YB Exhaust info
YB Exhaust info
Dose a YB require exhaust back pressure to run correctly, im toying with making a side exit system for my car with no silencers, would just be down pipe 90 deg bend then out the side.
burnzy
No exhaust is best exhaust on a turbo car, hence why hyabusa turbo's run just a short length of pipe off the turbo.
N/A require back pressure to help empty the chamber of exhaust gassed to give a cleaner burn iirc.
David Vizards excellent book talks a lot about the testing he did on the a series engine with loads of types of normally aspirated engines and it was amazing what the exhaust does on a normally aspirated car. An open pipe on that would lose power but I believe as others have posted that it doesn't matter on a turbo car.
And of course it's all very camshaft ( and rpm range ) dependent too.
True, he def had a section where back pressure was needed, maybe it is to do with the a series specifically?
It just means it was a bad combination to start with. But as said there are so many variables it would be a nightmare to optimise for everything and every one
But turbo....bigger is better. Nice and simple !
Read the book then and argue with David Vizard, google him, he knows his onions
timsrs
11
21-05-2016 04:48 PM
