how much for a s2 clutch change?
as above, anyone know how much the likes of Jamsport would charge to change a clutch for a standard motorcraft one? how much is a good price, inc labour, at a local garage?
how much harder is it to change on a s2 than a xr3i, as i done a couple on them?
cheers
dre
cheers
dre
I do it for about 120 quid labour plus what ever the clutch costs, not sure how much they are from ford if its got abs its a bit of a pain to do on the floor, if it hasnt it wwill be the same as an xr3i realy
I'm sure I priced it up at Ford once [a rapid fit dealer] and they did a special clutch change price. Think it was £150 including the part!! I think the clutch is £80 from Ford.
Also a local gearbox place quoted £75 if fitted with ABS £30 without although that was when I bough a box at the same time.
AJ
the only thing that worries me is that there is alot of shit around the box that makes life hard eg metering unit, fuel lines etc. was gonna do it myself originally but if it wasnt gonna cost a great deal it isnt worth the bother... for $100 however...
clutch is 92 inc vat
just finding my feet
abs is the issue, if you dont got it then its usually fro 90 quid upwards for labour
3 hours to fit a clutch is a estimate and also a foooking piss take if the car is a erst with no abs
specially at a garage with a ramp as it takes about a hour
metering head aint a issue as you take the box out the bottom
remove the drive shaft cup and then box , take out clutch and refit new, then line it up like a fooker , thats the hard bit
no trouble at all, we done a gearbox and clutch on me cabrio in 2 hours on the side of the road
air tools is ever quicker ,,,,,, all i got ot ratchet spanners
most decent garages would charge £40-£50 an hour, so with the parts, labour & vat it should be around £250 the worse way.
i admit the ABS thing its a cooont,,,,,,,,, but if it was your own car could you not do it quicker,,,,,,,, i ask cause ive just asker the techs at work and they said they can do 2 hours but choose to take 3 and a half as why rush a car as theres just gonna be more work
Originally Posted by andrek12345
fook paying $250!!! id rather do it myself...
i dont have abs on my car, not sure if its been removed or didnt come with it... how can i tell?
I used to find if you drop off the complete front ARB with the brackets and bottom arms, then drop the box down before attempting to remove the modulators and shafts it made it a lot easier.
Leave the modulators hanging on the pipes,saves bleeding the brakes.
I used to kill boxes all the time in my RSTs
most placed will charge book time regardless how long it takes
i can drop a box on shafts n clutch re fitted in 30 mins on 2 poster but i wud still charge book time
if i was hung over and took me all day i still charge book time
p.s i dont work on customers cars hung over
