2.9 efi 12v
2.9 efi 12v
So I'm putting a 2.9 efi out of a Granada 4x4 into my Capri . I've swapped sump for rwd and stripped all the wiring from the donor car today.
It's the air flow metre type engine but I'd rather have the lamba sensors installed so that I can use cone air filters. They look so much better I think than the bulky air flow meters.
Can I convert to this I'd it possible
This is from the donor car
If I read your question right, you want to remove the air flow meters completely ?
You would have to use an aftermarket ECU, such as MegaSquirt or Emerald to do that.
I had a XR4x4 with the flapper type airflow meters and it ran fine with the K&N filters fitted - keeping the meters and stock ECU and it never came with lambda sensors.
On a side note, the Escort Cosworth boys would kill to get their hands on your Granada 4x4 hubs - pretty rare now!
I will probably just use air flow meters. They were the only part that I couldn't get as they were not on the donor car so I will have to get them in eBay or something. It's really the wiring that has me stumped. I need a wiring diagram, having trouble fining one though.
Live long and prosper!!
What colour are the wires you have left once all the sensors and ecu are fitted?
Green will be tacho feed
Black usually ignition feed
Brown white trace temp gauge
Red battery positive
Black red trace fuel pump positive.
Brown earth
Red blue trace can also be battery positive.
These are from memory need to see a pic of what you have really to check.
Most fords are the same.
Brown earth
http://www.autobest-tuning.cz/kn-kit...hp-p-2221.html
I think I have found the correct one for sale.
jim_robson
29
06-05-2016 01:49 PM
tockwell
08-04-2016 08:46 AM
