Ford Focus Boot Leak -06 PLATE MK2
Good day all, hopefully you can help
I have water coming into the boot
I have replaced the plastic inserts that the lights fit into and used silicone around the other rubber inserts and around the wiring. This is on the drivers side.
When you look into the boot and up through the plastic into the back of the light, you can see where the metal has slight signs of rust. Any other entry points to consider
Any help is much appreciated.
Youtube videos suggest the boot hinge on that side and the part with the plastic trim of the roof meet the boot lid. Possible hairline fracture there. Will investigate
tailgate hinge plates and upper rear seams are common for leaking and water runs down the roof and normally corrodes read wiper relay.was a technical bulletin when I worked at fords
chink
20
08-08-2016 05:11 PM
BigD.
12
04-06-2016 03:31 PM
