2L Black top Zetec and ST170 thermostat housings?
18-12-2009, 07:12 PM
Are they the same?
Will a ST170 housing fit on a Black top?
Thanking you.
18-12-2009, 08:10 PM
yes there same, but the silvertop one is a bit better its ally.
18-12-2009, 08:13 PM
18-12-2009, 08:19 PM
The fucker on my focus is leaking i noticed today
18-12-2009, 08:20 PM
Quote:
Originally Posted by
crazycage
Very rare to find a silver top with the alloy housing. Also the holes are slightly different spacing on the black top so would need on e the holes opening out.
andy130
or the cvh rst one
you need to drill and tap the head for that one .
18-12-2009, 08:23 PM
andy130
or the cvh rst one
Also not right temp sensor hole.
18-12-2009, 09:15 PM
Rossco
i took the silvertop ally one off my 1800 fez and it bolted straight onto my st170 no messing with the holes.
18-12-2009, 09:28 PM
crazycage
Random, iam using a black top head and tried fitting a plastic housing from a silver top and one bolt hole was a couple of mm out
18-12-2009, 09:36 PM
Rossco
its got me mate as its now on my blacktop .
18-12-2009, 09:40 PM
crazycage
I drilled most of the alloy insert out of the misaligned hole, was not quite enough as it crack when tightening.
18-12-2009, 09:42 PM
Rossco
ill get a pic of it mate as it cant be the same as the one i used and that was off my 1800 xr2i
18-12-2009, 09:45 PM
Mine was from a 1800 Escort SI.
18-12-2009, 09:51 PM
just niped out the garage lol
18-12-2009, 09:55 PM
Thats the same design as the one I used, only yours is alloy.
18-12-2009, 10:01 PM
Rossco
i only fitted that one because i cracked my plastic one when lifting the engine in and out doing the mtx conversion,but they have 3 threaded bosses in them for different water sensors handy if you have a after market management and a water temp gauge.
strange that your one didnt fit tho.
19-12-2009, 07:39 AM
19-12-2009, 08:24 AM
Ford for life
crazycage
arent the impellors plastic on the silvertop
19-12-2009, 12:51 PM
The 60ft Launch King
zetecdan
£200 for that...
the words.
'Get'
'Bent'
come to mind sharpish
20-12-2009, 10:14 AM
mozzy
what impellers its a thermostat housing lol
20-12-2009, 06:31 PM
Ford for life
crazycage
ignore me i was half asleep lol, was thinking water pump
20-12-2009, 06:50 PM
mozzy
thought as much lol
20-12-2009, 08:26 PM
Rossco
I "might" have a spare alloy housing mate.....
I will have a look and drop you a text, i know they were pretty rare, but the engine in the MK1 deffo has one, and Im 99% sure I have a spare!
May be of use mate!
19-01-2010, 03:44 PM
crazycage
Difficult to make out the markings on it from these pics. Can you supply the part number? I need one of these housings and the local ford dealer can't seem to locate without part #s
20-01-2010, 08:18 AM
I'm after one of these too
20-01-2010, 04:53 PM
will get the part number later and post it up
21-01-2010, 11:00 AM
Did you get the part number?
21-01-2010, 06:37 PM
AustenW
yes , 928m-9k470
22-01-2010, 10:56 AM
My local Ford dealer says that part number has been superceeded by the newer plastic type housing now
robnock
21
13-05-2019 05:29 PM
Porplus12
10-09-2015 07:20 PM
robnock
22-08-2015 10:51 AM
track.focus'd
12-08-2015 05:53 PM
gingerturbo
11-08-2015 09:44 PM
2l ,
928m9k470 ,
black ,
blacktop ,
engine ,
head ,
housing ,
impeller ,
pump ,
st170 ,
tap ,
thermostat ,
top ,
water ,
zetec
