Wrapping a car
Wrapping a car
I've seen a few people comment about wrapping cars in vinyl and i'm thinking of going this route soon but just have a few questions
does it damage the paint underneath at all? Mines fine apart from one small rust bubble on the passenger door.
what is the process of applying the wrap? is it as simple as doing something like:
clean panel, spray soapy water on the panel then lay the vinyl on top and use a heatgun while smoothing out the vinyl and getting any bubbles out of it
how do you go about trim like the small pieces normally half way up the doors, do you remove them, wrap them and then refit them?
thanks
thanks
DECODING JIBBA JABBA!!
it will only damage the paint if the paintwork is not 100% the rust will need sorting and at least priming/flatting before wrapping over
you apply wrap dry with heat not with any fluid.
small items are best removed, wrapped and re fitted
trust me it's not easy to do so be prepared to screw it up if it's the first time you've done it, as there are LOTS of techniques used to get it right.
my friend wraps vehicles most days, from cars to coaches, he uses soapy water as it makes it easier to adjust, but as said above its not easy, he is on here but not sure of his profile name, hopefully he will be along to advise shortly
I highly doubt that if he is a pro wrapper he would use soap and water to wrap a car. Proper wrap vinyl is repositional (ie - not that sticky) and most now come with an air release system. Once in place you 'activate' it by applying heat (which makes it sticky. He may use soap/water when applying larger graphics onto cars but not wraps (although he should not really be using soap / water, there are particular liquids that are much more efficient).
As said above paint needs to be good otherwise you run the risk of removing laquer / paint when removed. Easiest thing is to youtube it, plenty of guides. I've been wrapping cars for around 6 years now and always find new techniques even now. Always taking care cutting on the car as you will damage if done too heavy. You can buy cut tape which makes it easier.
HTH
Chris
HTH
Chris
Some very interesting replies guys and all helpful.
I might pick up a spare rust free door since the cars being wrapped so I don't have to worry about the rust now. The rest of the car is fine. I will have a look for some youtube videos, most i've seen have been for dipping cars which doesn't give the best results from what i've seen.
on a scale of 1-10 what would people say it normally is, i'm good with mechanicals and can swap engines etc but this will be a first attempt.
only other thing that I was concerned about is trim, would that need removing and then wrapping and refitting?
I would say the more you can take off the better. Depending on the car I aim to remove all headlights, bumper trims, door handles etc where possible. I'm confident enough on some cars not to do this but for a beginner definitely! Prep is the key as well, get yourself some isopropyl and clean all panels etc properly just before applying.
Some people pick up wrapping really easy, although its down to the person. I would have thought that window tinting is similar but I am SH1T at that!! Although I will be going on a tinting course soon!!
I've been in the trade 22 years. I used to wrap cars well before the air release was around.
Wrapped a mini once in chrome. Not air release and was thick stuff.
And found that easier to do than leaning to window tint. Still find it a ball ache tinting.
I work for the biggest wrapping company in the UK and done correct using a decent material it's fine, be careful who you use - adhesive technology has come along way so the vinyl can be moved around before heated in - I'm having my BMW wrapped next week in 3M 1080 satin dark grey
plenty of vids to YouTube showing it done but there is no substitute for experience. Glasgow wrapping company regularly use my unit when they have a car to do through this way so I've seen it done many a time. I got them to wrap my van in matte grey a few years ago. Still wouldn't expect to be able to do it myself without lots of practice. Easy(ish) to do the flat panels but it's all the fiddly bits that put me off..
Is that Jay your talking about.? If so he wrapped my mk1 focus rs and did a superb job, it completely transformed the way it looked and was a great way to stand out.
Thanks for the replys. I've got a pair of new bumpers coming soon for my car in the next week hopefully so I'll be getting some stuff together and wrapping them before they go on the car and wrapping a spare passenger door thats rust free. If that goes to plan i'll progress onto the rest of the car.
Originally Posted by JasonPD
Based on what I paid to have my van done (ÂŁ1400) I'd estimate about a grand
Originally Posted by costina
And thats from a guy who run's bodyshops so it must be good....
JasonPD (20-08-2016)
produces 262bhp @ 6psi and was 30+ degrees in the workshop the day it was mapped!!
Visabroke. From the replies and photos put up it seems to me if you want it done right and to last its not really a D.I.Y. job. If you can afford it leave it to the professionals.
visa_broke (19-08-2016)
Originally Posted by furry
it's the only tigra twin top turbo in existence that we know of.
They look bloody good wrapped, a friend was going to get a it done last year but didn't I've also thought about it but one thing..
They obviously don't do under bonnets, inside doors ect ect cause say the car's red and you want matt black, evertime the doors boot or bonnet's opened it's a giveaway...still look good though..
Quaver - inside doors is the normal, in some instances it is possible to remove the door, wrap right across the shuts and refit the door. The inner edges of the doors are normally done as well. If someone wants a cheaper install done you still run the vinyl around the first lip so that the colour cannot be seen.
Below is an S4 I wrapped, was red underneath but did the doorshuts, you couldn't even tell what colour it was previous when it was finished!
Yanamize is prob the most well known for wrapping. But charges for it. They strip the car right down. And have it on ramps. Always remove the doors. Lights. Bumpers off
Looks good that van, that shape is bit of a fooker to do, those recesses on the side panels are deeper than they seem! I just wrapped one this shape for a customer as well, it was red and he wanted it wrapping, ummm, red (very random!!)
