t5 upgrade
Old 15-01-2017, 12:49 PM
jamie956
jamie956's Avatar
Default t5 upgrade
What are the options for up rating a t5 box,
Big tooth, straight cut, bronze forks? What's best and who dose it.
Old 15-01-2017, 01:18 PM
Caddyshack
Caddyshack's Avatar
Don't most people go over to a tremec?
Old 15-01-2017, 02:44 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Tremec is the fit and forget option but I'm sure I herd it's the older type box that rod runs or the one mark used which are the ones to go for. Is there not an issue with the newer ones changing gear at high rpm? Sure someone had an issue I've a big tooth in mine but once mine is back on the road I'll be looking to up grade at some point. It's torque that brakes things
Old 15-01-2017, 03:33 PM
DAN400
DAN400's Avatar
big tooth kit in mine , no real problems the past 10 years or so with it
Old 15-01-2017, 06:31 PM
rog
rog's Avatar
Have you considered opting for a better box like a Tremec TKO?
Old 15-01-2017, 07:15 PM
jamie956
jamie956's Avatar
heard the same thing about the tremec boxes don't like shifting at high rpm.
Old 15-01-2017, 07:27 PM
james kiely
james kiely's Avatar
I never knew their was a early and late version of the tko andy.
​​​​​mine must be early version ,well over 12 years old at least
Old 15-01-2017, 07:35 PM
ajamesc
ajamesc's Avatar
I'm thinking tremec that rod has is that not a tremec tko?
I don't know the numbers or the codes I know rods is different to the one mark had in his RS500 I believe.
Sure the older versions are the 3550 or the 500 but not entirely sure long time since I asked lol gearbox is a long way down my list at the moment lol
Old 16-01-2017, 09:37 AM
nixon_2wd
nixon_2wd's Avatar
You can make them shift way better with the shift finger modification and carbon fiber syncro rings. The shift finger mod is easy to do. The problem being the complicated 3 rail design which the finger sits in between. The sliding motion between the rails make the finger jam from 2nd to 3. and 3. to 4th.
You should also use GM syncromesh part no: 12345349 on the tko's. This will help with high rpm shifting.
Another option is to send your gears to liberty and get them faceplated & cryo-treated for about $800. You still need the shift finger mod though, but that is included in the price I stated.
