Supra/Weir diff oil
cossie fan (unluckerly)
I've not driven it yet as the engine is out. But I had it at my workshop when I did the beam. While I was moving it about it sounded exactly the same as my gripper did which I was a bit gutted about
Mine is quite knotchy in reverse when cornering, you can hear it and feel it but mine hasn't done 100 miles yet. I think you can hear it at very slow speeds turning going forwards.
Thats a good question as to be fair my mates dose lock both wheels. I guess the kit just makes it lock them sooner as it tightens it up. Mine is just a weekend toy so I'm not fussed and it can't be as bad as the gripper i had in it
Yeah, I don't mind mine either. Mine is really tight, so much so you Can only just turn a wheel by hand but I think it may loosen up. I don't spend much time in reverse so can live with that. Based on Baras reputation I think mine is fighting fit. Very happy with it, I didn't mean to sound like I was moaning.
You will have to try mine when I bring it up to you and see what you think
Bara done mine with weir kit
It's great had no problem just wish I'd fitted a shorter cwp as I prefer the shorter 3.9 I had in my quaife
Mark
Mark
Lol they seem to tell every person they talk to a different oil grade lol
I got mine from jaguar they keep it on the shelf for there cars with lsd's
I suggested the Castrol diff oil which when used quietened the diff.
A diff cooler was also fitted later as the diff temperature increased beyond what Castrol recommended
It is the same grade fitted to the MK1 & MK2 escorts fitted with plate diffs, it was also used in Capri 2.8 axles when fitted with a plate diff, although they would have had a light pre-load.
I use it in my own cars, the ones which have a plate diff.
I discussed with Gripper Diffs and trialled in two diffs I built for YB powered Westfields and found the Castrol oil performed better, even with the later Gripper plates fitted to the diffs, with both set with the same pre-load.
The second diff was filled with a non-Castrol brand of LSD oil, that diff was more noisy and wore the friction plates sooner.
The Jaguar oil suggested may be the same oil, but I have not seen any to confirm.
Steve
Chances are they have it as well then. Not many places keep oil that thick on the shelf. We have 85/140 as I work for Daf but it's mineral. They told me to use a good quality synthetic other wise I'd have used are oil like I did in my gripper
As long as it is oil specifically for plate diffs, the oil should be ok, normal diff/gearbox oil should not be used.
Steve
Let us know how you get on...maybe it can be made better with some experiment.
The noise is the plates fighting against each other as the wheels turn at different speeds. The stronger Spring in the up rate kit has made the load on them stronger
have just swapped out the Millers CRX 75w-90 LS as the Millers was too thin and making the plates smack like a bastard, now running Castrol Syntrax 75w-140 LS though it and it's quiet as a mouse, the only noise was the smallest amount doing a 3 point turn
Hi lads just a small bit of info here as iv got a supra diff in my focos and I have the same problems as you lot it banging but to be onist it's not a bother to me as the car is used a lot on track but wot I have found when underneath and the hand brake was on I could roll the prop a fair bit . It was not the diff at fault but there is play in all 4 CV joints . Witch if you think about it as diff loads up in a turn and then the diff slips / jumps as its a clutch set up inside . Any way as there is play in the CV joint it lets the diff unload more so witch will result in a bang . I bet if you go under your cars with the hand brake on and roll the propshaft you will see wot I'm on about.
At the end of the day we are all running stuff under these cars that's over 20 years old
I would say mine is near silent now and it has the weir kit and complete new driveshafts.
I don't know, Bara built it and didn't mention an option.
My diff doesn't make much noise at all now unless on full lock turning the car round etc. It took maybe 300 miles to settle.
I have quaife up front and all I notice is that if I slowly turn in to my drive it feels like I have put the brakes on, you can feel the tyres begin to run out of twist, it is the same doing a 4 point turn, it is easy to stall the car on full lock....so you can tell how tight they lock up front and rear...probably more so on my light 205 pug.
