3dr antiroll bar
Old 18-01-2017, 06:12 PM
martynhomer01
martynhomer01's Avatar
Default 3dr antiroll bar
I had to take the 17 inch wheels off my 3dr as they keep catching the front bumper as they're sat too far forward. I believe the car has had a sapphire anti roll bar fitted so wondered if the standard 3dr roll bar made the wheels sit further back?
If so, has anyone got one they'd part with?
Old 18-01-2017, 06:21 PM
3drRich
3drRich's Avatar
I had a similar issue years ago on my 3dr and I think I had to change my lower arms as they where saff and not 3dr ones...
Old 18-01-2017, 06:22 PM
Mark V8
Mark V8's Avatar
Early 3 door one is shorter and will pull the wheels back.
Just make sure it's a H13
Not selling mine though !
martynhomer01 (18-01-2017)
Old 18-01-2017, 06:27 PM
2Litre
2Litre's Avatar
Yes the 3 door anti-roll-bar (H13) will give you less Castor than the sapphire (H14) resulting in the wheels sitting further back.
Tim.
martynhomer01
Trying to find one mark. Any ideas?
Old 18-01-2017, 06:34 PM
martynhomer01
How come you won't sell mark? Are they a rarity?
Old 18-01-2017, 06:36 PM
PAUL S
PAUL S's Avatar
All 3drs came with the H13 not just the early ones.
As part of the conversion process Tickford swapped out the H13 for the H14 on the RS500s well that was the theory anyway!
My 500 still had its H13 fitted, but given it was the last but one car built and the August 1st deadline for homologation was the next day it seemed to have slipped through the net I however finished off the work for them.
Mark V8 (18-01-2017)
Old 18-01-2017, 06:47 PM
martynhomer01
Do you have a h13 for sale Paul?
Old 18-01-2017, 06:48 PM
Mark V8
Mark V8's Avatar
I struggled to find one
Got it from a guy on Ebay advertising that he was breaking a 3 door.
Old 18-01-2017, 06:49 PM
mk22door
Fart of the Purniture
mk22door's Avatar
If you can't get hold of one you could get your Saff ARB milled back a bit to suit.
Old 18-01-2017, 06:51 PM
martynhomer01
If I can tempt you mate. I'll pay decent price.
Old 18-01-2017, 06:56 PM
3drRich
3drRich's Avatar
Is there a difference in the lower Arms as I'm sure I never changed the arb???
Old 18-01-2017, 07:01 PM
martynhomer01
Lower arms are the sam ei think rich. It's Arb that has a different length shaft for arms to sit on
Old 18-01-2017, 07:07 PM
3drRich
3drRich's Avatar
i must have changed the arb then. Sorry mate not sure where I got that from as I could have sworn I changed the arms lol. How do you tell the difference between a h13 and 14 then? Obviously one is shorter but how would you know unless you had them side by side??
Old 18-01-2017, 07:09 PM
martynhomer01
Numbers are stamped into the ends near the tca shaft
Old 18-01-2017, 07:11 PM
mk22door
mk22door's Avatar
Might have to rub a bit of rust away but its there somewhere.
Old 18-01-2017, 08:19 PM
3drRich
3drRich's Avatar
That will teach me to look at the pictures properly next time
Old 18-01-2017, 08:31 PM
mk22door
mk22door's Avatar
I do it all the time.
Old 18-01-2017, 08:38 PM
Mark V8
Mark V8's Avatar
Sapphire TCAs don't fit 2 door hubs
3 door hubs have a tapered fitting for the ball joint on the end of the TCA and Saph ones are parallel with a pinch bolt.
3drRich (18-01-2017)
Old 18-01-2017, 09:25 PM
Ridgey
Ridgey's Avatar
Would a slight trim of the edge of the bumper sort the issue, then you have better handling with the greater castor angle.
Old 18-01-2017, 09:37 PM
martynhomer01
Just fitted a brand new 500 bumper! No chance 😂
Old 18-01-2017, 09:57 PM
Ridgey
Ridgey's Avatar
Fair enough.
What tyres you on? Smaller tyre profile any use? 225/35 ?
Old 19-01-2017, 08:51 PM
PAUL S
PAUL S's Avatar
I stashed that H13 down the side of the garage, and after I moved out my lovely ex wife had the local gypsy clear out all my stuff stored there before I could pick it up, full stainless system also went walkies.
Luckily my garage was fully secured otherwise she would have also no doubt let him have that old Sierra parked inside for Ł100 as well!!!!!
Old 21-01-2017, 10:44 AM
Mark V8
Mark V8's Avatar
Might be worth asking this guy
http://www.ebay.co.uk/itm/breaking-3...3D122312159610
martynhomer01 (21-01-2017)
Old 21-01-2017, 02:36 PM
2Litre
2Litre's Avatar
just machine your H14, I run a h13 on my three door but i fitted double backing plates on the back of TCA bunches to increase the castor as it was very twitchy without.
Tim.
martynhomer01 (23-01-2017)
Old 23-01-2017, 11:48 AM
martynhomer01
Tim.
question is, how far do I get it machined back?
