote:
His car must be making peak power lower than you suggest i would think from that. |
| Thread Tools | |
| Display Modes | |
