Max power on a 200 block?
Old 26-10-2016, 12:13 PM
lee2cossies
lee2cossies's Avatar
Default Max power on a 200 block?
What is the safe max power on a 200 block without liners? Mines a new block on standard bore, not a Turkish block, a new original casting that came from bore ham. I'm fitting a efr 8374 soon just wondering is it worth waiting and getting a nikasil linered block, aim is around 600/620 for now, would this block be safe at that?
Old 26-10-2016, 12:27 PM
jamie956
jamie956's Avatar
nothings safe at +600hp, at that power you roll the dice and take your chance.
lee2cossies (26-10-2016)
Old 26-10-2016, 12:33 PM
lee2cossies
Know what u mean, just interested to see if anyone's running 600+ on a 200 block without problems, further down the line I'm either going to get a nikasil linered block or alloy.
Old 26-10-2016, 12:45 PM
Staffi
Staffi's Avatar
Do it once, do it properly Lee I would pal
The following 3 users liked this post by Staffi:
800bhp (26-10-2016), lee2cossies (26-10-2016), Rod-Tarry (27-10-2016)
Old 26-10-2016, 12:46 PM
800bhp
**RS COSWORTH**
800bhp's Avatar
It's worth having it done now while it's in bits rather than doing it later or in the worse case it's to late.
Old 26-10-2016, 12:47 PM
Staffi
Staffi's Avatar
Just to add, it's always going to be one of those questions like with the 205 block, I know folks that run 500 conversions on them and they didn't crack, Brom, Dingy, Nutter etc etc, but if I were looking at doing 600 plus I'd want everything out there available that can make it as safe and reliable as possible.
Pete
The following 2 users liked this post by Staffi:
Old 26-10-2016, 01:10 PM
1374lee
1374lee's Avatar
Best to ask your engine builder and mapper Leigh.
CheeRS.Lee.
Old 26-10-2016, 01:31 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
If you build a proper engine with expensive internals it's a very expensive gamble if it dose go wrong lol
Old 26-10-2016, 02:22 PM
lee2cossies
I havnt long built the engine and it's in the car and running on a s200, don't really want to strip the bottom end yet was just thinking can I go for a bit more on this engine or start again!
Old 26-10-2016, 02:29 PM
jontysafe
jontysafe's Avatar
I've gone wet nicasil lined and I'll not be much over 500bhp. The nicasil liners aren't there just for strength but heat management too.
Old 26-10-2016, 02:42 PM
nixon_2wd
nixon_2wd's Avatar
Nikasil is old expensive tech. Go for newer stuff (steel) which you can hone / bore to next size if anything happens.
A 8374 will put you beyond a non-linered block imo. The 7670 is already over the limit.
The following 2 users liked this post by nixon_2wd:
lee2cossies (26-10-2016), smiley (26-10-2016)
Old 26-10-2016, 02:51 PM
jontysafe
jontysafe's Avatar
Steel is "new"?!
Old 26-10-2016, 03:58 PM
AJC
AJC's Avatar
Wenny runs a standard block i think but his power is only really used for 10 seconds and thats it, think Cossie Dave Pritchard maybe on a standard block at over 600 ponies
Old 26-10-2016, 04:19 PM
lee2cossies
Il have a chat to a few tuners see what they think, if iv got to go down the road with liners I will just thought maybe I could get away with this engine at 600 ish. I thought a few people were running 600ish on a standard block, doesn't big Justin have a standard block? The price of having a linered block is half way to the price of an alloy block is another thing.
Old 26-10-2016, 06:50 PM
Gav Diamond
Gav Diamond's Avatar
Depends how far you plan to go, alloy block with nice crank etc at 2.2L will give scope for higher power if you get bored and be a nicer engine but it's if you can justify the costs
I wanted more power and after weighing up everything that I wanted the cost was more than I was willing to put into the car so called it a day
So many things you need to budget for, I wanted 700bhp but silly things like breather system was Ł800, exhaust another Ł700 etc etc soon spirals out of control
Old 26-10-2016, 07:42 PM
lee2cossies
Know what you mean about it getting out of control! Really wanted a rs500 but that's out of touch for me now so plan on going as far as I can afford with my saff, for the time being anyway, don't plan on ever selling it, if I could get close to 600hp for now then slowly gather the bits over a few years to go further il be happy.
