| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#81 | |||||
__________________
#82 |
Stu, funny you should mention failed fuel pressure regulators today, a few days ago my friends liner melted down on the way home from buying it, and the reason it would appear at first glance is that the MAP pipe into the FPR had come off, meaning that the FPR wasnt staying the same differential from the manifold pressure that it should.
10p worth of pipe failure = bill for many thousands (well would be if he wasnt going to rebuild it himself, but even DIY its going to be well into 4 figures) |
#83 |
I monitor the 4 egts out of each cyl and i have a wide band afr meter i also monitor the fuel pressure which has a warning light which pisses me off when im not on boost
BUT its better to be safe than sorry |
#84 | ||
Quote:
#85 |
Super Moderator
i need to fit my 044 pump .. just need the fitting to do it ...
#86 |
Stu, i said technically, not most accurate - will defo be intersted in tests
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#87 | |
Quote:
#88 | |
Quote:
__________________
Euan Fastest Sierra in Scotland 188.1 mph at brunters in the wet Built,tuned and prepared by AVA turbos |
#89 |
So a standard or stage 1 saff has less risk of a melted piston because they don't run an high boost like a stage 3 saff?
For example, take the old fuelpump of Stu's car, with a standard or stage 1 saff there where nothing wrong because the boost isn't high enough so the fuelpump works correct and fuelpressure doesnt drop on boost, or am i totally wrong here? cheers |
#90 | |
Quote:
Spot on for 3 main reasons: 1 the pump sees less resistance 2 the pump doesnt need to flow as much for 280bhp as 330bhp anyway 3 if you DID get a slight leanout, its safer at lower boost and less likely to melt something |
#91 |
Good post Stu
Question for you though mate, how old was the std fuel pump on your car? I'm asking as because you know you have my old Saff in with you at the mo & 2 years ago I had a brand new std one fitted as a safety precaution, thought about going for an 044 but heard it wasn't necessary for stg3. Dave (new owner) was on about gettin one fitted & I said the same to him (that that new std one should be fine for many years to come especially with new wiring - unless of course he decides to make use of that ported head I never knew I had on there with some greys). Is this true or was I talking bollocks again & would you recommend he should really get an 044 fitted?Cheers, Ian
__________________
Mint Stg 3 Cossie now replaced 180bhp of 205 oversteery-ness & a house
#92 | ||
Super Moderator
Quote:
where has the egt gauge come from if you dont mind me askin cheers jay
__________________
#93 |
Don´t mind of course.
It´s an aircraft instrument. It has four inputs, so you can measure multiple things with it. Watertemp, oiltemp, cylinderhead temp, chargetemp before and after intercooler, EGT, pretty much any sensor you want can be purchased to the meter. Since it´s approved for use in aircrafts I guess it´s pretty accurate too. Approx. £100 incl one EGT sensor. L.
__________________
#94 | |
Quote:
cheers
__________________
aka scrote honda c90 1974 you know it makes sense gone but not forgotten http://www.youtube.com/watch?v=V5fCyx_I5GU |
#95 |
__________________
#96 |
http://www.mglavionics.co.za/ (manufacturer)
#97 |
__________________
#98 |
they look cool
__________________
#99 |
Just ordered one
thanks
__________________
#100 |
This is a very good thread
For the price of one of the monitors compared to my engine I really am going to have to invest in one of these for piece of mind |
#101 | |
PassionFords Creator
![]() ![]() ![]() Trader Score: (12)
Rep Power: 36 ![]() ![]() |
Impressive gauges, and at a GREAT price!!
Quote:
Mine was knocking on a bit (A lot) and strugglin with the 35psi thats all.
__________________
Best Regards, Stu . Click here to read my tuning articles. . Click here to visit our Brand NEW webshop. Find us on FaceBook. |
#102 | ||
Quote:
__________________
#103 |
is there a price list on this website for there products ?
i cant find one
#104 | |
Quote:
__________________
#105 |
Dave wouldnt want to be doin any hammer time with AFR'S like that in yours pal get it checked out on the road,IMO Should be in the 11's if not all but most of the time,looks a tad close to the bone to me
On my topspeed runs i was 11.6 ish droppin to 11.3 top end at limiter. Tim
__________________
Built By Norris Motorsport.(Builders of the worlds fastest RS TURBO'S). www.norrismotorsport.co.uk 01773 836274 |
#106 |
Thats a cheap Gauge
__________________
#107 |
Trader Score: (0)
Rep Power: 12 ![]() |
bloody cheap
#108 |
gauge turned up in only 3 days!
__________________
#109 | |
Quote:
__________________
#110 |
sorry to hijack the thread but i wanted to show my pics of the gauge fitted.
i have 5 egt probes around the engine now- 1 in exhaust housing of turbo and one in each runner of manifold ![]() ![]() and ask a couple of questions.... what should i set the alarms at? (currently set at 870degC) and at what difference between cylinders should i be worried? because i see 100 degrees difference at tickover between 1 and 4.... cheers
__________________
#111 |
Depending on your inlet manifold design (i.e. if you have a single throttle plenum) you will get significant differnences in EGT's at idle. This is due to the large difference in AFR's on each cylinder at idle brought about by the each cylinders inlet runner proximity to the throttle body.
As an example on my own car which has a centre feed single throttle plenum I see 300DegC in 1 and 4 headers and 400DegC in headers 2 and 3 at idle. However this is largey irrelevant as it is your on boost EGT's that are important. Here a correctly designed and mapped engine can see as little as 10DegC between exhaust ports! With regards to safety limits I personally allow 950DegC in the exhaust ports of the head, and up to 900DegC in the down pipe assuming you are not running with significant exhaust system back pressure. If you are it is possible to see the down pipe temps rise above the head port temps. In this situation you should increase exhaust bore size. Ideally you should see anything from a 100 - 200DegC drop between head port EGT's and turbo downpipe.
__________________
Best regards, Karl Norris |
#112 |
Could be worth getting a new 044 before the ring trip
Cheers Stu, very good point with evidence to prove
__________________
Its taken two weeks and one trip to see Karl and Ollie @ NMS.....Oh dear best get saving hahaha |
#113 |
Fucking superstar........
Trader Score: (0)
Rep Power: 20 ![]() |
Well, I know all about leaning off on boost. My fuel pump died on boost in 3rd, going up a hill, just a few weeks ago, melting 1 and 2 pistons
Thought it was going well
__________________
#114 | ||
Quote:
__________________
nice try |
#115 | |
Thanks for the answer Karl
Quote:
all the thermocouples i have were supplied by ForeigneRS
__________________
#116 |
Testing the future
thermocouples came from www.conrad.de
can't find the exact ones on their website, but they're something like Artikel-Nr.: 120757 - 62 but made of inconel only 1.5mm thick, which is quite fragile, but fast reacting to temperature change
__________________
Nick It takes me less than 9 minutes ![]() RP Lab L8 ECU 1998 Puma 1.7 / 2002 Galaxy 2.3 LPG / 2007 Honda VFR800 VTEC / 1972 Honda C90 |
#117 |
any pics of these sensors in situ ?
Dave.
__________________
I don't want a BMW.
#118 |
__________________
#119 |
This is interesting stuff.... STU - I might need some of this info for the Technical Articles I discussed with you some months back!
My car run's at .76 lambda on hammer and I also have a Knock Guage that has been calibrated with DET CAN's. I must admit, I am fairly regulary checking my lambda and Knock Guage..... |
#120 |
Yeah, no probs Shaun, keep me updated with links pal
![]() All my articles are interesting, this isnt scoobynet ya know...
__________________
| Display Modes | |
