Where to get boost hose when fitting a hart inlet to cosworth?
Just fitted a hart inlet to my car with a top feed intercooler but the cooler is higher than the throttle body and don't have much room between the two, where can I get a step down hose have had a good look and cant find anything!
**RS COSWORTH**
What make intercooler do you have fitted?
**RS COSWORTH**
Matt lewis or Rouse you may have to cut it down to size from each end but will give you the angle your after. They should have these as it's a combo that people usually fit.
lee2cossies (20-01-2017)
You can get a specific one which is listed for Swedish plenum, I used it on mine and was able to trim it to suit, it has the correct kink in it, I will find you the link
Yes, mine is the same as Cossynut. If you did as Stevieturbo says you would need to be lifting the engine a few inches and apart from a hole in the bonnet I think that might upset handling.
I am sure you also do not want to cut out the front of the car and have your intercooller dragging on the road so maybe a simple boost hose is the right solution?
