Turbo specialists
Turbo specialists
Hi all not having much fun with that car at min , injectors 4 let
Go at mappers witch took the turbo with it , it's a turbonetics t4 roller bearing
External gated item any one know of a turbo of the same , this one good for
600 + . It's at s turbo place but they saying its mashed to bits . So I'm after something Asap it's on a v band exhaust side .and kind of why my plate says
T44 loy lol
T44 loy lol
likewise, brand new GTK550 here, or a friend has a GT4094R, but that's maybe a bit big.
Although autocorrect turned off would make the post easier to understand !
if it is actually a Turbonetics unit...how old is it ? They have some pretty good warranties ?
Hi Andy I have one big ask here as you have such a big turbo on your focos . Have your Pistons been machined to a lower compression and if so wot to ?
It's just a bit funny your car has done over 600 miles with that turbo on it . It goes on the rollers and it goes so wrong and I can not for the life of me see how the injectors could take out the turbo . From wot I no if your head is standerd and your Pistons are standerd then your turbo will have a lot of back presher hitting it . and it will put the turbo under a lot of strane big time
PassionFords Creator
For reference,
The engine arrived with a random missfire that came and went at idle.
While we were wiring up his Dash 2 coolant, rpm and wheel speed sensors we obviously had the engine running and the missfire got worse and worse and we found it was fouling No:4 plug. Upon investigation we discovered number 4 injector has an intermittent dead short which is causing it to stick open and miss close events from the ECU thus causing overfuelling on Cyl4.
The engine / turbo also smokes when it gets very hot which is indicative of a failing turbine oil seal.
Because of the above two items, along with a few other issues like a leaking fuel rail the engine was never driven out of the estate, nor did it ever make the dyno for mapping to even be started.
I fail to see how the injector sticking open with the engine only ever idling has caused the turbo to be "mashed to bits" I would challenge that diagnosis with whoever has made it pal.
Fuel in the exhaust housing cannot destroy a turbochargers core as the oil pressure is higher than the turbine inlet pressure... The only way it could is if it ended up in the sump and heavily diluted the oil which it didnt as we checked oil level when we discovered the problem and it was fine.
I guess if you have run it like that for a long time with a lot of oil dilution then yeah, maybe you could scorch the bearings, but as it came to me on a trailer I am guessing not?
For reference,
Wasn't saying it was anything to do with what u done mate and I'm not fussed .done all jobs just waiting on turbo
New injectors
New fuel rail
Fuel pump rewired
New plugs
And turbo on its way to some one else to be rebuilt
As I wasn't happy with what the other company said about the hole
Thing
Car done 600 miles steady away most that mainly driving to photoshoot
Odd thing is...there are no oil seals in an oil journal turbo. But it doesnt make any sense a leaky injector could fuck a turbo.
Although what make etc of injectors were they ? such problems are rare
They Siemens 83'z now the damaged injector replaced and I've got a spare
I'm not at all fussed what happened I was just trying find a descent person to
Send my turbo too , witch I now have ! I've replaced all the parts witch weren't fitted
Right or faulty soon as turbo back I will be trying book it back in at msd as the summer is close an no car =unhappy Dingle
Mickyflint
17-04-2016 12:12 AM
tockwell
13-04-2016 11:24 AM
Indyrs
07-04-2016 09:53 PM