Old 26-10-2016, 07:49 PM
smiley
smiley's Avatar
Just as a guide mate as I don't know what's in your block but my fresh built mountune spec 200 running shot peened rods was told the rods are at their limit at 550
Old 26-10-2016, 07:58 PM
lee2cossies
Run shot peened standard rods myself, spoke to Harvey at scs about this and he said standard rods are fine to 700hp.
Old 26-10-2016, 08:04 PM
Adam-M
Adam-M's Avatar
Bit shocked at this thread I thought the 200 block was meant to be good, I know they are old but I thought if anything it would work harden them?
How much is it to get steel liners fitted then?
Adam-M
Adam-M's Avatar
That is amazing, take it people upgrade them below that power so they can go longer and change the angle of rotation and not because they are on their limit?
Old 26-10-2016, 08:11 PM
Gav Diamond
200 block is good, mine was/is fine at 550 bhp
Rod broke his at 838bhp but think he went liners when moving from 500 to 600bhp
Old 26-10-2016, 08:23 PM
smiley
smiley's Avatar
Sound mate guy I got it off had it spec'd for 550 probaby safety in mind it will be re spec'd for 700 new rods pistons steel ductile liners haven't you asked Harvey about running 600 on it?
Old 26-10-2016, 08:24 PM
lee2cossies
They are good for 800+ with liners fitted.
Old 26-10-2016, 08:25 PM
lee2cossies
nice spec you got there, im going to call him for a chat this week so as I get a chance.
Old 26-10-2016, 08:26 PM
lee2cossies
To have nikasil liners fitted it was about Ł1400, not sure what liners are being used these days or the cost.
Old 26-10-2016, 08:27 PM
smiley
smiley's Avatar
It's only block thickness between 205 and 200
Old 26-10-2016, 08:41 PM
DAN400
DAN400's Avatar
my first 200 block cracked at only 420ish hp
luck of the draw with all of them imo
Old 26-10-2016, 09:02 PM
Gav Diamond
This is it, I sold my Turkish block from my old engine and that's been running over 520bhp for a good while now and know of a few others at similar power
Old 26-10-2016, 09:29 PM
Adam-M
Adam-M's Avatar
8kg of extra material I thought they'd piss 600bhp easy
Old 26-10-2016, 10:11 PM
turbotrev
turbotrev's Avatar
I have been told similar about the standard rods as well.
I have a linered 200 block and once a new turbo goes on next year I'm hoping for at least 600hp keeping the engine internals as they are now
Cheers Paul
Old 26-10-2016, 10:13 PM
turbotrev
turbotrev's Avatar
Also I don't know Cossie Daves engine spec but he is running 700hp now
Cheers Paul
Old 27-10-2016, 07:43 AM
Mark Shead
Mark Shead's Avatar
700hp on 25+year old rods is plain stupid.
My limits are 550hp on stock rods and pistons these can go higher if carefully with hitting rev limiters and plug misfired as this is what pushes them over the edge with age and power.
I have mapped a few at 600hp and been ok but you pay your money and take your chances is my opinion.
Mark
The following 2 users liked this post by Mark Shead:
800bhp (27-10-2016), smiley (27-10-2016)
Old 27-10-2016, 08:56 AM
Adam-M
Adam-M's Avatar
What's your opinion on block strength mark?
Old 27-10-2016, 09:21 AM
Mark Shead
Mark Shead's Avatar
I what way. I liner above 550hp for bore strength and stability of bores to reduce blow by.
Mark
Adam-M (27-10-2016)
Old 27-10-2016, 09:48 AM
c20tbo
c20tbo's Avatar
Im standard bore size 200 block, but running arrow long rods and short cp pistons to improve rod angle, st/st crank, im aiming for around 600bhp
Old 27-10-2016, 12:12 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
No!! didn't have a problem at 838bhp it just needed new shells at 7k miles hence going dry sump. The Block that cracked was my 680bhp engine with a 200shot of 'push' Nitrous so probably over 950bhp on the day. That was in February 2006 lots of development since then.
Old 27-10-2016, 03:35 PM
lee2cossies
Mark
What type of liners do u recommend to fit these days mark, still nikasil?
Old 27-10-2016, 05:10 PM
Mark Shead
Mark Shead's Avatar
Custom made ductil iron after having to much nicasil blocks have oval bores.
Mark
lee2cossies (27-10-2016)
Old 27-10-2016, 07:35 PM
smiley
smiley's Avatar
I mentioned iron Lee was a while ago I spoke to mark
Old 27-10-2016, 08:04 PM
lee2cossies
Didn't notice that bit! lol. il get a price on these liners, who fits them these days and how much?
