What wideband kits are people using?
Wye Valley Hardcore
As above. My Innovate LC-1 controller seems to have given up on me and their customer service seems as good as their products, so time for a change.
What are people currently using, recommendations.
I did fancy a Stack to match my other gauges, but are there better kits out there for the money? If I'm honest, I'm not completely happy with my Stack gauges anyway for what they cost!
AEM kit on mine, has been spot on for about 4 years now. Links into the ecu so can run closed loop fueling via it, AFR's seemed pretty accurate to the readings I got on a power run at MSD.
http://www.efi-parts.co.uk/index.php?productID=204
Engine Machinist
aem uego for me, but i'm yet to get the car running so i can't comment on reliability.
http://www.ebay.co.uk/itm/New-AEM-Di...MAAOSwgQ9V4Eey
Dynojet Wider Band Commander (not the wide band 2) .. been using it for years and its spot on and still going strong.
AEM for me too, smart bit of kit.
http://www.plxdevices.com/PLX-Wideba...uges-s/125.htm
I thought they had gone belly up...their support forum certainly did.
They should have because of their awful customer care and crap parts. Oh well, they made enough money from the r-500 dross.
I'm actually looking to buy a kit today. Anyone using LD Performance's kit? Only reason I'm leaning towards it is the LCD because I don't really want another gauge in the car.
https://ldperformance.co.uk/product/...nd-controller/
New Owner
Bosch sensor so probably just as good as any other bosch sensor wideband kit in its accuracy.
"Accuracy" can mean many things....and of equal importance is the controller. They almost all use Bosch sensors ( or some generic equivalents ) anyway, that's why the setups are so cheap in the first place. It's just an OEM sensor
I have just put a lumenition square gauge old Skool one in the for sale section cheap.
Location: it's not where you are, it's where you've been and where you hope to be
So true! its critical that there is no exhaust leakage past the sensor in the exhaust bung. the gauges (analogue or digital) are just voltmeters which take the analogue voltage from the controller (which in turn relies upon the sensor) and report it. on my analogue innovate setup the gauge itself has a 2% voltage error reading. they also say you must 'recalibrate' the sensor/controller frequently. the whole thing looks a little unreliable really. apparently, you can check overall accuracy (at least at stoic) by using a narrow band as well which are very accurate at stoic.
Matty_C
34
11-04-2018 12:01 PM
cossirob
12
20-08-2016 08:48 AM
B16CVH
Ford XR Parts For Sale
16-08-2016 11:33 AM
