Drag slicks on standard Cossie lattice wheels
Old 11-10-2016, 05:49 PM
  #41
stevieturbo
C**t
stevieturbo's Avatar
I'd be surprised of 13" fitted over the rear brakes.
Old 11-10-2016, 06:08 PM
  #42
scoooby slayer
scoooby slayer's Avatar
Originally Posted by stevieturbo
Doesnt matter what car etc.....slicks/santa pod breaks stuff !
The difference between such tyres and normal tyres, even 888's etc is night and day
I never went near pod with any of my cossies, only got one of them to hook real good which was my white saph from north yorks, just cheap 225 tyres and every full bore launch I did broke the diff instantly so I fitted a gripper In the end.
I'd be very wary of a stock diff at pod on road tyres let alone slicks I've got a heap of planet gears here still lol
Old 11-10-2016, 07:16 PM
  #43
costina
Live long and prosper!!
costina's Avatar
Correct they will not. 15's min
turbotrev (12-10-2016)
Old 12-10-2016, 09:00 AM
  #44
turbotrev
turbotrev's Avatar
Totally!
Stock planet gears and cwp's are like chocolate when launching at pod
Cheers Paul
Old 25-10-2016, 09:19 PM
  #45
jamie956
jamie956's Avatar
Well had another go with the slicks on at the weekend, knocked a bit more off my 60ft down to a 1.61 and lifting a wheel in the process
turbotrev (26-10-2016)
Old 26-10-2016, 06:05 AM
  #46
ekjim
ekjim's Avatar
Looks amazing did you get any vids and how did the gain in 60ft effect the et ?
Old 26-10-2016, 07:19 AM
  #47
jamie956
jamie956's Avatar
Et was crap i was playing with set up and pressures as the car was all over the place only managed 3 runs as it was that busy plus a few oil downs made it a slow day, on the last run where i started to have it figured out the car was over boosting so had to back off
Will be leaving the line on boost next year so see how that go's.
Old 26-10-2016, 06:33 PM
  #48
Gav Diamond
Gav Diamond's Avatar
Ran the BFG drag radials on my 3dr, broke my Gripper diff and destroyed my T5 gearbox
Got a 1.8 60ft running tyres at 12psi, tried them at 6psi but bogged the launch
Old 26-10-2016, 06:48 PM
  #49
stevieturbo
C**t
And BFG's would be the least grippy of the bunch ! lol
Anything below about 10-12psi for a drag radial is too low IMO but always worth experimenting. I'd never go that low for fear of the tyre moving too far or simply coming unstuck from the rim and losing all the air.
As far as breakages, a lot do say a proper wrinkle wall tyre is much easier on the drivetrain because of the really soft sidewall.
But sticky tyres will break stuff if you give it the chance. What part of the diff broke ? As a proper LSD it should be fairly strong ? Or does it still use a single diff pin as per old LSD's ?
Old 26-10-2016, 07:04 PM
  #50
jamie956
jamie956's Avatar
I started to play with the tyre pressures after a little advise from Kevin Jenkins, I started out at 14 psi but the car was all over the place he said go up to 20 and drop 1 psi each run till you find a balance of grip and stability, I didn't get the chance to put it in to practice only the initial run at 20 psi which made the car more stable and at that I did a 1.7 60ft previously a 1.6 at 14 psi.
Old 26-10-2016, 07:09 PM
  #51
Gav Diamond
Gripper diff still uses standard CW&P
Broke teeth off crown wheel and on the road I snapped pinion shaft so gave up on the Gripper and went supra route but never ran the car again on 1/4
Never had a issue with running the BFG on low pressures, was cold pressure so may have increased slightly after big burnout but felt fine and car was reasonable stable upto the 124/126mph trap speeds
Couldn't compare grip levels with other drag radials as only ran those, now gone skyline I don't think I'll ever be at power levels to need to try them again
Old 26-10-2016, 10:18 PM
  #52
turbotrev
turbotrev's Avatar
Good 60ft time buddy
Cheers Paul
jamie956 (27-10-2016)
Old 28-10-2016, 06:45 PM
  #53
costina
costina's Avatar
What is in your granada Steve?
