| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#41 | |||||
__________________
nice try |
#42 |
Airflow in the car is greater, so potentially if it was going to go either way i would expect it to be LEANER on the road than on the dyno, so i cant explain why dyno readings might be higher numbers (leaner) as its not what i would expect.
But ive never had the luxury of owning a dyno to play with im afraid so im kind of guessing really mate! Stu will know of course |
#43 | |||
Moderator
Quote:
.Quote:
__________________
Mike Rainbird Sarcasm is just a free service I provide. http://www.rsnorfolk.co.uk/ Nordschleife, there's only two barriers to worry about - the ones on the left and the ones on the right .
#44 |
Dave, by the way, peak pwoer occurs at the sort of numbers you have there.
If i was operating a dyno and wanted a big number for the customer to tell his mates, i would run those figures briefly to get the numbers, then dial it in a little safer on the road. Its called "pub horsepower" mate
#45 |
Dave,
Whos dyno is that and are they the same people that mapped your car? It may be possible that the lambda sensor is at fault. They do degrade over time if they see alot of fuel additives and rich mixtures.
__________________
nice try |
#46 | |
PassionFords Creator
![]() ![]() ![]() Trader Score: (12)
Rep Power: 36 ![]() ![]() |
Quote:
Example: Std YB at idle. 3.0 bar With 0.1 bar boost = 3.6 bar With 1 bar boost = 4.5 bar With 2 bar boost = 5.5 bar Seems my old pump flows fine at 5.3bar but not anymore than that, this incidentally is where the 044 scores. it loves huge pressures. lol. (Note.. remember that as pressure goes up, so does current draw to finish off your shonky 20yr old wiring loom)
__________________
Best Regards, Stu . Click here to read my tuning articles. . Click here to visit our Brand NEW webshop. Find us on FaceBook. |
#47 |
On the same Dyno as Daves...
#48 |
looks like the same map but .1 psi higher fuel pressure
![]() Thats harveys dyno i take it? as the readout looks the same as dougs |
#49 | |
Quote:
Fuel pressure? |
#50 |
BTW different turbo different injectors, one has ALS one doesnt
#51 |
Damo, i was joking, its obvious from the torque figures tehy are totally different specs!
#52 |
I run my mini at 10.4:1 AFR on full boost
__________________
![]() "Judging by the car you have chosen, you are a motorist of a special breed, and you are probably no novice when it comes to automobiles." . . . 928 S4 Owner's Manual 1987 |
#53 |
Makes sense stu - just my initial thoughts out loud - as you have shown the pump sorted it
#54 |
Stu
Is there anything to setup and check on a Focus RS Fanks |
#55 |
on the focus you have
knock sensor airflow meter lamda sensor So the ECU is a lot more "clued up" on any changes that happen and its far less of a risk. |
#56 | |
Quote:
#57 |
Lord of Longridge
you told me to get mine checked every 6k or so stu so i will
booking it in pretty soon
__________________
Cheers, Andy ![]() 11.93 1/4 mile @ 116.9mph - Santa pod Lancashire RSOC Group Chairman |
#58 |
i love the idea of having a warning light for a/f ratio
mmmm maybe i might buy one of these myself
__________________
#59 | |
Quote:
#60 |
Guess i´ll go uprated pump before i get my car on the dynapac this winter... I dont have a warninglight for a/f ratio, but for the EGT which i believe is the most important one. Because you can have any a/f you want as long as the EGT doesn´t rise to a critical level. It´s the high temps that melts stuff, not the a/f itself.
__________________
#61 |
but whats the response time of your egt gauge/sensor?
__________________
#62 | ||
Quote:
http://www.dynojet.co.uk/wideband/ Quote:
__________________
12.063 at 112.66mph with under 300bhp |
#63 |
More than fast enough to avoid meltdown in my opinion.
If it had to be quicker than what it is, I wont be able to let my foot of the throttle fast enough to avoid damage anyways.
__________________
#64 | |
Quote:
#65 |
#66 |
so what is there to set up (adjust) on a small turbo escos?
#67 |
we always like a picture!!
good one that is!! billabong - you werent on the a47 near peterborough the other day were you? coulda sworn I saw who I thought was you lol
__________________
MELV |
#68 |
Melv, last Friday per chance?
#69 | ||
Quote:
he has i have mine checked approx every 2000 miles generally twice a year - both maps
#70 |
yeah I think it woulda been - I was just nipping home from work to get my fridge delivered, unusual i see daylight at the moment lol
where does the datalog come from? the Afr gauge or is there an add on you need to datalog?
__________________
MELV |
#71 | ||
Quote:
thats the one ave got , just need to weld the boss in
__________________
![]() 3dr Cossie & RWD = Fun (Small Clip) http://www.keithamorracing.com/ 3dr build thread |
#72 |
LM1 shits on any other Wideband bar the ECM "technically". Most important gauge in the car for me - i can program in any combination of conditons to warn me - ie IF MAP is > 15psi, and rpm > 4000 & afr > 12.5 then fire the rev limiter....
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#73 | ||||
Quote:
Quote:
Quote:
Quote:
I have tested them BOTH back to back with a national Magazine in tow, so i know how accurate they BOTH are. And thats exactly what my software does, i think to be honest most of em do, but i dont know of any with the warning light, which is the feature i like the most.
__________________
#74 |
Super Moderator
stu cheers for this topic gives me a comparison of where my car should be i just fitted a new pump standard one tho so looks like ill be buyin a 044 soon lol
cheers jay
__________________
#75 | ||
Quote:
Your EGT gauge will normally not respond fast enough to show detonation, especially if its in a low speed area that isnt showing high EGT's anyway, this you then not knowing anything is wrong. EGT monitoring is superb and certainly has its place, but it sure isnt a "substitute" for an AFR monitor, more an ideal partner IMO. Quote:
__________________
#76 |
Super Moderator
stu is there anychance of rounding up the recent topics and putin them in tech forum
cheers jay
__________________
#77 |
yeah, as long as someone collects up the links i will move em
__________________
#78 |
Noooooooooooooooooo! Then I won´t be able to read em.
__________________
#79 |
The warning light idea must be reasonably simple to apply to any AFR meter with auxiliary outputs anyway? ie the LM-1 can drive a narrow band DISPLAY as a true AFR reading via its analogue output. So surely a simple circuit that illuminates a warning light at the correct voltage from this output would do the job?
#80 | |
Quote:
Otherwise it would come on whenever you reached this low AFR, thus part throttle, idle, cruise, blah blah... It needs some intelligence to be useful. EG: Over 22psi + over 60deg throttle + over 3000rpm + leaner than 12.2 = ENABLE. Anyhow, anythings possible, was just making the point that it does it out of the box and does it well, so its my preffered unit, i also like all the others.
__________________
| Display Modes | |
