MK1 Focus Clutch Pipe to AN hose
Has anyone ever modified a MK1 Focus clutch pipe to use different fittings? I need to convert mine to an AN aero fitting. I cut it down so it's just the steel pipe, and was going to flare it and use a threaded fitting, but it seems a very odd size. No brake pipe fittings will go over it.
Has anyone every modified one?
Hi mate,
I got mine to be all braided using a focus adaptor at the pedal end and the line I actually bought from Central Florida Motorsport for the SVT. I think the standard focus adaptor gives you a female M10x 1.0 thread
Ben
Ben
Proline Motorsport has had the fitting made from the end of the pipe made so it can made onto a braided hose
Found this at Proline:
http://www.prolinemotorsport.co.uk/b...c-11aa40fea444
But I had this from CFM:
http://www.c-f-m.com/performancepart...m#.WBBRFIZ4WEc
Pretty sure it's a -3 hose so I just cut it where needed and put a fitting on.
