Mk4 mondeo EGR Blanking
Old 31-05-2016, 11:55 AM
The Crocodile Hunter
The Crocodile Hunter's Avatar
Default Mk4 mondeo EGR Blanking
After some opinions on blanking off the EGR on an 09 Mk4 2.0 tdci
After a quick google there are mixed opinions and it seems that no matter what you do the fault light will come on. Lots of people seem to just live with it and clear the code regularly
What do we think?
Old 31-05-2016, 08:24 PM
slammedorion
slammedorion's Avatar
Blank egr
Get it remapped and have the egr mapped out
Old 31-05-2016, 08:41 PM
Thats the fall back, i just dont want to do that unless i have to.
Old 01-06-2016, 08:50 AM
slammedorion
If you want the light off and the egr deleted you've got no other choice tbh
I've run our Vectra cdti with the egr blanked and remapped for 4 years fault free
It used to have daily wobbles with egr related issues
Inlets a lot clearer now with it blanked
Egr's are awful things, cause nothing but issues on modern cars
Old 01-06-2016, 09:31 PM
The Enigma
The Enigma's Avatar
What are the symptoms of EGR troubles?
Old 01-06-2016, 09:36 PM
RichieST
RichieST's Avatar
If the egr is working properly I would just leave it be. Easy enough to blank off a vacuum operated egr like the 1.8tdci has, but an electronically operated system will just give you a nightmare.
Old 02-06-2016, 05:29 AM
grcossie
grcossie's Avatar
On my 2009 Kuga euro4 2.0 tdci, i have blanked egr, and been like that for years. No light and no fault code
Old 02-06-2016, 08:00 AM
gcfcos
gcfcos's Avatar
I hate egr valves with a passion. Terrible idea. Most diesel faults that come into the garage where I work are egr related. Oh and dpf problems are a weekly occurrence now too :-(
Old 02-06-2016, 09:40 AM
grcossie
grcossie's Avatar
Exactly, is the biggest engine trouble maker these days
Old 02-06-2016, 01:25 PM
slammedorion
Blank and forget
Old 03-06-2016, 09:50 AM
It has developed a very light hesitation on light throttle, doesn't happen very often but I'm sure its the egr sticking every now and again. Under normal load its fine
I'm going to give it a clean out to start with and see how it goes
Old 03-06-2016, 09:59 AM
I assume they use the peugeot engine the same as a mondeo? You must be really lucky if the light hasn't come on.
Where have you blanked it off? Just fitted a plate between the pipe that crosees the engine and the egr? Assume you've left the electrical connector plugged into the egr itself?
Mark_
30-05-2016 05:19 PM
cutch
12
30-05-2016 07:27 AM
anthony lea
27-05-2016 08:01 PM
90_spec
20-05-2016 11:28 PM
James Porter
02-05-2016 06:09 PM
Quick Reply: Mk4 mondeo EGR Blanking