Old 23-01-2017, 05:34 PM
dojj
Resident Wrestling Legend
dojj's Avatar
there are many tales of what fits one sierra not fitting another
i've taken the suspension from one car and it's not fitted another simply because of the tolerances of an 80' ford being in inches rather than microns
the first thing to do is to make sure that it's an actual 2wd bar as the 4wd versions give you different geometry
the granada bars are also a fit but give you different issues again, even though they are supposed to be the same thing
changing the size of the bushes in the body mounts can also give you issues
the simplest method to change the position of the front wheels it to fit compression struts and then have a front mounted arb, will probably work out cheaper than buying a "genuine" rs500 one with the added benifit of being better in the way that matters, handling
if you don't want to do that and want the wheel further back then milling the bar down is another tried and tested way to shift the geometry, but this might lead to different geometry related problems
it could even be the case that the front bushes are poly and don't deform to the extent that the originals do leading to the wheels hitting the bumper
i'll stop there before you start to have too many ideas swirling about in your head
Old 24-01-2017, 06:29 PM
tjRS500
tjRS500's Avatar
I have a 28mm arb here off a 2wd saph Cossy. Only marking on it is (H then the ford emblem then 23)
Not sure if it's H13/14 or something different?
Old 24-01-2017, 06:51 PM
martynhomer01
Not sure what the h23 bit is, but I think it has to be h13
I've just got a h14 but looking at the bar on mine it already has h14 on it
Getting cheesed off now
JPA (11-08-2018)
Old 24-01-2017, 07:45 PM
Mark V8
Mark V8's Avatar
I'm pretty sure that's a 29mm ARB from a Granada 24 valve mate.
They are a bit wider than a Sierra one.
Old 25-01-2017, 09:30 AM
dojj
dojj's Avatar
if it is then, in my experience anyway, they are a right bastard to get to fit and straight line normal driving is "difficult"
but the turn it is brilliant
Old 25-01-2017, 02:05 PM
Marc sierra
Marc sierra's Avatar
The Granada arb is indeed a bit wider than the sierra one because of the longer tcas on the Granada. So it's very difficult to fit as you have to compress it quite far. But handling wise it shouldn't make a difference as the castor angle will still be the same.
Old 25-01-2017, 03:43 PM
2Litre
2Litre's Avatar
I would take 3mm off the H14. I have increased my h13 by about 4mm.
Cheers.
Tim.
Old 22-03-2017, 11:21 AM
tjRS500
tjRS500's Avatar
Sorry to revive this thread..
What effect would fitting the compleg 2wd saph setup, I.e. hubs, tcas and arb have on a 3dr...
I assume that it will push the wheels further forward?
Atm I have a three door replica still using mk1 parts... I.e hubs, tiny 24mm arb and tcas.. I recently purchased 4 pot calipers and discs and these do not fit the standard hubs. Needs about 5mm taken off the hubs which I think is too risky.
Obviously purchasing 3dr cosworth hubs, arb tcas etc would cost a fortune! Even if you could find such!? That's why I'm thinking about using all saph 2wd items
So back to the original question, has anyone used complete saph Cosworth 2wd setup on a 3dr? And what consequences were there?
Old 22-03-2017, 12:08 PM
MONSTER
MONSTER's Avatar
Going off the previous posted pic I'd say around 10 - 12mm (3/8" - 1/2")
Old 02-08-2018, 01:22 PM
janus
janus's Avatar
i know, old thread but found it looking for ways to increase castor.
to add to the confusion.. i found this in another thread (actually Mark V8's build thread, where there was some discussion about the front ARB) - regarding the modification to a H14 ARB:
"its 5mm you would need to machine back on the ends (not the very ends) of the roll bar to move the cups/washers 5mm back and ultimately the TCA's" (to put castor back to stock/H13 position)
--edited, got confused with h13 and h14 but think it's correct now - H14 can be machined to H13 but not the other way round, right?
Old 02-08-2018, 07:33 PM
2Litre
2Litre's Avatar
Correct.
Tim.
Old 10-05-2019, 12:42 AM
janvanv
www.rallyanarchy.com
janvanv's Avatar
Exclamation another bump of a ancient thread.
Is there any comprehensive listing of the various anti-roll bars???
I have 2 here, bought in England as alleged 4x4 bars and they're marked H15.....they're 26mm dia. which is what I was told is what gravel rally guys used on their 4x4s....I also have one which seems same shape marker "24" and its 28mm..
But the Sierra 3 door, Sapphire RWD and Sapphire 4x4 all had 28mm so that doesn't narrow it down...
I'm assembling a whole Cossie 4x4 engine, box, front diff, crossmember, rack TCAs hubs, brakes PS rack and I would like to assemble it with the correct 4x4 anti-roll bar..
Any hints or leads on positively ID the markings?
Old 10-05-2019, 08:59 AM
Marc sierra
I am not sure on the markings, but the early XR4x4 had a 26 mm ARB. And standard 2wd Sierra’s had ARB’s in 24, 26 and 28 mm, depending on the year of build. In general all ARB’s (front and rear) got thicker over time.
Old 10-05-2019, 03:50 PM
janvanv
janvanv's Avatar
Yes, Xr4x4 was 26mm and there's a fair chance that the 2 I have which have been milled flat on the bottom in the middle to facilitate sump gaurd monting are 4x4. But I'm packing and shipping this whole, assembled engine and box and crossmemnber/rack/hubs and hopefully bar 2000 miles to a guy and it needs to be right...
Hence looking for something that says " "H15 bar..........V6 4x4" or "24" bar.................Sapphire Cosworth 4x4
I still have to find a 2wd bar for me cause my cars going back to 2wd..