Old 28-10-2016, 06:57 PM
  #54
stevieturbo
C**t
in what bit ? tyres ? air ?
Old 29-10-2016, 03:04 PM
  #55
costina
costina's Avatar
Sorry Steve. Wondered what diff you are running?
Old 29-10-2016, 05:05 PM
  #56
stevieturbo
C**t
At the minute it's a Wavetrac torsen diff.
A plated type might better suit some usage, but I've a huge disliking for any diff with a diff pin. Sooner or later they all break. I'll sacrifice some performance for reliability.
I've only broken one torsen style diff and that was just last year ( Ford Racing diff ). And it wasnt even the gears that broke it was the outer casing of the gears.
Old 30-10-2016, 09:53 AM
  #57
ekjim
ekjim's Avatar
Gav what size were your BFG drag radials and where did you get them from ? I could only see them in USA and was working out to expensive when you work out postage .
Old 30-10-2016, 10:16 AM
  #58
stevieturbo
C**t
They'll all come from the USA, and they'll all be F'ING expensive....and worse with the crappy exchange rate.
All UK sellers I've come across are charging basically the same price it would be to bring them in yourself, give or take.
All the usual places can bring them in, few actually keep any stock.
Hauser, Webster, Trackstuff, LARacingparts and I'm sure there are others.
It's a pity some US sellers cant or wont sell them through egay's global shipping program, as that would make them more affordable. Summit offer some iparcel thing to some locations which is about the cheapest postage option I've seen
Old 30-10-2016, 12:25 PM
  #59
jamie956
jamie956's Avatar
My M&H tyres where Ł450 at the beginning of the year, I got them from La racing but wouldn't recommend them took ages to come and just kept getting bull shit every week that they where on there way and I've heard the same about trackstuff, I would order a set now if you want them for next season.
Old 30-10-2016, 01:44 PM
  #60
stevieturbo
C**t
When I ordered my MT DR's from Lee at LA, they were about 3-4 weeks. That's pretty much what he quoted timewise.
if you want faster you'll pay more, simple as that really. Although bigger places may well get more frequent shipments
When I've bought the Hoosiers direct from Hoosier UK, they're fairly quick if timed right, ( and Hauser too although it was years ago ). You could have them in a few days if you get the order just in time for one of their shipments.
Old 30-10-2016, 02:46 PM
  #61
jamie956
jamie956's Avatar
Yep quoted me the same 3-4 weeks took about 4-5 months to arrive, the thing that pissed me off as he lied every time i asked where are they "yer there on the way be with you next week" when they arrived the airfreight label was still on sent from New York 3 days before I received them.
Old 30-10-2016, 04:15 PM
  #62
turnover
turnover's Avatar
Trev you should be hitting atleast low 1.5s or mid 1.4s in the cortina,I don't know if your on a 4 link etc,but I presume you've checked diff angle,plus you might want to get it corner weighted,does make a difference and make sure your in the car when this is done
Lots of things can be done to improve my only advice is do one at a time,as in play with rear shocks after each run,or do tyre pressures do NOT try and do 2 or 3 things at once as you won't progress as you don't know what making th difference but many do alter too much in one go
Looking at your launch pic it looks like o/s rear needs stiffening
Old 30-10-2016, 08:30 PM
  #63
ekjim
ekjim's Avatar
Thanks for tyre advice Stevie & Jamie , I got my car corner weighted problem is I'm not quite sure how to use information to help my car launch with my 4 bar coilover setup .
NoRubNoDub
Fitness / Weight Training Discussions
26-08-2020 05:23 AM
martynhomer01
33
02-10-2016 12:13 AM
chrisa3
21-09-2016 07:00 AM
timsrs
20-09-2016 11:56 AM
bridgeman
Ford Fiesta
06-09-2016 09:38 AM
Quick Reply: Drag slicks on standard Cossie lattice wheels
