4x4 Saph how to make them Handle???
Old 30-04-2016, 03:23 PM
BigD.
Japan meets Dagenham
BigD.'s Avatar
Default 4x4 Saph how to make them Handle???
Looking for some advice on what parts and brands of parts you guys are using on fast road set up saph 4x4's to make them handle better.
Thanks in Advance Darren
Old 30-04-2016, 03:55 PM
Caddyshack
Caddyshack's Avatar
6 degree rear beam seems to be the most popular mod, this stops the geometry change on the rear. £1200 ish from Mk motorsport. Ahmed bayjoo springs or quality coil overs. Mk also does adjustable front track control arms, compression struts and bladed anti roll bar. Get that all set up properly, new bushes and the some good tyres like the new toyo r1r and it should Stanform it. I think strut braces would help too.
Old 30-04-2016, 04:34 PM
Marc sierra
Marc sierra's Avatar
I have Koni dempers and Ahmed Bayjoo springs on mine with poly bushes all round, including the diff mount. At the front it also has a sort of compression struts fitted that still retain the original antiroll bar. After changing the rear beam for a 6 degree one it had a lot less understeer on track. It still has some understeer left so I plan to change the rear arb for a thicker one with rose jointed drop links.
Old 30-04-2016, 04:47 PM
Diff mount is defo a good mod.
I would like to go out in a safd with a 6 degree rear beam to see how good they are.
Old 30-04-2016, 04:49 PM
Caddyshack
Caddyshack's Avatar
A lot of the rear diffs are tired too and don't lock very well, worth getting it to Bara motorsport for a freshen up. Or go supra diff mount kit, you can weir kit it too
Old 30-04-2016, 04:59 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Beam good bushes good coil overs. Traction is down to good diff and tyres as well. There's loads you can to from moderate fast road set up right up to the sort of spec rod has. All depends on budget really
Old 30-04-2016, 05:13 PM
Marc sierra
I always wonder what a lsd in the front diff would do for the handling.
Old 30-04-2016, 05:38 PM
BigD.
BigD.'s Avatar
I saw the beams and wondered if that was a track only mod or a worth while one for a fast road car, whats the suspension of choice? I have koni's but they feel a bit wayward, that said could be the rest thats needing changed and it'll change it all
Old 30-04-2016, 05:51 PM
Marc sierra
My car is still a road car, so all the changes I have done are suitable for the road. Whether you think it is worth the money is all personal of course. Personally I want the best handling that's still ok for a road car, so no rock hard suspension for me.
Old 30-04-2016, 06:05 PM
BigD.
BigD.'s Avatar
Sounds exactly what i want from mine, ive done the rock solid suspension on other cars and unless the road is perfectly flat its of zero use as it skips over the road rather than riding over n through it
Old 30-04-2016, 06:16 PM
gcfcos
gcfcos's Avatar
Ive got koni adjustable shocks and koni springs and fully polybushed the car but it's still a bit of a boat. I want to fit coilovers and compression struts when I can afford it to see if that improves things
Old 30-04-2016, 06:27 PM
Adam-M
Adam-M's Avatar
You not keeping yours standard anymore Darren? I've got bilstein shocks but they are far too soft so just ordered gaz gold coilovers
Old 30-04-2016, 06:28 PM
Caddyshack
Caddyshack's Avatar
I can't say it has changed mine much but when you really go for it you can feel the front tyres grip.
Old 01-05-2016, 07:44 AM
BigD.
BigD.'s Avatar
No ive a ton of parts to fit adam, and when i do i want it to handle a bit better , alot more go and same handling wont work lol
Yeah i saw the Gaz Golds n wondered.... I run bilsteins with 40mm pistons in my daily golf . They are firm but not rock hard like the last coilovers i had, just hoped the gaz golds might do the same and be firm but not crashy
Old 01-05-2016, 07:50 AM
Caddyshack
Caddyshack's Avatar
Coil overs I find quite frustrating as there are so many choices and too many are made just to get the car low and are of poor quality. I know the rally boys can spend over £2500 per corner so there is a huge range...not that you need to go too tot for the road. I suspect reasonable damping and good geometry with sensible Spring rates is what is needed. People often go too hard.
If you look at some of the greats such as scoobies, 205 gti, 911 996 turbo, Mitsubishi evos etc what made them great road cars was good compliance down a bumpy road.
Old 01-05-2016, 11:17 AM
costina
Live long and prosper!!
costina's Avatar
Don't use coilovers on a road car.
Poly diff mount and make sure you have original bushes in the rear arms.
Good set of koni's and AB springs don't go any lower than 25mm.
Chamber shims on rear help also good tyres and set up.
Old 01-05-2016, 01:55 PM
I defo noticed the difference when i put a modded diff mount on my saff. The rear end seemed alot tighter.
Old 01-05-2016, 03:02 PM
Jay,
Sponsor
Jay,'s Avatar
Wouldnt use AB springs unless they have changed as they are not progressive
Regards Jay
Old 01-05-2016, 07:37 PM
Adam-M
Adam-M's Avatar
Well mines has uprated diff mount, fully polybushed, decambered back end, strut brace and bilstein shocks and springs and I think it's far too soft and roll poly.
I've been in a few cars with decent qaulity DAMPER adjustable coilovers and I thought they drove superb.
Old 01-05-2016, 07:38 PM
Adam-M
Adam-M's Avatar
Sounds good mate what power do you have in mind?
Old 02-05-2016, 06:26 AM
Marc sierra
As far as I know Bilstein only make shocks and not springs. So what is the make of springs that you have? But I would expect that Bilstein shocks are quite a bit better than GAZ or AVO coilovers.
Old 02-05-2016, 07:24 AM
YBJ
Thinking Cosworth..
YBJ's Avatar
I have driven a 4x4 cossie with coilovers. At first I thought it would be to harsh. But when I drove it it was nothing like that at all! Very firm nice drive, brings the car to a level like the cars from today. I really didnt think a Sierra could feel this way. So now I now some good quality coilovers can make a very, very big difference to the car.
And my car has got AB springs, Konis, polybushed and PU diff mount. Still drives like a boat...
Old 02-05-2016, 09:09 AM
Matt Baxter
Back in black!
Matt Baxter's Avatar
Mines 2wd but....
I've fitted a modded beam and gaz gold coilovers and it's pretty good tbh! Already had a good poly diff mount and solid beam mounts it all helps!
Old 02-05-2016, 09:23 AM
Adam-M
Adam-M's Avatar
Sorry mate they are Koni springs.
Old 02-05-2016, 11:18 AM
Marc sierra
Koni also only make shocks. If it was supplied in a full Koni suspension kit the springs may have been made by Eibach.
@Wim, what coilovers where they? My car has about the same setup as yours. What do you mean by feeling like a boat? The AB springs and Koni shocks aren't really soft, or is that not what you mean? For road use I don't think they are soft, but last year when I was on the track I thought the setup could be a bit stiffer. But when coming home I found out all shocks were still set to their softest setting.
Old 12-05-2016, 08:09 PM
YBJ
Thinking Cosworth..
YBJ's Avatar
Gaz Gold coilovers, very good!
4x4kiwi
04-05-2016 08:32 PM
davidfordrs
28-04-2016 08:06 PM
ghrs91
28-04-2016 07:20 PM
RsS2daz
28-04-2016 05:10 AM
mrmann
27-04-2016 08:29 PM
Quick Reply: 4x4 Saph how to make them Handle???
