Any of you work for VW? Service light reset switch
Legend
Should be as follows:
The display will say IN01 IN02 or something?
With the key out of the ignition press the odometer reset button (hold down)
Turn the ignition on (warning lights come on) wait about 10-15 sec until most or the lights are off (still pressing odometer reset button)
Turn ignition off (button still pressed) and remove the key
Release reset button
Should be fixed
Should be fixed
i thought it was
step one, press the milometer reset button down
2: while still pussing it down the the ignition on
3: with the ignition on and the milometer reset down, twist the other reset button on the dash cluster to the right
4: release the milometer button first, then the other one
5: then press the milometer rest down once
WARNING THOUGH
reseting it this way will revert the car to fixed servicing which is every 10k, where id imagin your car is on variable or longlife service
if you pm me the reg, i can check this
i think your all way out there , have you got a full digi panel ?
does the service indicator say 'service due' or 'inspection' or a little spanner light ?
if so unless youve got a service tool you cant do it !! , or you need VAG 5051 to reset it !!
mark
p.s the very old type indicators said 'in01' and in02' and 'oel' !!
mark
Service indicator says 'service due' and GSF are saying it's reset with the buttons as I asked to buy the service tool but apparently there isn't one??? Nobody seems to know for sure!
I have the registration if anyone can check this?
Cheers,
Jim
Cheers,
Jim
sorry to bring this post back up,
but i also work for vw, and you dont need the 5051 to reset the service light on a mk4 golf as i did it this morning on a customers car
jr,
pray do tell , i fookin hate 5051 with vengeance , so slow and out of date , its fookin shite , i had heard there was a way , but put it down to pure speculation,
Originally Posted by markk
jr,
just checked it again
hold right had side reset button down, turn ignition off
turn ignition on
twist left reset button to the right while still holding down right reset button
relaes both and press right reset button fown once
twist left hand side button to the right
should be done
turn ignition on
should be done
Stu @ M Developments
41
21-08-2015 06:47 AM
