Had my cossie on the rollers at the weekend...
#121
1st to 200 without NOS
Dude do you really need to ask?? I don't want to be rude but its been pointed out several times already, but if I need to clarify then there is absolutely nothing wrong with the graph as graphs go but what it does look to display is that the engine is lazy, not just a bit but very. Get more low down power and the car will be a completely different animal.
#123
Mark
#124
Do you mean engine or turbo?
Like I mentioned I debated putting on a smaller better specced gt30 to make it possibly 800-1000 revs lower spool up but that would still only give me around 500hp.
I want to go for a bigger turbo keeping the spool up about the same as it is now but with a 600-700hp peak power, so if it comes on boost around 5k and pulls all the way to 8500 that is still a nice power band just higher up in the revs
Cheers Paul
#125
I'm no expert on this so forgive me in advance and if I've missed also I'll get my coat. But what is the engine spec of your car?? What cams are in it?? Who is your builder mapper??? Karl Norris I'm guessing from your window sticker?? Should you not be talking to Karl if so??
PS, I had a similar thing years ago, Jim Greens old Sapphire, engine was spec'd for a T4 and Jim changed his mind last minute and stuck a UT T38 on it and it was horrendous, I had a very similar graph (Mark) will clarify this and it was just awful, very very lazy indeed
#128
This has also been backed up with real tarmac times
#129
Cheers Paul
#132
Anyway, great thread this, some great input by Mark and many owners, very interesting indeed.Some good comparisons on the graphs.
CheeRS.Lee.
turbotrev (01-12-2016)
#134
Yes my car is set up and specced by Karl. I am happy with it as it is. It is a little laggy but the turbo will be changed. Like I said before I've just made do with what the car had when I bought it.
Soon I will be changing the turbo.
It is low comp, 200 block, Cosworth racing Pistons, neil roper head, Karl's cams with solid lifters, hart inlet, 83lb injectors, l8, air injectors, hybrid GT30, live mapped, 80 shot of nos upto 1 bar of boost.
Cheers Paul
#136
I think it's fine to have an engine that comes on boost at 5000rpm and goes all the way to 8500 if it's a track/circuit car as that's where it'll spend most of it's life.
For a road car on the other hand, you'd have to be in the right gear at the right time or you're gonna get roasted by a 300hp Fez that pops up
Twin scroll turbo and manifold should sort out power lower down with maybe some DBW on something like Syvecs/Life Racing.
#139
I think you've got the wrong end of the stick buddy, I wasn't necessarily asking for info, it was mearly a post of my results from a RR run, that's all.
Cheers Paul
Cheers Paul
You'll be suprised the difference cams can make, that's all I was saying bud, not having a dig. Engine's can be specd incorrectly bud
#141
Ops car will be a fast car just not easy to drive, my supra was laggy as hell but also fast as hell and great fun to drive mentalist car, nothing nothing nothing and spinning at 100mph lol
#142
I've seen some shoddy engine specs before trust me ha ha.
I do agree with Moondustka too, I guess mine is more of a 'track/racing' spec rather than a 'road spec' I guess.
I've never been on a track yet ha ha.
But I've not lost a race yet either....
Cheers Paul
#144
Cheers Paul
#145
I used to think the same mate, I had an r33 gtr make 650 at all 4 hubs, 30 hp loss per axle so 710 hp crank, did 30-130 in 9.7 seconds which is about right, seen lots of times of supposedly 700 hp gtrs doing 30-130 in 12 seconds they've been Miss informed by dynos I think, the black stuff doesn't lie it can confirm dyno plots though that's how I look at it
turbotrev (02-12-2016)
#147
Mark
#149
Surrey rolling road is regarded as realistic I'd say you've certainly got over 500 hp, all its lacking is revs, msd mapped my yb to I think 7800 rpm iirc it will have a good band then that's all I'd be looking for if it was mine
#150
It's my turbo restricting power top end of the revs.
This turbo just won't flow more power.
When a bigger turbo goes on with less efficiencies the power won't be restricted
Cheers Paul
Cheers Paul
#152
You need to watch for surge aswell my t4 yb surged it's tits off below 5000 rpm fluttered like mad
Get them revs up to 8000 and stick a gt35 on it will be monster
As a side note on a gt40 I picked up 100 hp just from turbine housing going from 85ar to 105ar at same boost !
I was informed by a reputable tuner my housing change will make no difference, I picked up over 100hp and 1.5 seconds quicker 30-130 needless to say I havnt used that tuner again, I trusted my gut and I was right
#153
I wouldn't worry too much about power, we will soon be returning them back to standard in order to sell on to someone who believes the Ford Sierra is the holy Grail of automotive history and is willing to pay obscene amounts of money to remind themselves of 1980's Ford technology
#154
Modded all the way for me
Cheers Paul
#155
Have you had a gt35?
What car did you gain the power on swapping the gt40 housings?
Cheers Paul
#159
On another note.. transmission loss is totally car dependent and what transmission you have. The Cosworth stuff from 30 years ago is archaic and will be no comparison to a GTR.
15-18% is about right for an average 4x4 system. The GTR will be much lower than that as it's a much better engineered system. FWD usually has the lowest transmission losses. Transverse mid-engined will be the same. Rear engined will also be similar like Porsche. But every car is different, that's my point.
scoooby slayer (02-12-2016)
#160
The GTX-R range is just out. Depending on the rear housing selection these are meant to be as good if not better. And more reliable? Or so I've heard.
Mark
