Cossie steering rack repair
My saph cos 4x4 steering rack has play in the rack (geared toothed part on o/s/f). I'm just doing an mot for one of our traders who used to be a ford master tech back in the good old days and I've been talking to him about it and he reckons they used to suffer with a certain problem. Like the older ones with a plate and 2 bolts holding a cover on the sierras have a plug with a massive Allen key shaped hole and it's on a thread. Under that is a strong spring and another part he can't remember the exact name of. He said the springs or that part used to fail and cause loads of play in the rack arms. Has anyone ever taken one of these plugs out before?
Originally Posted by Glenn_
Have you not got a cossie repair manual matey. It shows you how to strip the racks down.
I can post some pics up of the repair manual if you get stuck. Im sure i downloaded a copy of the tinterweb.
Are you sorted now l? I've stripped one of these racks ages ago i just cant remember lol.
Hopefully you can sort it.
Originally Posted by dojj
Get a 28mm bolt and weld it to something to make the key
Find a 28mm nut that I can weld something to also
Is it not easier to get a reconditioned rack.. My brother spent a good while reconditioning his rack only to find it leaked 100 miles down the road. Got a ref-conditioned one on an exchange and happy miles ever since. Wasn't worth the time or the cost of the seal kit in the end.
Received 1,042 Likes
Yerp this also happened to me.
my rack on 4x4 is the same,what symtoms are you getting
,i can feel something not right through steering wheel and my front tyres wearing bad inside and outside,
virtually new everthing so the only play there is is in the rack,
id need different style key to adjust the black bit,
colin
colin
colin
colin
Have you try to adjust the preload on the rack? Have done this on some, and they are fine afterwards
http://www.dreamsofdrifting.com/ae86/rackpreload/
1374lee
20-09-2016 07:48 AM
