Mid-engine'd Ford?
#41
I have looked over and over the car, I don't think it's that bad. Definitely cheaper I reckon.
Stevie, I've been thinking a lot about how to do this, so I may end up using front Puma hubs. I can always change it at a later date - I just want the geometry to be right. After getting the engine in the right place and as low as possible, this will be the difference between it driving and corning like dog shite or being pretty darn good. I need to make it adjustable everywhere so I can take it to someone who knows the maths and science behind chassis dynamics, then they can get it set up right. That way I shouldn't end up in a hedge on the first corner!
Failing the Puma hub route, I think it might be a custom job.
Thanks for all the input.
Even if it does work out cheaper (I'd be surprised)
It is massively more complicated and everything turns into a big, awkward job.
I'm not discounting the idea or trying to put you off.
But my car spent so long off the road cos even simple jobs took such a long time to do that a normal setup wouldn't, that you lose out on a lot of driving time.
#44
Boooost!
Yes, thanks for the sarcasm I need some sleep clearly
I think transverse might be easier. The only headache I've got currently are the gear shift cables, as even when they're short if you get them routed wrongly it's dog shite.
stevos (17-09-2016)
#45
Are you able to get another cheap puma and mock it up with spares off that so you can keep yours running as long as possible till the majority is done?
I think it will be good to do something different
#46
If going mid-engine I'd mount the engine lengthways and use a transaxle, that way the engine will be more central and not sitting on the rear axle.
#47
If you need longer cables...just get longer cables made. That's easy.
#48
Boooost!
I was thinking about that and although cheap I don't fancy spending the money on it. I did think about doing it all to another shell, but I would need a mock 2.0 blacktop and an FRS box as they are unique in their mounting holes I believe.
I pretty sure I will be doing it and I don't quit. So many of these projects get started and never finished. I'll just keep going until it's right
I've asked Cable-tec about cables and yes, they don't seem to be a problem to get made. They've shown me a shifter with cable entry from the rear but it's not going to work with the handbrake in the way.
I need to start a project thread for the car's current state anyway, and I'll put the progress in there. My biggest decision by far is whether I start it this Winter (mid-October probably) or wait until next. I'm supposed to be taking the roof off my bungalow to convert to a house in February which has made me lean towards starting it now, otherwise it'll be forever in the making.
#49
Boooost!
Would I be mad trying to keep air conditioning with this set up?
I obviously have the space at the front of the car for charger cooler rad --> A/C condenser --> coolant radiator. I can make the majority of the new lines from aluminium, bending and welding. Would just need Pirtek or similar to do the short rubber flexi hoses either end.
Thanks,
Ben
Thanks,
Ben
paceo
25-07-2016 11:29 AM
Ashlaw
11-07-2016 08:31 AM
